#2101 | |
![]() Join Date: Aug 2010
Re: The Blue Goose
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
#2102 |
Grandpa in the rustmobile...
Re: The Blue Goose
my gf driving the truck
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#2103 |
Lucky Teter at the wheel
Re: The Blue Goose
Tell her not to be so camera shy!
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#2104 |
Re: The Blue Goose
I showed her, she grinned (i think?) LOL
I fixed my senderunit/oil guage leak. Put a copper line in place of pos nylong/plastic took a 3 mile ride no leaks yet. Ima scrap the motor and clean it nice and see where the rest of my leaks are (have bad feeling pan/rear main leaks). Will go with 1 pc rear main felpro blue rubber next time (if there is a next time). Hopefully my trim clips come in this week and i'll get the driver side trim ALL on asap! Mtn man chad thinks he has some DD trim he'd get rid of. Whats the correct style/colors for a 68 low optioned truck?? Did come with side trim though.
#2105 | |
Cruzin
Re: The Blue Goose
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#2106 |
Re: The Blue Goose
woops scrape/clean, I went to a small school and played games in typing class
#2107 |
Re: The Blue Goose
Cool! the original paper work says truck place din service 10 3 67 murfreesboro tn
i got the original owners adress name lol whats up with the metal card in the back of the booklet?
#2108 |
Re: The Blue Goose
its a "protect o plate"
#2109 |
![]() Join Date: Jul 2007
Re: The Blue Goose
I got some grill trim if you want it. You pay the shipping. I'll have to look to see if it has any dents. I think one of them is good.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
#2110 |
Re: The Blue Goose
Oh that'd be great lonerlife! let me know on the condition im going to check the scrapyard (they get 67 72 often but go straight to crusher no matter condition, cheyenne whatever!)
Thanks Rick-keep exlpaining protecto plates
#2111 |
Re: The Blue Goose
got 5 push in clips (big old honkers) so hopefully i'll polish trim and put some on (B pillar for sure lol) gotta bring the door back...
![]() i ran home this afternoon on fumes
#2112 |
Cruzin
Re: The Blue Goose
aka, sailboat fuel (cb slang)
#2113 |
Re: The Blue Goose
nate-i like hearing all your funny sayings lol
![]() sailboat fuel haha thats good, going on facebook
#2114 |
Re: The Blue Goose
clips came today!
got the b pillar on, it sticks out a little but i think thats from the dent it had when i got t boned...the clips were sloppy at first but i opened em up so its tighter Now I gotta bring the driver door back- Do i have to take the door off to adj the bolts that go into the cab (pretty sure i do) any tips?? thanks
#2115 |
Re: The Blue Goose
need to get a few more misc clips and get the bed trim on (its ALMOST perfect but the front is messed up but it matches the truck (was trying to find perfect trim, oneday this will get all restored..)
Need to adj door, GET RICKY TO SEND ME A DOOR EDGE CLIP FROM HIS STASH OF 67 68 STUFF, and get a few more bolt style clips
#2116 |
Cruzin
Re: The Blue Goose
how exactly are you trying to adjust the door in/out or front to back?
#2117 |
Re: The Blue Goose
not sure hubscrub-
The entire door just needs to move toward the rear of the truck about a 1/4" the door/fender pretty much touch
#2118 |
Junk Yartist
Re: The Blue Goose
Got some motor cycle ratchet straps? I have a red-neck trick that works...
You need ratchet straps, and something that is the thickness of the gaps you want. -Take off your fenders -instert your shims between the doors and body -ratchet strap the doors through the windows and where ever you can to keep the doors from moving -loosen the hinge bolts -adjust the door by using the ratchet straps -tighten down the hinges -put your fenders back on -take off the ratchet straps if you want to open the doors
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#2119 | |
Re: The Blue Goose
To get the fender off, take off the cowl panel to find the 2 upper fender bolts, unbolt the hood hinge, one huge bolt in the fender liner at the rear, one bolt at the bottom of the fender at the rocker, and a few at the bottom edge of the radiator support attaching the fender liner, and 2 near the back of the head light on the rad support. Sounds like about 20 minutes, tops.
#2120 |
Re: The Blue Goose
drew is spot on but i dont think you want to take the fender off so take a pencil or sharpie and outline around the hinges where they mount to the door then take the hing to door bolts off (6) then once the door is off and its just hinges on the cab take a pencil or sharpie and outline around the hinges then loosen the bolts (6) and slide it back how ever much the door needs to come back then check to see if its equal in the horizontal lines above and below the hinge and tighten then brong the door back and put the hinges directly in the outlines on the door. tighten up WHEN DOOR IS OFF MAKE SURE TO PUT TRIM ON!!!!!!!!! putting the clip on right behind the fender will suck because there is no way possible to tighten the little nut behind the door.
#2121 |
Re: The Blue Goose
Ricky-Im missing the clip that your talking about, you dont possibly have another one laying around...??
I'll try it sometime, Im a little nervous to be honest I have some other misc projects to tackle... When I bought the truck it had trim door shut good etc, I took the door off the hinges (left the hinges on cab), should the adj be @ the door/hinge area? Anyway thanks for the help guys
#2122 | |
Re: The Blue Goose
#2123 | |
Re: The Blue Goose
#2124 |
Re: The Blue Goose
Fender sh ould be in factory spec
I'll try'n get my gf dad to help me on it sometime, so can I just align the door to roof/back of cab/rocker and then install the fender?
#2125 |
Re: The Blue Goose
Theres a junkyard north of me about 30 minutes that had a c20 with lots of trim etc
I need the pieces my sis junked for me ![]()
