Old 07-08-2015, 08:32 PM   #2151
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1972 Chevy 4wd Longhorn Project: Never Ending Changes
Here it is sitting out side after a natural wash job. (rain) There are some pics of the LED's as well.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-08-2015, 08:35 PM   #2152
Dieselwrencher
Here's another pic, and pics of the VHX gauges while it's running. I still have to make a console to hold some switches, the trans controller, and some drink holders. I stil have to finish my tail pipes. In these pics, it has a turn down under the bed. It's coming together slowly.
Ryan
Old 07-08-2015, 11:26 PM   #2153
ryanroo
ryanroo's Avatar
lookin good brother
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 07-08-2015, 11:37 PM   #2154
Dieselwrencher
Thank you sir.
Ryan
Old 07-09-2015, 01:42 AM   #2155
jbclassix
Junk Yartist
jbclassix's Avatar
Love the wheel, tire, hubcap combo! Can you explain the mods you did on them? Not like I'll get that far on mine anytime soon
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 07-09-2015, 07:51 AM   #2156
mcbassin
Still Learning
mcbassin's Avatar
Your truck looks great Ryan! Digging the gauges too.
mcbassin is offline   Reply With Quote
Old 07-09-2015, 03:46 PM   #2157
Dieselwrencher
The hub caps are different from 1/2 tons to 3/4 tons. I never paid any attention to it. The 1/2 ton ones are dished in, on the center, and the 3/4 ton ones are dished out to clear the hubs. Although, the half ton ones fir on my wheels even with a D80. I used an acetylene tank cap with the rounded end down, put a block of wood on top of it, placed the hub cap on a card board box with the center in a folded end. I got everything set, then centered the tank cap in the center of the bow tie in the hub cap. I smacked the block of wood with a big hammer. It doesn't take much to get it to go out. But it does take some work to keep it from moving back in. I ended up taking a large bearing race driver cone and putting it on the inside diameter of the rolled bead in the hub cap. I smacked it multiple times to help set a memory in the hub cap to keep the center from popping back in. It worked pretty nice. My hub caps were for 73-75's, so I had to paint the bow ties blue.
The fronts. I had one with a hacked hole cut in it and another with a very ugly center. I used a die grinder and a carbide bit to frind a better circle in the center of the hub cap on th eone that was already hacked. On the one with a bad center, I drilled a hole in the center, then used the gas axe to cut a circle around the stamped circle in the center. I then used the die grinder and ground it smooth. Once that was done I used a flap disc on a die grinder and sanded/smoothed the openings. That's about all the mods I had to do to the hub caps other than straighten some dings and dents out of a couple. The fronts aren't perfect, but who makes them for D60 front hubs any way?
Thanks Mike.
Ryan
Old 07-09-2015, 06:07 PM   #2158
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Haven't been over here on the diesel side for awhile, I Love the new look in your truck!! Wheels and bumpers really make it look Tuff!
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 07-09-2015, 08:33 PM   #2159
brimc
brimc's Avatar
That there is one beautiful truck !!
Do you another picture of your throttle cable setup? I need to figure one out for mine.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 07-10-2015, 02:58 PM   #2160
Dieselwrencher
Thanks. I do like the look of the steelies. I hope so, it wasn't a cheap look. Haha
I can get more pics for you. I have some other brackets off engines I can get pics of too.
Ryan
Old 07-12-2015, 10:52 AM   #2161
mx289
mx289's Avatar
New rims and tires look great Ryan.
And congrats on the new house.
Looks like somebody has a fence or deck to build ?
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 07-16-2015, 05:45 PM   #2162
Dieselwrencher
Thanks, and yeah, that guy needs to get on it. So his wife says.
Ryan
Old 07-16-2015, 09:25 PM   #2163
watahyahknow
watahyahknow's Avatar
just explain het the merits of having a strong puller to rip the old decking of the veranda with some rope and a short initial run
(hold my beer : hey all watch this)
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 07-17-2015, 04:05 PM   #2164
Dieselwrencher
She'd just tell me to go get her excursion and use it.
