Old 11-27-2009, 03:14 PM   #201
vegaschevy
Re: Project NOT4SLE
Originally Posted by highperf4x4 View Post
Ok, I was just curious. I didn't realize this was a daily driver for you.
It did not start that way, then a truck was stolen and daily driver it is. Then for the last few weeks we sold my Girlfriends tacoma and while looking for another vehicle we were driving it 100 miles per day for both of us to work. But we found her a nice crew cab Ford yesterday and so back to just mine LOL
anyways... going to pick up my wheel bearings, and a few last minute details so when I dive in to the suspension..... I can just get it all done.
If anyone knows off hand, I need to find the pics of where everyone cuts off the bump stop off the lower control arm to make it clear better. Also what else I may need to do when doing the suspension
vegaschevy is offline   Reply With Quote
Old 11-28-2009, 01:36 AM   #202
highperf4x4
Re: Project NOT4SLE
Dude I had no idea!!
So, your only daily driver for a while AND you kept working on it? Right on brother!
highperf4x4 is offline   Reply With Quote
Old 11-28-2009, 12:25 PM   #203
VA72C10
VA72C10
VA72C10's Avatar
Re: Project NOT4SLE
Not sure on the bumpstop since I cut mine completely off for bags, but I would buy some loctite for all of your nuts/bolts you're installing with the suspension. Also, between now and starting on the tear down, spray all the bolts/nuts you're taking off with PB blaster once or twice to make teardown a lot easier. Have primer and paint around if you're planning to paint any of the parts while they're off for looks and/or rust prevention since it is a DD.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-28-2009, 12:27 PM   #204
VA72C10
VA72C10
VA72C10's Avatar
Re: Project NOT4SLE
Oh, and make a list of nuts/bolts you might need. I needed a lot more than you because of bagging it, but you will most likely need some not included with your parts so I'd lay everything out and take inventory of any needed bolts/parts and have that purchased to keep your down time to a minimum.
Old 11-28-2009, 01:05 PM   #205
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Project NOT4SLE
Here's a picture that I have.
The blue tape shows the "already trimmed" area of the lower control arm balljoint area. This will keep this area away from any rim with up to 4" backspacing.
Check your own "trim job" with your wheels on your truck, setting on the ground,... and then turn them "lock-to-lock", checking for rubbing issues.
The blue line shows how I trim off the bumpstop and leave the steering stop.
(some people remove it all,... but I like to keep the steering stop) Personal preference.
Keith
Convert to disc brakes.
Old 11-28-2009, 02:34 PM   #206
SCOTI
SCOTI's Avatar
Re: Project NOT4SLE
Keeping that portion of the steering stop helps keep the trimming of the lower a-arm to a minimum (pending back-space). I trim back farther since I run more backspacing typically.
When trimming the lip off, drill a hole where the 'starting' points will be (one on each side of the a-arm F/R). Then trim the lip & blend it in where the holes were drilled. This helps prevent stress areas from squared cuts when cutting the lip off.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-28-2009, 03:31 PM   #207
vegaschevy
Re: Project NOT4SLE
I have sprayed my entire truck down with PB blaster twice now. Trying to make sure it is all ready to be taken apart!!! LOL I also have lots of loctite and what ever chemicals will be needed.
Old 11-28-2009, 05:28 PM   #208
vegaschevy
Re: Project NOT4SLE
Pulled the front drivers wheel of the truck this afternoon to try and get some of the 40 yr old gunk that has built up off of the parts to prepare to lower it.
I found that the rotor is junk and needs to be replaced. It has a groove that is pretty hefty right through the middle of it. So Ill need to order some replacement rotors before I lower it now. ill do brake pads and try to clean the calipers also at the same time.
I sprayed oven cleaner on everything and let it soak in but it barely scratched the surface of this gunk.
Old 11-28-2009, 05:34 PM   #209
Rokcrln
Rokcrln's Avatar
Re: Project NOT4SLE
Before you through those rotors out you might want to check them first. I have seen a lot with the same grove and it may be a factory type thing. I know they are made that way now but they may not be junk, just older.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-28-2009, 05:40 PM   #210
vegaschevy
Re: Project NOT4SLE
Kevin
LFD Inc.
thanks for the info, ill have to look in to it. Anyone else have any opinions on this?
Old 11-28-2009, 06:48 PM   #211
highperf4x4
Re: Project NOT4SLE
Mine have the same groove.
As for the gunk..... where is your power washer?
