Old 06-25-2017, 09:10 PM   #176
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: What did you do to your truck today part IV
forestb if you can get away with it I think it's awesome.
Old 06-25-2017, 10:23 PM   #177
forestb
forestb's Avatar
I also was able to drive the truck for the first time on the freeway with the new 700r4. Vary happy 😊
forestb is offline   Reply With Quote
Old 06-26-2017, 11:12 AM   #178
Northwest Outlaw
Northwest Outlaw's Avatar
Finally got the engine back together with the new camshaft kit from CompCams. Nothing wild, just a replacement for the worn out one that left me stranded last month.
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline   Reply With Quote
Old 06-28-2017, 03:56 PM   #179
Northwest Outlaw
http://67-72chevytrucks.com/vboard/s...4&postcount=90
^installed new cam kit
SHE'S ALIVE!!! https://youtu.be/26ZDzVYPUbw
After realizing i put the dizzy in backwards again, did the same thing for the first engine start up, she fired right up. We ran her through the COMPCams break-in procedure with only one hiccup. I hadn't fully tightened the distributor after spinning it around and it walked the timing way back to where it was backfiring real bad. I tighten it back down in the right spot and ran her 25 min between 2000-3000rpm, varying ever few minutes.
Old 06-28-2017, 04:28 PM   #180
jbgroby
jbgroby's Avatar
Installed the Sissy Box under the dash.......
jbgroby is offline   Reply With Quote
Old 06-28-2017, 08:28 PM   #181
vetnat
Ooh! I want me one of those! Did I mention, I am female Seriously, I have not seen such a thing. Is it a factory Kleenex box? My mother has this obsession with always having tissues available, that would be just the ticket. Where did you get it?
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline   Reply With Quote
Old 06-29-2017, 08:18 AM   #182
jbgroby
jbgroby's Avatar
This is a quick search on eBay, where I found mind. if you have a Chevy, they have them with the proper badges, but nothing technical correct for GMC, so I found a generic one with no badging. The make a few styles, you need to look for a "swing out" type, they make a pull out type but it would mount to the underside of our dashes.
http://www.ebay.com/itm/VINTAGE-ORIG...VZKkNb&vxp=mtr
http://www.ebay.com/itm/Vintage-Klee...FY2s-n&vxp=mtr
https://www.ebay.com/sch/i.html?_odk...enser&_sacat=0
Use this search string terms "vintage 195* tissue dispenser"
Old 06-29-2017, 10:38 AM   #183
sirJim
Got the engine in last night.
sirJim is offline   Reply With Quote
Old 07-03-2017, 10:07 PM   #184
rvrfoot
Installed a cup holder.Name:  DSCN0892.jpg
rvrfoot is offline   Reply With Quote
Old 07-04-2017, 12:18 PM   #185
rvrfoot
lacquer the wood boardsName:  DSCN0896.jpg
Old 07-04-2017, 01:01 PM   #186
AngryPirate
AngryPirate's Avatar
Originally Posted by rvrfoot View Post
Ha! You're doing exactly the same thing I am doing this week.
I got my wood from Mar-K and it's Pecan.
It takes forever though, staining it with the spar... thinning down the first few coats and then putting pull strength coats on, each side.
It's been taking at least 12 hours for each coat to dry (the thinned coats are drying faster, of course).
AngryPirate is offline   Reply With Quote
Old 07-04-2017, 01:03 PM   #187
Backpayne
I replaced the rockers on my pickup. They turned out good, but I'm glad I don't have to do that again!
Backpayne is offline   Reply With Quote
Old 07-08-2017, 11:30 AM   #188
herb1
Replaced the master cylinder after 2 years of pumping brakes.
Flushed and bleed them 2 days ago with fresh BF and then replaced MC this morning. Stops awesome now!
herb1 is offline   Reply With Quote
Old 07-09-2017, 12:59 AM   #189
2bo.c10
replaced the mechanical fuel pump with an electronic one....because I thought I needed a new fuel pump. Turns out, I was just out of gas. Didnt realize how much gas would evaporate from not driving it for 2 months.
2bo.c10 is offline   Reply With Quote
Old 07-09-2017, 03:10 AM   #190
graymage
graymage's Avatar
thats funny!!! glad I am not the only one
graymage is offline   Reply With Quote
Old 07-09-2017, 10:30 AM   #191
rvrfoot
Installed the aluminum radiator.Name:  DSCN0894.jpg
Old 07-09-2017, 03:36 PM   #192
rvrfoot
I picked up my vent windows and a side window.I will test fit them and se how it goes.Name:  DSCN0901.jpg
Old 07-16-2017, 09:09 PM   #193
Blue666(2)
I patched up the extra holes in my high and installed it. Used rivnuts to so it can be removed as needed.
Blue666(2) is offline   Reply With Quote
Old 07-16-2017, 09:37 PM   #194
forestb
forestb's Avatar
I replace my wiper blaids with a set of 12" Champion blades. I hade to buy a hole assembly and take it apart to use only the rubber. I hade to do a little cutting to make them slide in but they look like they will work well.
I also used a d-ring to lock my column shirt linkage in park (as a society measure). With the hood locked you can't take the truck out of park. I am also trying to figure out a way to lock my steering column inside the engine compartment.
Old 07-16-2017, 09:50 PM   #195
rvrfoot
I was told to drill a hole in the shaft than put a bar in it.When you turn it it will hit the inter fender.
Old 07-16-2017, 09:52 PM   #196
rvrfoot
I put the wood in my bed.Name:  DSCN0911.jpg
Old 07-16-2017, 09:53 PM   #197
rvrfoot
Old 07-16-2017, 09:58 PM   #198
forestb
forestb's Avatar
Fortunately I have a steering knuckle on my column so I don't have to drill a hole.
Old 07-16-2017, 10:08 PM   #199
AngryPirate
Ha! I think rvrfoot and I are on the same schedule.
I just got my wood installed this week/weekend myself.
Old 07-17-2017, 06:45 PM   #200
rvrfoot
I got a new back window had it tinted.Installed it and new seal.Name:  DSCN0893.jpg
