Old 08-11-2014, 09:24 PM   #176
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Loadmaster '47 COE
Rob, I'm glad to see the house damage isn't worse. It looks like if the tree fell back a little it could have been much worse.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-29-2014, 07:25 PM   #177
Eric Q.
Hi Fasttoys
I just stumbled across your thread and we have similar projects although yours is much further ahead. I just recently acquired my donor vehicle. Similar to you, I bought a 2002 GMC Sierra with the 4.8 to go under my '50 GMC COE.
I read your post about modifying the LS wiring harness and have a question. It appears that a lot of folks modify the wiring harness or get a very basic harness to simplify the installation but doesn't that render all the cool features of the driver information center non-functional/absent?
Similarly, the aftermarket gauges that I've seen use their own sending units vs. the ones that come with the LS engine and send information to the ECU. Are folks disabling the ones that go the ECU or running in parallel and ignoring the factory signals?
My goal would be to use as much of the modern functionality as possible while making it not look modern.
Thanks for your input on these questions and can't wait to see your progress when you return to the states soon.
Eric Q.
Eric Q. is offline   Reply With Quote
Old 08-30-2014, 11:19 AM   #178
47 Fasttoys
47 Fasttoys's Avatar
Hey Eric, To answer your questions, yes the typical mods to the wiring harness eliminate the the information center function. I did look hard into retaining it, as it does do a lot of neat things. In my case, and maybe yours, I could not find a good way to incorporate the donor dash into the '47 dash and make it look right. I tried photo shopping the gauge cluster in my dash but just didn't like the look. The donor cluster (with info center) has a complete printed circuit board lay out which would have to be completely modified and re-engineered to use the info center only. You would also have to keep the the body control module, lock system and column along with almost all of the stock sensors. Now the other option is to use one of the aftermarket info centers which have most of the same functions. These units plug into the OBD II port. I plan on using one of these and a flip down speaker grill mod. As far as retaining the factory sensors goes, some you need to keep. Temperature sensor is required, oil pressure is not, oil low level is not (hot rodders check their oil just because they can) Tach signal is required for the ECU, but ECU also has an output for an additional tach. For a basic 5 gauge lay out you would need only to add a second temperature sensor to the engine, swap the oil pressure sensor, use the VSS signal for the speedo (using an electronic speedo), swap the fuel level sensor and wire in a volt gauge.
I sure you will find there are lots of little challenges in building a COE but that's where the fun is. Post up some pictures of what you got. And by all means ask a ton of questions, we all have a lot to learn from each other. 62 days left, and yes, I'm counting.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 09-03-2014, 10:48 AM   #179
sparkydog
sparkydog's Avatar
47 Fasttoys - nice project! I encountered this same decision on my build and ended up striking a compromise. I was able to graft the backlit idiot light graphics out of the donor cluster but I too could not figure out a viable way to migrate the logic chips for some of the more advanced functionality of the donor cluster. If you want to study what I did (a lot of work) it starts at post #705 on my build thread which is linked in my siggy.
Looking forward to your return to the states and the progress on your build!
Balls and a Sawzall
Project Halfbreed
Porsche 944 L67V6 CARB Legal & Other Stuff
sparkydog is offline   Reply With Quote
Old 10-09-2014, 08:49 PM   #180
47 Fasttoys
OK, so I will be back on the truck in 3 weeks and I'm trying to come up with a basic plan of attack. Here is a list of the major work to be done. What I would like input on is in what order would be best. Below is my guess.
1. Final location fitting of the cab and mounts. It will be removed later for frame work.
2. Front sheet metal mounts and test fits.
3. Steering column choice and fitting.
4. Brake pedal choice and fitting. Early 70s Dodge van with 90 degree mount looks to be promising.
5. Seat choice and fitting.
6. Radiator location choice and fitting.
7. Seat choice and fitting. Late 80s Chevy bench is the goal.
8. Floor mods and access covers for engine maintenance.
9. Electrical component location and enclosure mock up.
10. Bed mounts and final decision on which type of bed. It will be a flat bed with fold down sides but it may also have a tilt function.
I'm thinking after these tasks are complete I can tear it all back apart for final frame welding and clean up, I will also be cleaning up the bottom of the cab and undercoating it. So what did I miss?
Rob
My '47 C.O.E build
Old 10-09-2014, 10:03 PM   #181
99 to Life
99 to Life's Avatar
I think you got it pretty on point, maybe get seat moched up bf you do your pedals and steering, thats about all I'd suggest.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 10-09-2014, 10:20 PM   #182
Advanced Design
Advanced Design's Avatar
With 99's suggestion I believe that covers the major items in a good sequence. Then all the other items..bumper, fuel tank, lines...Is the battery mount in the electrical center?
Hopefully your three weeks will go by quickly!
Advanced Design is offline   Reply With Quote
Old 10-10-2014, 02:41 AM   #183
47 Fasttoys
At this point I'm not sure where I will put the battery. You make a good point on the seat , I will do that before the pedals and column. If I have an option on radiator placement, would you guys recommend behind the grill with an electric fan or under the cab using the original mechanical clutch fan?
Rob
My '47 C.O.E build
Old 10-10-2014, 08:12 AM   #184
Advanced Design
Where would the radiator have the best airflow?
Old 10-10-2014, 11:04 AM   #185
99 to Life
99 to Life's Avatar
yeah good point on the radiator. if worse comes to it, you could make air ducts to help get flow to the rad if its in a awkward position. The fan situation will be dependent on space. I think the Efan is the way to go for not only tight fit but why not gain a little extra performance by not running the mech fan. I don't think cooling will be any issue.
as for battery, I like having easy access to it. I put mine behind my seat, run a kill switch in the cab.