Old 11-28-2009, 08:02 PM   #212
ripdog28
ripdog28's Avatar
Re: Project NOT4SLE
That little scratch? you would be good stopping the space shuttle with that cooling groove.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 11-28-2009, 09:28 PM   #213
LEEVON
LEEVON's Avatar
Re: Project NOT4SLE
I have the grooves too, been running them for years no problem except a jerk MO state inspector tried to tell me they were junk and sell me a brake job. I've had them turned twice, no issues.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-29-2009, 12:32 AM   #214
CheyenneShop
CheyenneShop's Avatar
Re: Project NOT4SLE
Me too - I got the grooves
I
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 11-29-2009, 12:50 AM   #215
Puropedo
Re: Project NOT4SLE
My Chocolata 72 have the same "groove discs" still on it, I knew they were the original discs!...
Puropedo is offline   Reply With Quote
Old 11-29-2009, 02:17 AM   #216
highperf4x4
Re: Project NOT4SLE
So, keep your rotors and drop that sucker!
Old 11-29-2009, 02:26 AM   #217
nastyc10
nastyc10's Avatar
Re: Project NOT4SLE
I also had the grooved rotors.
nastyc10 is offline   Reply With Quote
Old 11-29-2009, 02:31 AM   #218
vegaschevy
Re: Project NOT4SLE
i have a pressure washer that would take the grey out of concrete and it wont come close to touching the build up on this chassis after soaking it with Gunk engine degreaser, oven cleaner, simplie green, and whatever else I could throw at it.
any ideas?
I think how water would be the ticket but I do not have a propane pressure washer
Old 11-29-2009, 04:18 AM   #219
project 67 sub
project 67 sub's Avatar
Re: Project NOT4SLE
my burbs got grooved rotors just like that
project 67 sub is offline   Reply With Quote
Old 11-29-2009, 03:53 PM   #220
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Project NOT4SLE
Break out the Simple Green and a pressure washer.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-29-2009, 04:06 PM   #221
vegaschevy
Re: Project NOT4SLE
simple green is my cleaner of choice! It did not do a damn thing to this stuff... I mean nothing. maybe turned the run off water a little brown but no chunks came off!
I also get my brakes are fine!!! HAHAHAHA
Old 11-29-2009, 04:42 PM   #222
Rokcrln
Rokcrln's Avatar
Re: Project NOT4SLE
Small scrapper to get the large stuff off then I use a product called Oil Eater and I get mine at Napa auto parts in 5 gal pals ($40+-) and it works great. The best part about it is when you spill oil in the driveway and water hits it you get that rainbow affect. A few drops of this stuff and the rainbow is go never to return again so the neighbors are non the wiser Spray it on, let it sit but not dry then power up the H2O machine. For me it is a 2 coat system then right to paint with out any fish eyes.
It is also gentle on the hands for you single guys
Kevin
LFD Inc.
Old 11-29-2009, 09:20 PM   #223
highperf4x4
Re: Project NOT4SLE
Brother I don't know what to tell you. What type of power washer do you have? Mine is a 2800psi with a honda engine and it will just about cut a groove in the frame with the 0 tip.
There is a whirly bird tip that is a "0" that spins so that it makes a circle pattern really fast to cover more area and help to keep you from eating a line into something. I haven't seen anything yet it wouldn't take off and you can't hit any wooden surfaces with it or it chews it up. In fact, it will etch your conrete if you hit the driveway with it too close
Old 11-29-2009, 10:10 PM   #224
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Project NOT4SLE
Agree with the others, mic the rotors and if the non grooved area is within specs, you're good. That groove was factory on GM rotors.
As for removing the crud... man do I remember that month of fun.
I pulled everything off, got a large plastic container, soaked them in Simple Green HD, used scrapers to remove most of the built up stuff. Then I got some media for my power washer blaster attachment and stripped them with the media (like sand but not as harmful) and ran my power washer with it. Strips and washes all at once. Makes a heck of a mess with media landing everywhere but it stripped it to bare metal.
Next time, I am taking it somewhere and having the whole frame and parts stripped!!!!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-30-2009, 12:29 AM   #225
sleepertruck72
sleepertruck72's Avatar
Re: Project NOT4SLE
The rotors are old GM rotors...mine on my C20 are the same... I used my 3000 PSI pressure washer to remove ALOT of junk off my truck and it came off in big chunks You just may have to rub your nose a little harder into the sheet metal to get it to come off
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
