10-14-2011, 01:41 AM | #1976 |
Lucky Teter at the wheel
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Puzzle pieces.
I can't believe I just drilled a hole in my gas tank. I can fix it with A-N bulkhead fitting with a hose barb attachment. Bolted up the reshaped 72 Suburban fuel filler neck. Ran out of time before I could hook up the hoses.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
10-14-2011, 02:02 AM | #1977 | |
VA72C10
Good progress! Getting closer
Looking for a 67-72 swb or blazer project in or around VA. |
10-14-2011, 02:09 AM | #1978 |
Details, Details... Drew every part you add just seems like it was suppose to be there. Keep up the work.
71 Ol' Blue: http://67-72chevytrucks.com/vboard/s...d.php?t=474752 Carving the Jake-olantern: http://67-72chevytrucks.com/vboard/s...d.php?t=679537 |
10-14-2011, 02:21 AM | #1979 |
Junk Yartist
Drew, do you think the OE fuel cap will cause a service engine soon light?
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
10-14-2011, 09:16 AM | #1980 |
I'll need a 72 SEALED cap, or tune it out when I get my cat delete tune on the computer.
10-14-2011, 03:22 PM | #1981 |
6>8 Plugless........
Looking good. I think your suspension travel should be ok. It's not like you plan on driving this thing through fields or anything.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
10-14-2011, 03:38 PM | #1982 | |
"Oh well, it's a driver."
Wait...you mean you're NOT planning to use this as a hay-hauler??
- JB - '93 C1500 SHORT/FLEET SILVERADO, 350/4L60E Quote:
10-16-2011, 12:47 AM | #1983 |
Saturday night picture time.
I spent a while cleaning up the shop and reading the latest Hot Rod magazine, but I did get the fuel filler hoses hooked up finally. (I had to take out the inlet and cut it shorter which meant I had to weld another reducer on to fit the larger new hose) - wasting time. Then I moved on to fabbing up these crazy little brackets to attach to the axle to attach the ride height sensors to. I'm walking back out to paint them black so they will be dry to put on Sunday.
10-16-2011, 01:04 AM | #1984 |
is the hose rubbing on the cab sheet metal?
10-16-2011, 01:08 AM | #1985 |
Nope, I bent the edge over so if it ever did hit it would only be rubbing on a curved sheetmetal surface. And I put the hose clamp strategically so the clamp would actually hit first.
10-16-2011, 06:24 PM | #1986 |
I finished up the sensor mounting today and here are the pics.
I still need to weld the shock mounts to the axle tubes, install the e-brake cables, rotors, and calipers. All that can be done from underneath, so I may try to throw the bed on soon. Where's Igor and his buddies???
10-16-2011, 07:51 PM | #1987 |
VA72C10
Looks clean for all that's going on there. Nice work!
10-16-2011, 08:11 PM | #1988 |
Moderator
It looks factory!
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
10-17-2011, 01:44 AM | #1989 |
Just a little sumpin sumpin.
This is just with a battery sitting on the ground so I can troubleshoot it before I get too far. My rear air lines are crossed for one thing, but hey, 2 days ago I had no suspension.
10-17-2011, 01:59 AM | #1990 |
Ooooo so saweett!!!!
Eric "Target" Sherwood Professional Bullfighter For Hire God Bless and Gods Speed! TheCowBoyProtectionUnit@yahoo.com http://www.facebook.com/pages/Eric-T...59496227444241 |
10-17-2011, 01:59 AM | #1991 |
VA72C10
Nice!!!! Seems to have a decent amount of travel. Not as much as I've seen on some but probably plenty for a smooth ride and you're not laid out like some guys who have to raise it 6-7" just to be able to turn their tires
10-17-2011, 02:12 AM | #1992 |
Nice...I think it will be just right.
10-17-2011, 08:51 AM | #1993 |
Still Learning
Nice work on the fuel filler and the suspension! Thanks for sharing the pictures and video.
10-17-2011, 09:47 AM | #1994 |
67cheby
sweet....cant wait to do mine
10-17-2011, 10:02 AM | #1995 |
Like it very much...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
10-17-2011, 10:39 AM | #1996 |
Very awesome! This is an incredible build!
Posted via Mobile Device |
10-17-2011, 11:38 AM | #1997 |
Is it me or is that hose laying on a sharp edge? I can't tell what that is, but it just looks like it might not last. Other then that, this thing is looking sharp!
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350. http://www.facebook.com/#/profile.ph...&id=1116781152 |
10-17-2011, 11:55 AM | #1998 |
67cheby
someone else already asked the same thing, if you look close you can see he has rolled the edge over
10-17-2011, 11:59 AM | #1999 |
it may just be me, but id still slit some rubber hose and cover the edge just to make sure. even though it does look like theres a good roll on the edge. just my .02
10-17-2011, 01:27 PM | #2000 |
I'm with you on that one. A little security never hurts.
