03-08-2021, 06:33 PM | #176 |
Re: The build date project
I realized I gave my VIN and, date but, no door jamb decal. Here's what's left of my door jamb decal confirming Zooey was a Janesville truck born in December of 69.
03-09-2021, 10:43 AM | #177 | ||
Let's use "engines" as an example (since I already have this written up): Quote:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-09-2021 at 10:56 AM. |
03-09-2021, 10:48 AM | #178 |
The operator looks at the build sheet in the appropriate box and sees he needs a "TAF".
He then walks over to this display of various racks, sorted by engine type, chooses a "TAF", and hangs it on the line. Another reason for the broadcast code (also known as a "pick code") is that the part numbers themselves are so nuanced. Can you imagine if he really wanted a part number 12345678 but incorrectly picked a 12345478? It could be catastrophic. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-09-2021 at 10:53 AM. |
03-09-2021, 11:01 AM | #179 |
This scenario plays out in a dozen different areas of the assembly plant, any place where there is proliferation within the RPO:
Transmissions (manual vs auto, low gear ratio, HD vs LD, etc) Seats (based on color, trim level, vinyl, leather, extra padding, etc) Axles (2wd vs 4wd, locking vs non, ratio, HD brakes, etc) Tire/wheel (rim type, tire type - front, rear, spare or no spare) Body shop (body style, high tunnel, low tunnel, bed length) Paint (color, ZY1 single color, ZY3/4/5/6 two tones) Radiators (size, auto vs manual, HD vs LD) etc. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-09-2021, 11:50 AM | #180 | |
03-09-2021, 01:19 PM | #181 |
72 chevy
2/72 2Z144229 And 71 Chevy 2/10/71 1Z628194 And 70 chevy 1/70 0B132792 And '69 Chevy 12/07/68 9Z834654 Last edited by 402Bowtie; 03-11-2021 at 07:04 PM. |
03-13-2021, 02:35 PM | #182 |
I'm trying....
1970 Chevrolet
Fremont 0Z170363=6/70
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
03-13-2021, 05:22 PM | #183 |
71 chevy
1S667955 6/71 And 72 chevy 2Z131939 1/72 70 chevy Blazer, reproduction sticker. If correct, it suggests St Louis slowed down production in the spring of '70. S159628 3/70 71 GMC S128680 4/71 70 chevy found here 0Z138502 1/20/70 Last edited by 402Bowtie; 03-18-2021 at 12:05 PM. |
03-13-2021, 08:00 PM | #184 |
All about them K’s
Awesome work guys. I’ll get the updates added soon.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
03-18-2021, 12:14 PM | #185 |
Two 69 chevy's from the same day
9Z833750 12/05/68 9Z833902 -- This one on the list already, but not sure we had a picture previously? 12/05/68 72 chevy 2F349324 2/72 72 chevy (from post #1034 here) 2Z108075 9/22/71 69 chevy 9Z895406 7/18/69 Last edited by 402Bowtie; 03-18-2021 at 08:39 PM. |
03-18-2021, 11:48 PM | #186 |
71 chevy
1S655506 4/71 72 GMC 2A507337 4/72 72 GMC 2S504575 10/71 72 chevy 2B163197 5/22/72 Last edited by 402Bowtie; 03-20-2021 at 08:45 PM. |
03-19-2021, 07:22 PM | #187 |
Ok so I don't have a build sheet in my truck (don't know if the bench seat is original to the truck or not) and I don't' have the little blue sticker but I am hoping that if enough numbers come in I'll be able to get a close guesstimate on when my truck rolled off the assembly line. the partial vin would be 9T800240, all I know is that it is a 1969 c10 that was built in Tarrytown NY and I believe it spent most of it's life in Pennsylvania before I got a hold of it.
03-19-2021, 07:27 PM | #188 | |
03-19-2021, 07:34 PM | #189 | |
All about them K’s
John, I’ll get the additions added this weekend. Thanks again!
03-20-2021, 12:15 AM | #190 |
thank you guys, I know the truck was a base model truck. the only things I could decipher on the spid were full foam bench seat, green vinyl, spare tire, add a leaf springs, and I think a passenger mirror, the truck also doesn't have a delete plate so I'm guessing it had an am radio from the factory, other than that it was a pretty stock medium olive long fleet with a white top, 307, saginaw 3 speed, and open rear end. I don't know much about the previous life of the truck but I figure if I can find more out about it then maybe I can track down more info on what she did all the years before I bought her and started my on going rustoration project
03-21-2021, 11:42 PM | #191 |
All about them K’s
My list is Up to date. Thanks guys!
03-22-2021, 05:34 PM | #192 |
72 chevy - reproduction sticker, but appears to be correct date.
2F349494 2/72 70 chevy 0J131476 1/16/70 Last edited by 402Bowtie; 03-26-2021 at 03:24 PM. |
03-22-2021, 07:01 PM | #193 |
All about them K’s
John, sorry I meant to answer your question about the second entry in post 185. We got that entry in one of the PMs it looks like to me. There was basically a list that a member took from the spid picture thread, door sticker thread and other similar threads. I bet I probably have a picture of it in my PM’s and forgot to attach it. If you guys see things like this please feel free to point it out and I’ll get an explanation. Also I believe I fixed the issue you messaged me over.
03-22-2021, 11:52 PM | #194 |
Here's a '69 Jocko posted on the Craigslist Finds thread.
https://67-72chevytrucks.com/vboard/...9&goto=newpost The date on the build sheet appears to be 7-18-69, but could be 7-15-69. VIN is CE249Z895406
Jim Last edited by FirstOwner69; 03-22-2021 at 11:59 PM. |
03-23-2021, 12:00 AM | #195 |
Just saw that and was trying to delete my post.
Jim |
03-27-2021, 01:06 AM | #196 |
72 chevy...Currently the last Fremont truck on our list.
2Z179866 6/72 72 chevy 2Z177161 Pretty certain it reads "6/72" 72 chevy 2A107594 9/71 71 GMC F117182 pre-4/7/71 Not sure if you want to include this one, but thought this added value since we don't have any other '71 Flint GMCs. 71 GMC Z113756 xx-30-70 ...The month should become clear when we get a few more 71 Fremont GMCs. On a side note, all 71 Fremont GMCs on the list should start with a "Z," not a "1." Also, is there a typo on Z115305's date? Guessing that should be 10/21/70. Last edited by 402Bowtie; 03-30-2021 at 08:43 AM. |
03-28-2021, 12:30 AM | #197 |
This build sheet for a 1970 was just posted here: https://67-72chevytrucks.com/vboard/...d.php?t=820056
Build sheet date: 06-02-70 VIN: CE240B161933
Jim |
03-29-2021, 08:38 PM | #198 |
67 chevy
7Z124195 12/14/66 70 chevy Blazer 0S175768 06/70 70 chevy 0S103526 pre-10/3/69 Again, thought this added a little value, but feel free to discard. 71 chevy 1B638453 4/71 Last edited by 402Bowtie; 04-03-2021 at 09:04 AM. |
03-29-2021, 11:14 PM | #199 |
How did I get this OLD!
Wouldn’t 12/14/67 be a 68? Or was it to be 12/14/66?
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
03-29-2021, 11:31 PM | #200 |
Oops. That should be December 1966. The 7Z refers to 67 model year. I'll update it. Thanks for catching that.
70 GMC ZZ65282 5/70 72 chevy 2F368734 5/72 Last edited by 402Bowtie; 07-16-2021 at 08:39 PM. |
