Old 01-04-2015, 03:27 PM   #176
marvgarr68
marvgarr68's Avatar
Re: 68 c10 6.5 turbo diesel
Originally Posted by ryanroo View Post
very nice. i love the attention to detail.
Thanks ryan.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 01-12-2015, 12:11 AM   #177
marvgarr68
marvgarr68's Avatar
I got the intercooler tubing roughed in and found a bell housing lower and front shield.
Old 01-12-2015, 01:42 AM   #178
jbclassix
Junk Yartist
jbclassix's Avatar
Very nice!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 01-12-2015, 02:36 AM   #179
marvgarr68
marvgarr68's Avatar
Thanks.
Old 01-19-2015, 01:26 PM   #180
superduty_59
Love the work! Can't wait to see this truck done.
superduty_59 is offline   Reply With Quote
Old 01-20-2015, 04:30 PM   #181
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Love the polished aluminum piping. Bell housing looks great too!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-30-2015, 06:12 PM   #182
marvgarr68
marvgarr68's Avatar
Well I have mastered taking the starter out of this truck. I have removed it 13 times could not stop it from jumping the ring gear and trying to strip the flywheel. I even got a new starter but still the same I finally got it meshed pretty good only kicked out once. Well it RUNS!!!! I got the the fuel system done and new filters. I also finished hooking up the oil pressure gauge. It needs to be timed I will bring the scanner from work and time it. It sounds great and nice and smooth. Oil pressure was almost to the end of the gauge if you revved it then it would peg. The turbo sounds great and the throttle response is awesome. I almost gave up on it after all the starter troubles but the wife kicked me in the butt and told me to figure it out. I wish I had a video but I was messing with the starter and didn't think about it.
Old 04-02-2015, 02:33 AM   #183
marvgarr68
marvgarr68's Avatar
I had went through this build thread from start to finish yesterday. I was looking for something and it occurred to me know one has said anything about the valve covers. Interesting.
Old 04-02-2015, 02:40 AM   #184
jbclassix
Junk Yartist
jbclassix's Avatar
I thought I saw double CDR ports but I just automatically assumed that was genius! Is there something else I missed? By the way, I am copying your double vent valve cover idea.
-Jeremy
Rebuilding an NP205
Old 04-02-2015, 11:14 PM   #185
marvgarr68
marvgarr68's Avatar
It will have crankcase evacuation. I wanted it to draw from both banks evenly. The valve cover fits no problem even the injector line bracket fits it.
Old 04-03-2015, 01:38 AM   #186
jbclassix
Junk Yartist
jbclassix's Avatar
I'll have to pm you my CDR plans for mine and see what you think. Are you going to run the CDR canisters? My plan eliminames them. what are you going to run for evacuation? A pump or venturi?
-Jeremy
Rebuilding an NP205
Old 04-03-2015, 10:20 PM   #187
marvgarr68
marvgarr68's Avatar
No CDR canisters. No pump. PM your plans.
Old 04-11-2015, 11:35 PM   #188
marvgarr68
marvgarr68's Avatar
Here is a video for you.
http://youtu.be/yZilNjUX3cU
Old 04-12-2015, 12:06 AM   #189
jbclassix
Junk Yartist
jbclassix's Avatar
Smoooooooth!
-Jeremy
Rebuilding an NP205
Old 05-07-2015, 10:09 PM   #190
marvgarr68
marvgarr68's Avatar
Jeremy thanks for the ECM. I got it installed and is working really good runs awesome. I just need to get a new PMD and I will be set.
Old 05-07-2015, 10:18 PM   #191
ryanroo
ryanroo's Avatar
that sounds great! reminds me of my dads old 6.2l trucks.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-08-2015, 11:27 AM   #192
jbclassix
Junk Yartist
jbclassix's Avatar
Aw man... I shoulda thought about the PMD's. I have a stack of them. when I get the 6.5 in its new home I think I'm going to run through the stack and see if any of them are good. Glad to hear the ECM fixed the problem!
Old 05-08-2015, 03:07 PM   #193
notchbackgta
Is the CDR the thing that is on the crankcase system? with the tubes that go to the intake? I have a 6.2 that I would like to make look nicer, but I don't know whether I can just eliminate that can thing
notchbackgta is offline   Reply With Quote
Old 05-08-2015, 10:20 PM   #194
marvgarr68
marvgarr68's Avatar
Yea I want to get the new Dorman PMD suppose to last.
Old 05-08-2015, 10:22 PM   #195
marvgarr68
marvgarr68's Avatar
You can but if its worn out you will spit oil every where.
Old 05-09-2015, 01:47 AM   #196
woodwright
Enjoying left field
woodwright's Avatar
So do you have a writeup somewhere about your cdr delete?
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 05-09-2015, 12:07 PM   #197
marvgarr68
marvgarr68's Avatar
I do not as I am not finished with it yet.
Old 05-09-2015, 03:29 PM   #198
notchbackgta
Yeah, that is what I was wondering
Old 07-15-2015, 05:24 PM   #199
Lemield
Lemield's Avatar
Any updates?
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 07-18-2015, 12:50 AM   #200
marvgarr68
marvgarr68's Avatar
I'm starting back on it just ordered new pmd. My plans are make battery tray and make exhaust next.