Ryan
Old 07-19-2015, 09:58 PM   #2165
6BT 56
6BT 56's Avatar
Love the look of those steel wheels. I tracked down the same hub caps all winter long . Put them on with my skinny 16 x 6.75? Steelies they looked horrible . Love them on the wider wheel tho. I haven't heard anything of the vet lately . What's it up to? Put into storage ? Driven daily ? Doing a long haul route to Texas running blocker for a load of coors ?
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 07-20-2015, 08:17 PM   #2166
Dieselwrencher
Yeah, the wheels and hub caps definitely look better with the wide wheels. The Vette has been sitting since November in the barn. The last week in June I got it out and my brother took it to Good Guys. Other than that, it just sets. I'm having thoughts of getting back in it and making some passes before snow flies. We'll see. I've had thoughts of selling it too. I guess too much other stuff to do and too many thoughts of what I could be doing with the money rather than it setting in a barn. But then again, it doesn't cost anything doing nothing. Haha
Ryan
Old 07-20-2015, 10:33 PM   #2167
6BT 56
6BT 56's Avatar
Ya it's tuff. You sell something it's gone for good usually. I sold a bunch of stuff when I bought this farm. It sucked but life goes on. Now that some bills are paid and business is good I see my pile of good junk getting back up again . Your rite. It costs nothing to keep something packed away for a Rainey day. I can't see your vette being easily replaced .
Does that car have a build thread anywhere ?
Old 07-20-2015, 10:44 PM   #2168
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Been away for a while and in see you've made some serious progress.
Nice work buddy.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-21-2015, 12:06 PM   #2169
gerfunken
gerfunken's Avatar
I've got to admit, I'm a little jealous of the bumpers.... I may have to do something about that at some point in the future.
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 07-21-2015, 03:10 PM   #2170
Dieselwrencher
Yeah, I'd rather keep it, but it's tough for me to keep it and not want to do something to it. I've had major thoughts of taking the Cummins out of it and putting an LS in it. Redo the interior to back to an original dash configuration, and make it a street car. But, I have too many other projects, and the car runs and drives now. Yeah, I'll have to dig up a link. I know I had it on a few different sites. Plus if I couldn't get enough out of it, I'd just keep it anyway. I won't give it away. I have too much blood, sweat , anger invested in the dang thing.
Nice work buddy.
Thanks Nate! How have you and the family been? Good I hope.
Thanks. I'm going to try to get a front one like this for my 76. But my money tree lost all it's leaves.
Ryan
Old 07-21-2015, 11:11 PM   #2171
6BT 56
6BT 56's Avatar
If you took the oil burner out and did the LS thing that sure would be cool , but then you would have to find a home for the stout cummins and we all know how much you dislike projects . Lol. I vote keep it barn fresh till ur in the mood for it . Corvettes don't go bad . Even the limited build diesel ones that Harvey earl built by hand in the basement of the factory .......lol.
Old 07-21-2015, 11:27 PM   #2172
ryanroo
ryanroo's Avatar
Honestly, i was going to say something about how nice the rear is... haha
how about a few better pics of that thing in paint for a dude?
72 K20 12v build
Old 07-22-2015, 09:27 PM   #2173
Dieselwrencher
After reading your post, I had this flash of an idea. Instead of buying my friend's engine out of his 94, I could save all that money and just steal the engine and trans for the 76. But I'm not that desperate yet.
I'll try to get a few other pics of it for ya in a couple of days. It's kind of blocked in by another 6bt now. Haha
Ryan
Old 07-22-2015, 09:38 PM   #2174
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Really diggin your build. Thanks for checkin in on mine.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 07-22-2015, 09:53 PM   #2175
COS399
COS399's Avatar
Looks great Ryan!
No wonder the other projects are progressing slowly.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
