Old 08-28-2014, 10:31 PM   #176
Denee007
Denee007's Avatar
Re: Project "Schrum" 1959 Gmc 100
Well, if you pull on the choke knob, it should pull the little lever which closes the choke plate inside the carburetor, thus "choking" to bring more gas on a cold start, and visa versa. Pull the air cleaner off, have someone work the choke and you see what's actually going on under the hood. It's quite a simple thing. You might check for vacuum leaks. I can imagine the single barrel carburetor might need attention; though simple, sure can make for some running problems.
I did watch the video I had a similar problem with the 6 cylinder that was in my truck from the start. I got it to run, but ran crappy. Now I have a nice running sbc.
Keep analyzing, you'll get there!
dne'
Originally Posted by SCHRUMGMC View Post
How do I know if its a bad choke cable?
I've driven it occasionally, it dies when I push the choke in, watch the video and you'll see what happens to it
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 08-28-2014, 10:48 PM   #177
SCHRUMGMC
SCHRUMGMC's Avatar
Thanks Denee, that is what I thought with the choke
The carburetor has been rebuilt. it squirts gas out the shaft thing
I put new tail light housings on the truck, just wondering how I can wire it up
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 08-28-2014, 10:49 PM   #178
BlackedOut67shorty
BlackedOut67shorty's Avatar
It is hard to tell how it is running from the video. If its manual choke go to the carb and open it up all the way as if it was all warmed up, my 67 c10 had a bad stumble to it cause my choke cable was still engauged even tho i took it off choke making my truck run on fast idle and then shutting off when i gave it the beans. Also have you checked for any vacuum leaks, should be too many places to leak from on an inline.
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 08-28-2014, 11:22 PM   #179
Denee007
Denee007's Avatar
well, take a close look at your carburetor, shouldn't be squirting gas out, not to mention a potential fire hazard! EEk!
As for you tail lights~ is there existing wiring where the lights would go? Do you have a test light? You may want to buy one and have it on hand for checking wiring to see if particular wires are Hot, or not. You may have to start at the fuse box, trace wires under the truck, check for cut wires, bad connections, etc..
dne'
Old 08-29-2014, 12:04 AM   #180
SCHRUMGMC
SCHRUMGMC's Avatar
What can I use to connect the new wires? I have a female connector that out go on the wire to connect to the prongs. I'd like to get the dome light, and tail lights/turn signals working
1971 GMC Sierra
1959 GMC 100
Old 08-29-2014, 10:18 AM   #181
BlackedOut67shorty
There should already be a harness for it, if its gone just got to a pick and pull to get another pigtail and solder your wires to the pigtail and plug em in
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 08-29-2014, 12:30 PM   #182
SCHRUMGMC
SCHRUMGMC's Avatar
Do I just use the generator wiring and put connectors on them?
Where can I get brackets at? Can I use one off of another I6?
1971 GMC Sierra
1959 GMC 100
Old 08-29-2014, 06:09 PM   #183
BlackedOut67shorty
I just got confused
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 08-29-2014, 06:19 PM   #184
SCHRUMGMC
SCHRUMGMC's Avatar
I use the Generator wiring for the alternator right?
Tried getting an alternator bracket off for my truck today at a local junkyard and couldn't get it off so I gave up on it. Looks like I will have to buy a new bracket set
The truck I tried getting it off of
Its a 71 Chevy with an I6
1971 GMC Sierra
1959 GMC 100
Old 08-29-2014, 08:34 PM   #185
Rita
Rita's Avatar
LOL - looks like my "Rita" is ahead of you "grandfather" - keep up the good work :-)
Henrik Franck Stampe
Denmark
GMC 100 S V8 1959 AKA: Rita
VW T4 2.4 D 1984 AKA: Hulk
Ford Focus estate 1.6 TDCI 2010 AKA: Snow White
Rita is offline   Reply With Quote
Old 08-29-2014, 08:50 PM   #186
lowrodderchev
lowrodderchev's Avatar
does it look like this?
