10-08-2015, 08:35 PM | #2176 |
Re: Restoring Rusty
Good job, just wanted to say, that job is very doable without dropping the rear of the lower control arm.
10-08-2015, 10:35 PM | #2177 |
Re: Restoring Rusty
Thumbs up...Dramatic change. How did your control arm bushing look and how do your leaf spring bushings look?
10-08-2015, 10:45 PM | #2178 | |
Post Whore
Re: Restoring Rusty
I am happy to report that the new shackles for the rear leaf springs came with new bushings so at least those will be taken care of. And I just checked LMC Truck and oh my are those leaf spring eye bushings really $17 bucks each and we need 4 total of them? wow pricey |
10-08-2015, 11:05 PM | #2179 |
Re: Restoring Rusty
moog part # sb335 cost you the same . you can pick up at a local part store and will save you shipping cost.
acdelco part number is 45g15300 gm part number 468481 and truck looks great
1981 Silverado C10 LS/4l60e My truck may be loud and ugly but I love her like bacon |
10-09-2015, 07:45 AM | #2180 |
Re: Restoring Rusty
Keep up the good work.
10-09-2015, 08:55 PM | #2181 |
Post Whore
Re: Restoring Rusty
10-10-2015, 09:45 AM | #2182 |
Re: Restoring Rusty
happy to help. it is also one of the things needs to be done to my truck lol
10-10-2015, 10:06 AM | #2183 |
Post Whore
Re: Restoring Rusty
Captains Log: SOL 1,878 [ahem] Saturday October 10th 2015 Anno Domini
Owe seven hundred hours - the Natives are still asleep, it's quiet, too quiet I don't like it... jk Going to do the rear today. Going to install the new 2" longer leaf spring shackles to lower the rear of the truck. Might need to "notch" the bed rail as some of youz pointed out. Notching means cutting out / making a hole / making room for something to slide in or fit. We shall see, but coffee first |
10-10-2015, 12:50 PM | #2184 |
Post Whore
Re: Restoring Rusty
and so it was time to do the rear, I swear I spent more time erecting the house of cards base to make the jack reach higher than to do the actual job, ha ha
below you see what we are up against, note the OG shackle in the lowest and highest positions and how it clears the bed rail (aka the 2x4 that holds the bed floor up) |
10-10-2015, 12:53 PM | #2185 |
Post Whore
Re: Restoring Rusty
a bit of PB Blaster juice on the old bolt threads and they came out pretty easily, I think I got to use my 13/16th wrench for the first time in for ever
10-10-2015, 12:57 PM | #2186 |
Post Whore
Re: Restoring Rusty
with the old shackle off we it was time for some Speed Dating (as we introduced the old mature part to its new wet behind the ears replacement, ie Stare and Compare Time
I am going to ball park the measurements as Old Shackle - 6" tall New Shackle - 8" tall again the camera angle makes the new one look like 9", I really need to learn how to take better photographs [ahem] sorry Millenials I meant pics |
10-10-2015, 01:03 PM | #2187 |
Post Whore
Re: Restoring Rusty
so we knew going in that we may have to notch the bed rail, and yep looks like the new shackalaka won't clear it by a mile
10-10-2015, 01:06 PM | #2188 |
Post Whore
Re: Restoring Rusty
ok, time for ... as the self proclaimed master mechanics on reality TV say ... [wait for it] ... A MOCK UP !!!
I am glad I mocked it up with the nut and bolts in cause I would have cut a notch way too narrow otherwise, so that's a Top Tip for you would you believe me if I told you that cut is straighter than it looks? yeah me neither, no seriously it aint that bad |
10-10-2015, 01:09 PM | #2189 |
Post Whore
Re: Restoring Rusty
alright with the bed rail out of the way, lets see how me did
... not bad... not bad at all HEY ITS A TRUCK! |
10-10-2015, 01:12 PM | #2190 |
Post Whore
Re: Restoring Rusty
ok and here it is all done with the leaf spring back in - bolts need to be tightened to 90 foot lbs, but my torque wrench only goes up to 75
10-10-2015, 01:41 PM | #2191 |
Post Whore
Re: Restoring Rusty
here's what it looks like up in there with the wheel back on and the truck sitting on the ground
I must admit I am a bit disappointed, as the preliminary measurements show a new height of 31 5/8 so not even a 1 inch drop, man that's a lot of work for an inch |
10-10-2015, 06:08 PM | #2192 |
Collector of Projects
Re: Restoring Rusty
I know its too late, but an axle flip kit would have gained more drop without cutting the bed crossmember...
10-10-2015, 06:52 PM | #2193 |
Post Whore
Re: Restoring Rusty
You are correct, but the ones I've seen at 6" would give me too much drop. Also according to LMC Truck they require cutting and drilling your frame to install the C-Notch brackets. So either way you're cutting something, so I picked the lesser of the two evils. ha ha
10-10-2015, 07:27 PM | #2194 |
Re: Restoring Rusty
You don't ~have~ to do a c-notch.
I did, since I tend to carry loads, but with a notch, the bed floor sits on the pumpkin before the notches really show their value. I'm not convinced it was worth the effort on my truck. The flip kit, though - totally worth it!
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
10-10-2015, 08:12 PM | #2195 |
Re: Restoring Rusty
If you are not where you want to be in the rear, you can always do hangers for the front side of the leafs.
10-10-2015, 08:46 PM | #2196 |
Post Whore
Re: Restoring Rusty
10-10-2015, 08:53 PM | #2197 |
Post Whore
Re: Restoring Rusty
so knocked out the other side
10-10-2015, 08:55 PM | #2198 |
Post Whore
Re: Restoring Rusty
notch on this side, and done
10-10-2015, 08:59 PM | #2199 |
Active Member
Re: Restoring Rusty
I'm curious, did you tighten the shackle/leaf spring bolts with the weight of the truck on the suspension? If not it's possible it's keeping the truck from settling and that's why you didn't get as much drop as you should have.
10-10-2015, 09:03 PM | #2200 | |
Post Whore
Re: Restoring Rusty
Nope that wasn't it, I loosed up the bolts took the truck around the block, jumped a few speed bumps, and no change, I recon the shackles were perpendicular to the ground already so that's as long as they are going to get Last edited by Gregski; 10-10-2015 at 09:19 PM. |
