03-28-2020, 07:20 PM | #2126 |
A guy with a truck
Re: How to: Ruin a perfectly good C10
Now, tackling the transmission protrusion has proved to be a bit more complicated. I started by building a tunnel section forward of the floor brace. This will serve as the flange for the bolt in hump to seal against. (Sorry for the blurry pic)
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
03-28-2020, 07:25 PM | #2127 |
A guy with a truck
Then built a kick-out to cover the rear of the shifter base. Just need to figure a way to tie it all together now.
03-28-2020, 09:11 PM | #2128 |
Looks good from the image
03-28-2020, 10:21 PM | #2129 | |
67-72 parts collector,…
Same shape just longer. Notch it to go over the higher floor section? Just an idea to keep the trans cover all the same shape.
03-29-2020, 02:25 PM | #2130 |
A guy with a truck
Thanks, getting there
That was my original plan (or one of them). Problem is that it starts to occupy the same space as the front of the bench seat. Still scratching my head, we’ll see where it ends up...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-02-2020 at 09:44 AM. |
03-29-2020, 07:31 PM | #2131 |
A guy with a truck
Ladies and gentlemen, meet Franken-hump. Everything fits underneath with (a little) room to spare. Now just needs lots more grind, weld, grind, weld, grind, weld, grind, paint. It just might be close enough for a stock style carpet to fit. ...or I might be seeing if the wife’s sewing machine can handle carpet bindings...
03-29-2020, 07:40 PM | #2132 |
I like it. Very creative. I bet your getting excited to drive this thing again!
03-29-2020, 09:15 PM | #2133 |
I'm betting 'high-hump' carpet will cover it fine. The area would be right in front of the seat edge so I bet that will help camouflage any irregularity.
03-29-2020, 10:37 PM | #2134 |
Nice job! I agree with Scoti, I think the stock carpet will fit close enough with the seat right there.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
03-29-2020, 10:58 PM | #2135 | ||
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 03-30-2020 at 11:22 AM. |
03-29-2020, 11:51 PM | #2136 |
Looking good!! When you are done welding that high hump, you will hardly be able to tell it has been modified.
As per you having to raise your bench seat 2". Will you still fit in the truck with that raised up? I know I would not be able to fit in my truck if I raised the seat even 1" (6'2" tall). Just something to think about.
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
03-30-2020, 11:09 AM | #2137 | |
A guy with a truck
03-30-2020, 11:22 AM | #2138 |
I'm not familiar with the 88-98 bench that you are using, but is there a way to clearance the back bar of the seat frame enough to allow you to not have to raise it? Maybe dimple the tube with a BFH?
03-30-2020, 11:49 AM | #2139 | |
A guy with a truck
I have already sectioned the side mounts, so it sits waaaay low, which is the only reason this is even an issue. Bumping it up a touch shouldn’t be a big deal. The spacers should disappear into the carpet/insulation.
04-01-2020, 09:48 AM | #2140 |
Still Learning
Awesome progress on your truck Chris! Just getting caught up on the manual tranny install. VERY COOL!
I know it's tough to get out and drive with the virus and all but I'm wondering about your suspension setup and how you like it? Have you had it on the highway? two lane running 65 yet? Just curious how it handles bumps and hickups in the road? I feel like I want to install coil overs on my truck just not sure yet. I will remain static either way. I may just have to raise it up a bit..... I'm tired of hitting asphalt with my stock control arms. stay safe out there |
04-01-2020, 10:16 AM | #2141 | |
04-01-2020, 10:50 PM | #2142 | |
A guy with a truck
Definitely do your homework if you decide to do a bolt on coilover kit. I’ve looked at a bunch and most don’t offer much in the way of ground clearance, and some of them are actually worse than stock. Tubular arms alone that will accommodate stock type coil springs will buy you an extra inch or so, mainly due to the smaller diameter bushings. Couldn’t agree more. This was one of the determining factors in wanting to do a crossmember versus arms only. Somewhere along the way, I lost sight of that and instead of moving everything up out of the way, I brought the whole truck down...
04-02-2020, 09:52 AM | #2143 | |
04-06-2020, 08:36 AM | #2144 | |
Still Learning
Stay safe out there bud. |
04-07-2020, 10:22 AM | #2145 | |
A guy with a truck
Out back, I really like the adjustability of the QA1 setup and the outboard mounting of the coilovers is inherently more stable and allows for longer shocks than an inboard setup.
04-08-2020, 08:18 AM | #2146 | |
Still Learning
04-08-2020, 01:11 PM | #2147 |
StitchMaster. Beautiful approach for that transition.
Are you using rolocs for finish work ? |
04-08-2020, 07:22 PM | #2148 |
certainly a lot of creativity. thanks for sharing. roger
04-09-2020, 11:07 AM | #2149 | |
A guy with a truck
Thanks Roger, I’ve learned most of what I know by watching others (many on this forum), which gives me the confidence to try new things. I hope by sharing that I can pass it on. Also makes me up my game, knowing people will be looking at my work. If not for posting here, this thing might be all bailing wire and duct tape
04-09-2020, 11:32 AM | #2150 | |
Every now and again I have to re-attach the dangling wires barely twisted together in the passenger side floorboard from one of these "I'll get to it later" style fixes. I do like it when guys post their not so great work. Seeing someone else's sub-par work gives me the warm fuzzies, it makes me feel a little less Sanford and Son-ish.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
