Old 12-04-2014, 06:44 PM   #2026
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Finally starting my Longhorn 4x4 conversion
Originally Posted by 6BT 56 View Post
Thank you.
Sorry, I spaced it off today. I will check it out tomorrow.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-04-2014, 06:44 PM   #2027
Dieselwrencher
I'm putting this here for my reference later.
http://www.hgmelectronics.com/produc...s/csm-chrysler
Ryan
Old 12-22-2014, 10:54 PM   #2028
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Will you post a part number for the A/C bracket
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 12-28-2014, 06:29 PM   #2029
1972RedNeck
1972RedNeck's Avatar
3930888
I run a Sanden 4474 compressor as it is about the only one with outlets that wouldn't interfere with the stock oil filter.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-29-2014, 01:54 PM   #2030
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sinister
Killer
Old 12-29-2014, 03:09 PM   #2031
Dieselwrencher
72redneck, thanks for the sanden part number. I might have to switch over to this style on this truck. I'll have to see wgen I get to that point.
Ryan
Old 12-29-2014, 09:56 PM   #2032
ryanroo
ryanroo's Avatar
Re: 1972 Chevy 4wd Longhorn Project: Never Ending Changes
i have that one bookmarked. its the best version of the 4474 that i could find to clear the obstacles on mine
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 02-16-2015, 11:46 AM   #2033
mx289
mx289's Avatar
How's it going over here Ryan ?
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 02-16-2015, 08:57 PM   #2034
Dieselwrencher
Not much to report on it. I switched to working on finishing some stuff on the inside of my south bay, and never got back on it. Things have changed again, and I'm not sure when I'll get back on this one.
Ryan
Old 02-18-2015, 08:24 PM   #2035
Dieselwrencher
I guess I can go ahead and report on some parts and progress I did make a couple months ago on it before I stopped working on it again. I had a hard time trying to figure out how I was going to add extra gauges without them looking dumb or being too hard to see. So I purchased a dakota Digital VHX cluster. I also got enough modules and sensors to do 2 boost gauges, a pyro, trans temp, and an extra temp box that may go in the rear diff. Then I got polished finned aluminum diff covers, a viair 480c compressor, and a rather stupid large trans cooler. I also started restoring a grill shell for it. I started by removing the clear anodizing, then straightening out any dents, and sanding the shell. It still isn't finished. I also modified a grill emblem because I wanted something different.
Ryan
Old 02-18-2015, 08:36 PM   #2036
jbclassix
Junk Yartist
jbclassix's Avatar
I wouldn't mind seeing the trans cooler and the other gauge stuff. On my Scout (TF727) I ran the trans fluid through the stock condenser. Worked awesome. I am working on a swap involving an A518 and the 3 factory coolers seem like they can be simplified, but will it be effective.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 02-18-2015, 09:11 PM   #2037
watahyahknow
watahyahknow's Avatar
transcooler never can be too large
where you going to put it ?
vertical behind the cab in the bed with an electric fan might be a good spot for it , out of the way of dirt the radiator for the motor and intercooler
small box around it should protect it from stuff rolling around inside the bed
if theres enough room you could mount the fan through the bed from the inside and the rad between the cab and bed might make routing the hoses eazier
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-18-2015, 09:12 PM   #2038
gerfunken
gerfunken's Avatar
Letting you know, that after weighing the options, this will be going into my truck this weekend. Direct hook-ups to all of the residual pieces that I had on the donor engine. I'll let you know how it works out. The one down side that I see so far is that mounting options are extremely limited, until I figure something out. Even though the display/controller is relatively small, all of the cables come straight out of the side.
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 02-18-2015, 09:35 PM   #2039
Dieselwrencher
I'll post a pic of the cooler here in a few. I'll have to get pics of the other gauge stuff tomorrow.
We'll see what you say about too large once you see it. It's dumb big. I don't know where I will put it just yet. In the bed is an option, although I'd like to keep it out of there. Behind the grill is more than likely out. It might go in front of my gooseneck hitch under the bed. It will have an electric fan that will be thermostatically controlled. I'm wondering if it'll even need the fan though.
Good deal. I've heard they're working great. I'd like to get 3 of these someday for my vehicles with RH's in them. Slowly but surely.
Ryan
Old 02-18-2015, 09:39 PM   #2040
Dieselwrencher
Here's the trans cooler. It's basically 2 giant cores looped together.
Ryan
Old 02-18-2015, 09:39 PM   #2041
watahyahknow
darngonnit they dont make the cheap version for the 4l80e
Old 02-19-2015, 09:57 AM   #2042
notchbackgta
Is that Vinyl or sheet? I may have to do that on mine. I forgot I have a couple of sheets that I bought to do the cluster in my Camaro
notchbackgta is offline   Reply With Quote
Old 02-19-2015, 10:18 AM   #2043
ryanroo
ryanroo's Avatar
Dakota digital, eh? I like that idea... Haha. I dig that front emblem too. I generally don't like CF but the tasteful yet small touches like that are cool. It goes well with the Halloween paint! Now quit slacking and build a truck!
72 K20 12v build
Old 02-19-2015, 09:23 PM   #2044
Dieselwrencher
It's a sheet with a sticky backing like a vinyl decal would be. I figured I'd give it a shot. I am contemplating doing the glove box door and gauge bezel in it too but don't want to over do it.
I'm afraid I'll be slacking on this one for a little while any way.
Ryan
Old 02-19-2015, 09:37 PM   #2045
Dieselwrencher
Here are some more pics of the parts collection I've been building up for it. I was trying to get all the little and big stuff knocked off so I can finish it and drive it and maybe be done? Is that possible?
Seat belts.
Ryan
Old 02-19-2015, 09:42 PM   #2046
notchbackgta
It looks pretty awesome. Can you take another picture from a little further away and not at an upward angle?
I don't know how the glovebox door would be if you did the whole insert, but it would go well with the gauge cluster. I LOVE Carbon Fiber and have been trying to figure out which VHX gauges I want to get. I like the CF, but I am not so thrilled about the blue and red backlighting they offer. I really like how the white backlighting is though, but they don't have any pictures on their website with the CF in white backlight
And holy crap you spent a t with all those modules with the gauges. I have been thinking about the GPS speedo with compass and temp, but I don't know if it is worth the extra 3 bills. I may just have to wait until I do the diesel and wire in other modules then.
And P.S. I have CF valve covers and the air cleaner top on the BBC in the 69 C10, you can't have too much CF, lol
Old 02-19-2015, 10:01 PM   #2047
Dieselwrencher
I only have this other pic of the emblem right now.
I really considered the GPS speedo, but I think I will go with the integrated cruise before I do that. And yeah, the cost will gag a horse doing these gauges. I just hope I'm happy with it when it's done.
Ryan
Old 02-19-2015, 10:15 PM   #2048
notchbackgta
That's awesome and will save me $45 from buying a repro emblem, lol. I will have to do that on both the Burb and the truck
Old 02-22-2015, 04:00 PM   #2049
mx289
mx289's Avatar
Nice new parts.
I like the gauges.Very nice.
At least when you jump back working on it,you won't be waiting on parts !
Tom
71 K2500
71 K5 Jimmy
Old 02-23-2015, 04:06 PM   #2050
Dieselwrencher
Originally Posted by mx289 View Post
Nice new parts.
The sad thing is there's stil more I'd like to do to it and need to get for it. I swear it never ends.
Ryan