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 08-29-2014, 09:10 PM   #187
SCHRUMGMC
SCHRUMGMC's Avatar
Yeah, it'll get there. For some reason it keeps dying when I push the choke in
Attachment 1295469
I have no clue Lowrodder, I know that I will have to get new brackets. That looks to be a V8 one
1971 GMC Sierra
1959 GMC 100
Old 08-29-2014, 09:43 PM   #188
lowrodderchev
that's the one I'm using on my 6 cylinder with a arm to adjust it bolts to the drivers side of the motor
Old 08-29-2014, 09:46 PM   #189
SCHRUMGMC
SCHRUMGMC's Avatar
Does anyone have a clue how to install the transmission cover?
Mine doesn't have the hole where the gas pedal goes on
1971 GMC Sierra
1959 GMC 100
Old 09-01-2014, 12:46 AM   #190
SCHRUMGMC
SCHRUMGMC's Avatar
Got the Horn cap polished up
1971 GMC Sierra
1959 GMC 100
Old 09-01-2014, 10:43 AM   #191
Kim57
Kim57's Avatar
Nice and shiny.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-02-2014, 02:28 PM   #192
SCHRUMGMC
SCHRUMGMC's Avatar
I have a Mouse problem in the truck damn things are everywhere in it. The bench seat has a nest in it. To top it off the Distributor is behaving erratic and all over the place. Thank God I have a backup distributor if it is worn out
1971 GMC Sierra
1959 GMC 100
Old 09-02-2014, 07:34 PM   #193
OrrieG
OrrieG's Avatar
See you are back at it, here are some comments.
1. Choke issue. Usually when it runs fine with choke closed but dies when you open the choke it is a vacuum leak. The additional air from the leak leans it out so it will not run. High idle with choke on disquises the problem. Get a vacuum gauge and hook it up you will find it is low and bouncing all over the place. Take starter fluid and spray around the manifold base, carb shaft, vac advance fittings, if the engine raises the rpm you have found the leak. If it is reading 16-18 on the vac gauge they it is another problem.
2. Tail light wiring. Since you are starting from scratch I would recommend using a trailer connector to connect the tail, turn and future back up lights to the front harness. Bonus is when you pull the bed you are just unplugging one thing. Just solder the connectors, cover with shrink wrap and you are good to go. I used them for my front turn signal grille, dash bezel and in the back too.
3. Generator to alternator swap: http://67-72chevytrucks.com/vboard/s...d.php?t=526547
4. Post a pic of the trans cover, don’t understand the throttle question. Sounds like it was changed out at some point.
And hello to D’ne good to see you back.
OrrieG is offline   Reply With Quote
Old 09-02-2014, 08:04 PM   #194
SCHRUMGMC
SCHRUMGMC's Avatar
The Transmission cover came out of a V8 so it won't fit the I6 area it is different. The Distributor is behaving weird, it shoots around to the retarded timing area when I try to set it. Thanks for the Link
1971 GMC Sierra
1959 GMC 100
Old 09-03-2014, 06:03 PM   #195
SCHRUMGMC
SCHRUMGMC's Avatar
I believe my Distributor is broken now due to it moving around erratically like its doing. It is moving around to the Retarded timing area. Its tightened down as it can get, it just started doing thing and I'm unsure of how and why its doing what it is doing
1971 GMC Sierra
1959 GMC 100
Old 09-03-2014, 06:40 PM   #196
lowrodderchev
Dumb question but your vacuum advance is tighten down to
Old 09-03-2014, 06:52 PM   #197
SCHRUMGMC
SCHRUMGMC's Avatar
Huh? I haven't messed with the Vacuum advance
1971 GMC Sierra
1959 GMC 100
Old 09-03-2014, 07:43 PM   #198
_Ogre
_Ogre's Avatar
trans cover is the same for v8 or i6 in chevy, gmc is probably the same
some have the 4 speed hole in them
gas pedal pivot goes thru the fire wall
if your distributor is flopping around, fix it
as lowrodder mention: the vac advance should be firmly attached to the distributor
also make sure the clamp is holding the distributor to the block
shop air compressor timer
Old 09-03-2014, 07:59 PM   #199
SCHRUMGMC
SCHRUMGMC's Avatar
If its the same then mine doesn't line up the holes correctly. On one side it doesn't lay flat and there is no place to put the Gas pedal on the transmission cover. Could it be the Distributor is bad, because I haven't loosened it up and its tight as it can get
1971 GMC Sierra
1959 GMC 100
Old 09-03-2014, 08:37 PM   #200
lynx5653
lynx5653's Avatar
Take it to a mechanic
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline   Reply With Quote
