Old 07-19-2016, 08:10 PM   #176
6t9camaro
6t9camaro's Avatar
Re: 67 C10 "Green Gobblin" straight from the field!
I started digging into the front suspension to see what the heck I'm going to do to slam this thing!?! But first I had to fit up my 15x8 steelies to see if its going to have the clearance i need before i order up a disc brake and drop spindle kit! Then I took out the springs and dropped it onto the bump stops to see how it's going to look but obviously thats just not low enough!!! Im thinking its time to put the frame aside for awhile until i decide what I'm going to do with it. (last pic is the front wheels)
6t9camaro is offline   Reply With Quote
Old 07-22-2016, 08:42 PM   #177
6t9camaro
6t9camaro's Avatar
I finally started on the box! I will start off with a few pics from this winter where it sat and i scraped out all the rust and $hit so you can see what I'm working with! Its a rough longbox but actually pretty solid for what i want to do with it. (chop it up) The floor is solid but beat up and theres some damage and old repair work in the drivers side that I've got to figure out a fix for?
Old 07-22-2016, 08:50 PM   #178
6t9camaro
6t9camaro's Avatar
Now to present time, All scraped out and pulled into the garage to assess damage and start teardown.
Old 07-22-2016, 08:58 PM   #179
6t9camaro
6t9camaro's Avatar
Oh I can't forget the awesome channels welded to the rear and the old welds everywhere!!!
Old 07-24-2016, 05:57 PM   #180
6t9camaro
6t9camaro's Avatar
I Finally got the box apart and i think it actually looks better in pieces than it did together! I really tried to save all the rusty bolts to reuse but after messing around for way to long I started cutting,welding and drilling them out! Im happy with the box floor as its not as bad as i thought.
Build
67 Green Gobblin
http://67-72chevytrucks.com/vboard/s...d.php?t=688755
Old 07-24-2016, 05:59 PM   #181
6t9camaro
6t9camaro's Avatar
Few more
Build
67 Green Gobblin
Old 07-25-2016, 02:38 PM   #182
68Gold/white
Bed floor doesn't look bad at all!!!
68Gold/white is offline   Reply With Quote
Old 07-29-2016, 03:57 PM   #183
6t9camaro
6t9camaro's Avatar
Ok first up is chop down and shorten the passenger bedside! Ive seen a lot of different ways to shorten box sides but nothing really stood out to me since i didn't want to just chop the whole backside or frontside off. The front cut i kept close to the edge to eliminate warping and save as much original paint as possible. That should help with my paint blending later! I did make it complicated for myself though as i staggered the cut on the outside vs the inside box. I used tape to keep my lines paralell and it was also an aid for the measurements.
Build
67 Green Gobblin
Old 07-29-2016, 04:02 PM   #184
6t9camaro
6t9camaro's Avatar
No turning back now!!!!
Build
67 Green Gobblin
Old 07-29-2016, 04:04 PM   #185
6t9camaro
6t9camaro's Avatar
12" removed!
Build
67 Green Gobblin
Old 07-29-2016, 04:10 PM   #186
6t9camaro
6t9camaro's Avatar
Now to put it back together.
Build
67 Green Gobblin
Old 07-29-2016, 04:14 PM   #187
6t9camaro
6t9camaro's Avatar
A few more!
Build
67 Green Gobblin
Old 07-29-2016, 04:39 PM   #188
MMcMasters
MMcMasters's Avatar
Very nice work!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 07-29-2016, 04:40 PM   #189
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice work!
ChuckDriver is offline   Reply With Quote
Old 07-29-2016, 10:23 PM   #190
tommys72
tommys72's Avatar
Nice!
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 07-29-2016, 11:30 PM   #191
6t9camaro
6t9camaro's Avatar
Thanks guys! Heres some pics on how i finished the rear section up.
Build
67 Green Gobblin
Old 07-29-2016, 11:35 PM   #192
6t9camaro
6t9camaro's Avatar
I had to remove the old welded in channel so i can get a tailgate on this thing one day! And pics of it going back together.
Build
67 Green Gobblin
Old 07-29-2016, 11:38 PM   #193
6t9camaro
6t9camaro's Avatar
lower section was tricky to keep the contour and the sloping body line lighted up.
Build
67 Green Gobblin
Old 07-29-2016, 11:42 PM   #194
6t9camaro
6t9camaro's Avatar
And thats it! This is what 20" cut out of the box side looks like and i now have one short box side!
Build
67 Green Gobblin
Old 07-30-2016, 10:51 PM   #195
GAc10boy
GAc10boy's Avatar
Beautiful work!
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 07-30-2016, 11:51 PM   #196
swamp rat
swamp rat's Avatar
Per the last picture on this post, my bed had the same weld and one where the bottom of the farmer built channel meets the floor on the stake pocket.. Pretty cool plywood tailgate idea huh?
I just don't get it, your cutting and welding up a storm and i see no warpage, if i worked at that pace my bed would be scrap!
Nice work indeed!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-31-2016, 09:20 AM   #197
Bennett68C10
Bennett68C10's Avatar
Wow, great job on those bedsides! You do awesome work!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 07-31-2016, 10:57 AM   #198
knomadd
knomadd's Avatar
Nice job on the bed side.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 07-31-2016, 04:24 PM   #199
67ChevyRedneck
67ChevyRedneck's Avatar
I don't post much in the build section anymore, mostly because there's so many, and I just don't have time to follow along anymore... but I couldn't resist with this one. Read every post so far. Love it and keep it up
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-31-2016, 04:38 PM   #200
jlsanborn
jlsanborn's Avatar
Well done!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
