Old 10-05-2018, 02:41 AM   #2001
DransportGarage
DransportGarage's Avatar
Re: What did you do with your truck today, Part 3
Originally Posted by MARTINSR View Post
Again, not much, but something! Got the rusted area cut out of the R fender, got the template made, marked out on the metal, ready to cut out tomorrow.
Brian
You've done this before!
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 10-05-2018, 03:40 AM   #2002
MiraclePieCo
MiraclePieCo's Avatar
Brian
That's a complex shape; what did you use to cut it out that left the original metal pattern intact?
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 10-05-2018, 07:21 AM   #2003
DransportGarage
I'd just whack in there with a 3" wheel, then round it out with a carbide bit, but that's me. That one looks like it's lazer-cut!
Bob
Old 10-05-2018, 10:09 AM   #2004
MARTINSR
MARTINSR's Avatar
A "nibbler" had it for years, use it rarely, but when I need it, it's there! These are the exact ones I have. They are not cheap, but I believe in using quality tools so it's less work on my body. Don't get me wrong, I have a few cheap ones but something like these, I want the best. And they don't disappoint. I bought an extra pair of tips and have never used them, the original ones have held up over the years.
https://www.speedwaymotors.com/Sheet...bler,2910.html
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 10-05-2018, 10:10 AM   #2005
MARTINSR
MARTINSR's Avatar
It's funny you should say that, I would have grabbed my cut off wheel too but it was late and I didn't want to make noise to bother the neighbor.
I just drilled a hole and then snipped it out. But after doing that, I REALLY need to get these out more as it's much cleaner and safer than using the cut off disc. There is NO WAY you can get those tight corners with a cut off disc leaving it anywhere near this clean.
Now I did clean up the corners a little bit with a "rotory file" but not much, I didn't really need to, I'm just anal sometimes.
Brian
1948 Chevy pickup
Old 10-05-2018, 10:37 AM   #2006
MARTINSR
MARTINSR's Avatar
I got out there late after a very odd thing, I went to a rally at my daughters high school, wow what a bunch of great kids! HUGE party with everyone cheering everyone else, very cool. Well, right near the end a kid slipped out on the hardwood floor flipping onto his head and was hurt bad, looking maybe even much worse (news sounds pretty good) so the whole place was emptied (MANY hundreds of parents and kids) with an ambulance coming in. So leaving there and coming home was pretty funky.
Brian
1948 Chevy pickup
Old 10-05-2018, 11:03 AM   #2007
DransportGarage
Brian
Great tips, great tool!
Bob
Old 10-05-2018, 02:52 PM   #2008
mikebte
Took the day off to complete some stuff around the house, some how I ended up working on the truck.
Finally got the engine running great and starting great, only took adding and repairing some wires. Finished the small details on the braking system. Finally and most importantly, my wife was finally able to take a drive in her grandfathers old truck for the 1st time. Well worth the time and effort put into the truck.
Now only to finish up everything else.
Last edited by mikebte; 10-05-2018 at 02:54 PM. Reason: Brake and break are not the same
mikebte is offline   Reply With Quote
Old 10-05-2018, 09:12 PM   #2009
DransportGarage
Things were going too smoothly, so I decided to spend the last few days figuring out how to screw up the paint job by putting a ghost checkered flag on the firewall. This is the MASK ONLY. I've also prepared a few test panels so I can practice since I've never done anything like this. (I did spend an hour with a buddy in the business and he painted a flag on a panel and showed me some tips, and there's stuff on You Tube, of course.)
Bob
Old 10-06-2018, 12:04 AM   #2010
MARTINSR
MARTINSR's Avatar
AWSOME!
Brian
1948 Chevy pickup
Old 10-06-2018, 12:04 AM   #2011
MARTINSR
MARTINSR's Avatar
I got the patch made and tacked into place. WHOO HOOOO! And yes the gap is a bit large here and there, I will plannish that smaller before I finish welding.
Brian
1948 Chevy pickup
Old 10-06-2018, 01:32 AM   #2012
mikebte
Flags turned out pretty cool.
Brian
That’s some nice patch work.
Old 10-06-2018, 01:46 AM   #2013
MiraclePieCo
Monumental!
Brian
Cool. Rounded edges are much easier to weld without burning away than sharp corners.
Old 10-06-2018, 10:41 AM   #2014
evilokc
its good to see everyone making progress. flag does look cool.
evilokc is offline   Reply With Quote
Old 10-06-2018, 01:56 PM   #2015
MARTINSR
MARTINSR's Avatar
Monumental!
And much less susceptible to cracking than at those corners too.
Brian
1948 Chevy pickup
Old 10-06-2018, 06:55 PM   #2016
mikebte
Welded in the motor mounts and removed the bolt, I always had commitment issues.
Installed the exhaust wrap and it made a noticeable difference on cabin noise and finish wiring on the interior lighting.
Old 10-06-2018, 09:16 PM   #2017
MARTINSR
MARTINSR's Avatar
Got the front patch on the RR fender all welded in, then cut out the old fuel door recess, made the patch and welded the new one in. Got some weld through primer on the front so I can weld that support in I made a few days ago and this fender will be ready tomorrow for striping and priming.
It's so funny, I made the recess for the fuel door and made the fuel door customizing the truck 38 years ago to now cutting it out to make it the way it was, funny stuff.
Brian
1948 Chevy pickup
Old 10-06-2018, 09:24 PM   #2018
MARTINSR
MARTINSR's Avatar
I also noticed the tail lamp hole I filled 35 years ago. LOL
Brian
1948 Chevy pickup
Old 10-06-2018, 10:19 PM   #2019
DransportGarage
Brian
Very nice work. Did you use an English wheel to put the curve in the patch, or a bag and hammer, or something else?
Bob
Old 10-06-2018, 11:08 PM   #2020
MARTINSR
MARTINSR's Avatar
Bent it over a wooden bench in the garage. I did simply plannish it with a round headed hammer on a large "dolly" I have on my bunch.
Brian
1948 Chevy pickup
Old 10-07-2018, 03:15 PM   #2021
MARTINSR
MARTINSR's Avatar
Started out Sunday morning getting a little done on the truck. I welded in the reinforcement on the RR fender so it's finished now ready for stripping and primer.
Got the lower grille apron all finished up, welded in the piece that had been cut out on the top. I decided to do it like Chevy would have and just plug weld the piece on the top and not butt weld it and finish it off like it never was cut out. I also repaired the bracket where it bolts to the rad support. So this part is finished up ready for stripping and primer too.
Brian
1948 Chevy pickup
Old 10-07-2018, 05:05 PM   #2022
Black_Sheep
Black_Sheep's Avatar
I managed to sneak in another shakedown cruise. 30 miles this time, no issues.
https://www.facebook.com/mark.wells....4459105591562/
I am going to straighten the steering wheel a little though...
Black_Sheep is offline   Reply With Quote
Old 10-07-2018, 07:36 PM   #2023
oldman3
oldman3's Avatar
Mark, great little video...Jim
oldman3 is offline   Reply With Quote
Old 10-07-2018, 09:04 PM   #2024
MARTINSR
MARTINSR's Avatar
Yep, that is friggin awesome!
Brian
1948 Chevy pickup
Old 10-07-2018, 09:10 PM   #2025
DransportGarage
After screwing up several test panels preparing for the "checkered flag" painting, I got cold feet. I called my artist buddy back and he came over for about 2 hours, showing me a variety of techniques on shading, contrast, use of pearl, etc. Tomorrow I'll give it a shot. I have a feeling at the end of all this I'll be doing a lot of sanding and re-work...
Bob
