Old 07-21-2011, 07:31 PM   #201
VA72C10
VA72C10
VA72C10's Avatar
Re: Project "Vertically Challenged"
Have a safe (and uneventful ) trip!!!!
And post here later to let us know if the grin wrapped ear to ear or went further
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-21-2011, 10:24 PM   #202
70k52wd
Blaze-Air
70k52wd's Avatar
No problems, runs great, drives great. It's an odd feeling when I look over at compact cars and see that I sit lower than them.
70k52wd is offline   Reply With Quote
Old 07-21-2011, 10:26 PM   #203
lolife99
67-72 parts collector,…
lolife99's Avatar
I'm glad you got the engine fixed.
Now you need something from the Billet Specialties catelog.
Say,... 4 big boxes?
Keith
Convert to disc brakes.
Old 07-21-2011, 10:48 PM   #204
70k52wd
Blaze-Air
70k52wd's Avatar
Oh Christmas tree I need some billets under the.
Old 07-22-2011, 12:14 AM   #205
VA72C10
VA72C10
VA72C10's Avatar
Cool!
although I really like it with the current rims.......a set of 20's would be KILLER on your blazer!!!
Old 07-22-2011, 06:10 PM   #206
72BlckButy
Tot Roddin'
72BlckButy's Avatar
You won't regret it.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-06-2011, 09:54 AM   #207
70k52wd
Blaze-Air
70k52wd's Avatar
Update: Tuesday I installed a new amp and sub. Had to pull the rear interior to do so because I have an amp rack under rear seat. Thursday: I did a clay bar and wax, looks really good for 27yo paint. Friday: I went to the shop to replace timming cover gasket. Got that done. I was pulling out of shop to go cruising, the motor burpped, and started ticking. Never left the shop. WHY does this truck hate me lol. I was too tired and dirty to look into it. Sounds like a rocker slipped, or a lifter gave out. I'll look at it next week when I have time.
Old 08-06-2011, 10:07 AM   #208
lolife99
lolife99's Avatar
Keep at it.
You will get it.
No chance it's just an exhaust "tick"?
Keith
Old 08-06-2011, 10:27 AM   #209
70k52wd
Blaze-Air
70k52wd's Avatar
Not really, I can hear it under passenger vc. Seems like I have to do everything twice on this truck. When I did the amp I had pinched the airpod control wire under the seat stand, so I had to pull the interior twice that day. The timming cover twice, this time I pulled the two front oil pan bolts, and wrangled the seal in. No more leaks. I'm getting pretty quick at front motor tear downs. It isn't that easy on ac trucks, but I have it down now lol.
Old 08-06-2011, 10:39 AM   #210
VA72C10
VA72C10
VA72C10's Avatar
Sorry to hear that Charlie....I was all excited reading your update then BAM! Another setback to cruising. And I actually have a 67-72 truck that drives right now
Old 08-08-2011, 07:28 AM   #211
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Hang in there buddy; all the tribulations of owning one of these old trucks.
-Nate
Old 08-08-2011, 09:43 AM   #212
70k52wd
Blaze-Air
70k52wd's Avatar
No worries, I'll be back at it today or tomorrow.
After I get it running I'll try to get the gas gauge issue fixed, I'm thinking a bad float. This will be the third time dropping the tank. It's easy though.
Old 08-09-2011, 05:53 PM   #213
70k52wd
Blaze-Air
70k52wd's Avatar
Well, I tore it apart and it had a rocker that slid off. I pulled the pushrod and it was bent. So I got a new pushrod, put it back together and it ran like a champ again. Took her out for a spin to Lowes, ran great...Made another quick stop, came out to fire it up and it did it again, rocker slid off. It seems to happen at low rpm's, like at start-up, or low idle...I do believe I have some lifters not doing the job correctly, so, tomorrow, I'll pull the intake and do some lifters and all new pushrods, and maybe new rockers although they seem ok...I'm thinking about changing the name of the thread to "Mechanically Challenged" lol...
Old 08-09-2011, 05:56 PM   #214
VA72C10
VA72C10
VA72C10's Avatar
Man, can't win for losing, huh? At least you've been able to fix it thus far.
and on the thread title
Old 08-09-2011, 08:58 PM   #215
70k52wd
Blaze-Air
70k52wd's Avatar
I'll agree with the "can't win for losing". But as far as being able to fix it thus far, it's still broke till it's not broke for more than a few miles at a time
Old 08-09-2011, 10:07 PM   #216
hot trux
'85 Stepside
hot trux's Avatar
maybe a shot in the dark, but some later model heads have to have ""self aligning"" rocker arms
hot trux is offline   Reply With Quote
Old 08-09-2011, 10:20 PM   #217
lolife99
lolife99's Avatar
Like these?
Hey Charlie,... Keep at it.
You are so close!
Keith
Old 08-09-2011, 10:27 PM   #218
hot trux
'85 Stepside
hot trux's Avatar
WOW , great pic Keith!
Old 08-10-2011, 08:16 AM   #219
70k52wd
Blaze-Air
70k52wd's Avatar
Thanks Hot trux, they(heads)are new GM replacements so maybe I need to look into this more. But I had a bent pushrod. Maybe it bent after it slid off. I was thinking it slid off because it bent.
Keith, as always you are very helpful not to mention encouraging. Thanks for the pic.
Old 08-10-2011, 01:21 PM   #220
70k52wd
Blaze-Air
70k52wd's Avatar
I forgot to mention that, I'm pretty sure I have lifter issues because I still have a couple rockers kinda loose, and the adjuster nuts are almost all the way down. Collapsed lifers on a few, and a couple more not collapsing enough...I have all new sealed power stuff going in today...
Old 08-10-2011, 01:49 PM   #221
lolife99
lolife99's Avatar
I assume you have no guide plates on these heads?
Keith
Old 08-10-2011, 02:40 PM   #222
70k52wd
Blaze-Air
70k52wd's Avatar
No sir, she's all stock...
Old 08-10-2011, 05:33 PM   #223
VA72C10
VA72C10
VA72C10's Avatar
Let us know how all the new parts work!!! Hopefully she fires right up and no more issues
Old 08-11-2011, 03:41 PM   #224
70k52wd
Blaze-Air
70k52wd's Avatar
I think I wiped my new cam...ARRRRG!!!
I'm going to measure the stud height on the old and new heads to make sure it's not the studs come loose. But yea, pretty sure it's the new cam gone south...I said I have to do everything twice, right???
Old 08-11-2011, 03:49 PM   #225
VA72C10
VA72C10
VA72C10's Avatar
Man, that stinks...I've heard it can have a lot to do with todays' oils...