Old 10-10-2014, 10:09 PM   #186
ghettoluxury
ghettoluxury's Avatar
I would leave the radiator up front and use electric puller. That way you can still pop the hood and have your coolant tank at easy access. As far as the battery I think I would also mount it under the hood.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 10-11-2014, 01:36 AM   #187
47 Fasttoys
OK, all good points. If I can fit the donor radiator behind the grill I will put it up front with electric fans. Because the sheet metal and grill mounting will be custom anyway due to the frame I can incorporate a mount system for the wider radiator. For the battery I'm thinking in a box mounted to the frame. With a flat bed I should have a lot of space to work with behind the cab.
Rob
My '47 C.O.E build
Old 10-11-2014, 08:24 AM   #188
Billys68SS
Billys68SS's Avatar
Battery closer to engine and all electronics= less wiring and potential for resistance build in battery cables. :-) My .02 worth. I like the idea of the larger radiator up front with an electric fan system so it can at least get some air while cruising and less demand on the fan.
1949 GMC PU http://67-72chevytrucks.com/vboard/s...d.php?t=608120
1966 C10 http://67-72chevytrucks.com/vboard/s...06#post6601806
1966 C10 SB Custom Cab, Fleetside, BBW.
1968 Chevelle SS 396
1937 Chevrolet Coupe
Billys68SS is offline   Reply With Quote
Old 10-11-2014, 09:58 PM   #189
99 to Life
99 to Life's Avatar
I see what billy is saying and do agree, but if done right I don't foresee any problems. heck alot of drag cars have battery in back with the killswitch sticking out. Just need to run proper gauge wire. I think your build is a bit different than most of us whom aren't so fortunate to have a COE yet! You have alot more options or maybe less in some cases on where you can put stuff. I hope these next few weeks fly by. you home for good or just a break? may have missed that.
Old 10-12-2014, 02:58 AM   #190
47 Fasttoys
Thumbs up Re: Loadmaster '47 COE
Home for good, 3 years, 4 months, 15 days. It's a long time to be away with only short home visits. Its been a good adventure but I'm ready for it to end. Now it's time to enjoy some of the fruits of my labor. I've got a good start on the C.O.E. and now will have the time and a little cash to build it right. I expect to have it road worthy with a modern drive train,modern suspension, restored interior and basically a dependable daily driver/work truck in around six to eight months for around 20K. That puts me in the middle of next summer for a 2 to 3 week road trip across America. I've done this in a '31 Oakland 3 window street rod, a '69 Mercury Cougar and my '46 1/2 ton hauling a pop-up. By far some of the greatest times that can be had in this great country of ours.
Rob
My '47 C.O.E build
Old 10-12-2014, 03:08 AM   #191
47 Fasttoys
While we're on the subject of E-fans. I understand the later Silverados used E-fans. Does anyone know if the radiator is the some size on the 2003 verses the 2007 or newer Silverados? or on what year they switched?
Thanks,
Rob
My '47 C.O.E build
Old 10-12-2014, 03:54 AM   #192
47 Fasttoys
OK, so I quit being lazy, it looks like the radiator is the same from '99 to 2012 and the E-fans started in 2005 so a trip the to the junk yard should solve the E-fan issue when the time comes.
Rob
My '47 C.O.E build
Old 10-12-2014, 09:00 AM   #193
Advanced Design
Love the road trip plans for the truck! Was thinking about your build and wondering if there would be any coolant flow issues? Probably not...many vehicles have been built with radiator away from the engine.
Old 10-31-2014, 04:01 PM   #194
47 Fasttoys
I'm back!!!! Not wasting any time I just had to do something on it after the return early this morning. I did end up clipping the frame horns off right behind the round cross tube (not shown) to see how the grill was going to line up. I also had to remove the support structure from behind the grill. I'll build one that is much closer to the grill and a bit shorter. I also came to the realization I will need to raise the front of the cab about 2 inches. I just don't have enough clearance for the front tires. I will also need to swap to a smaller tire. Anyway, a few pictures. Jet lag has set in big time and I need a nap. Great to be back.
Rob
My '47 C.O.E build
Old 10-31-2014, 04:10 PM   #195
99 to Life
99 to Life's Avatar
glad to see you back on it. jet lag sux. can't wait to see some more progress.
Old 10-31-2014, 05:22 PM   #196
Advanced Design
Awesome, welcome back! Gotta be a great feeling. Looking forward to frequent and fast updates.
Old 11-01-2014, 03:53 PM   #197
47 Fasttoys
OK, so today I rebuilt the front body mounts. I ended up raising the front 1 1/2 inches to give some more tire clearance. It's fine for the inside now but I will need to change tires for the fender clearance. I tacked things in place and then removed the body to install plates on the rear and final welding. Boy, I really need to figure out how to set this camera up.
Rob
My '47 C.O.E build
Old 11-01-2014, 11:57 PM   #198
99 to Life
99 to Life's Avatar
glad to see some progress, looks good. are you using a camera or a cell phone?
Old 11-02-2014, 11:28 AM   #199
47 Fasttoys
So, for this morning I shortened the brake line, it was originally mounted to the frame piece I removed. I also remounted the cab and just for kicks pulled the tube which was used to set ride height and dropped it down to see how low it could go. This view is against the bump stop with a tall tire. For sure I could drop it to the bumper with some minor mods. I also installed the drive shaft (just the rear). It looks like it will work good. This is what happens when you wake up at 3:00 due to big time changes. Oh, and I think I got the camera thing figured out, date is still off.
Rob
My '47 C.O.E build
Old 11-02-2014, 12:42 PM   #200
401ton
Thanks for posting pics, but especially thanks for fixing the camera thing!
401ton is offline   Reply With Quote
