#201 |
Re: 1970 SWB - Porterbuilt to the Extreme
Thanks Travis. Thanks for the air ride components.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme Mike |
#202 |
Nice build! I'll stick around for this one!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
#203 |
Thank you. I hope the cold doesn't keep me from working on it anytime soon.
#204 |
I just cut parts to have my gas tank made. I hope to start running some gas lines and brake lines this weekend. If I dont get around to that then I will start some more bodywork.
#205 |
67cheby
![]() Join Date: Sep 2008
great looking project !
#206 |
Thanks Mike. I'm hoping to drive it in the spring. Congrats on the cover. How did the blazer go over in Vegas?
#207 |
Started bending and running brake lines today. Any suggestions on the frame to caliper connections?
#208 |
The rear picture
#209 |
I picked up my new cab corners and front interior roof panel. Once those pieces are changed I should have pretty much a rust free cab now. I don't know if I ever mentioned this but but rust blows.
My tank should be formed up and welded next week. When I get home today I should have a package from Summit with my sending unit and fuel pump. Then I can finally finish running my fuel lines. It has been colder than all get out lately. So not much work going on at the moment.
#210 |
67cheby
looking good !
#211 |
Thanks Mike. I was just looking through your build thread to see what trim you used. I was then on Mar-K's website browsing.
#212 |
I forgot to mention I spent hours on saturday trying to hide my fuel line inside the notch. That was a *****. If you look at this Nate it would be nice if you welded a 3/8" pipe nipple or bushing into the top portion of the notch for running gas lines through it. That would really help. I am sure not everyone has the same fule line routing, just a thought though.
#213 |
My gas tank should be welded up this week so i hope to finish running my gas lines. Any recommendations on how to run the lines through the pb notch?
#214 | |
They can look really clean when they are hidden inside the notches, but it's a lot of work and if you ever have a problem, they are hard to get to! LOL
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#215 | |
#216 |
Just a little update on no update. WINTER SUCKS!!!!!!!!!!! Even though i have a heated shop it is hard to trek the 20 yards through the snow and below zero temperatures to turn on the furnace to work in there.
I did get my gas tank finally. I will post some pictures of that this weekend. If anyone is interested I can make my CAD models available for the pieces.
#217 |
Awesome truck man everything looks great. Did you ever get your brake lines figured out? here is what i did with mine, they will meet at the top of the frame with bulkhead fittings with stainless flex lines to the master. Cant wait to see the gas tank, looks sick!
#218 | |
#219 |
its a 22" flex line with the bulkhead fittings the part number from Wilwood is 220-11237
#220 |
Thanks.
#221 |
Hoping to get back to work during Christmas break. Some new cab corners and a new inner roof panel, that should be fun.
#222 |
Here is my gas tank. 26" x 19" x 10" 18ga stainless steel. Two internal baffles and a sump also. I still have to determine where I need to mount my mounting flanges.
#223 |
This is what I've been working on instead of the truck. Almost done though.
#224 |
I'm with ya on the drywall crap. It's like bodywork... UGH!
Looking forward to more updates on the truck ![]()
#225 |
![]() Join Date: Mar 2011
Your truck is looking great. Some really nice work going on there.
