08-19-2013, 09:02 PM | #201 |
Re: my 50 build... why not?
Haven't had a whole lot of time lately.
Getting some wiring done. Came to a stopping point to see where my gauges and other stuff will go. Started on the center console too. 2 coats of glass mat put down, and 3 on the top. I will pull out the foam inside and see how sturdy it is then decide if i will add another layer or not. Then I have to make inner bracing, and mounts for shifter. Placing my order for my converter hopefully this week with Pete from hughes. then hopefully a week or so after that, I can get my big engine parts order. Posted via Mobile Device
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit! http://67-72chevytrucks.com/vboard/s...d.php?t=380212 Last edited by nebdrummer; 08-19-2013 at 09:09 PM. |
08-19-2013, 10:31 PM | #202 |
Awesome work and progress. Keep it up!
Posted via Mobile Device |
08-24-2013, 06:50 PM | #203 |
2 coats on the sides of the console, 3 on the top. Bracing has been added and riveted in. One more coat will go on the sides to cover the rivets.
Shifter has been mounted, and a cover "bubble" if you will, is also glassed. I cut out the gauge panel as I'm going to make it removable, and blend in to the rest. It will be tricky, but I should be able to pull it off. Third gear Park Starting on the removable gauge panel. The "bubble to cover the console. Waiting for it to harden, then I will smooth it up a bit and make it a bolt on piece. The bracing I gave freakshow converters a call. He pretty much won me over. Hughes was $640 already set up for the turbo setup beings its another 260 to get it re stalled. Freakshow is 320 shipped and 120 to re stall. Michael is a super awesome dude and seems to know his ****. Stall should be around 3000 on the foot brake and on the t-brake and flashes around 4000. Sould be here next week. Posted via Mobile Device
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit! http://67-72chevytrucks.com/vboard/s...d.php?t=380212 |
09-01-2013, 05:30 PM | #204 |
About 6 hours of filler work on the console and its only about half done. Yuck. I need to open up my gaps on the gauge panel a bit, then smooth up the lines.
Converter showed up Friday. Picked up the f body oil pan as well. Posted via Mobile Device
09-01-2013, 08:56 PM | #205 |
Nice work, truck is looking great !
Shawn
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=582647 |
09-01-2013, 09:48 PM | #206 |
Freakshow is very good to deal with. I worked with Michael on 1 for my chevelle and put it behind a 436 sbc and it has worked great for over a yr now. Very nice build, I'm getting ideas for my 51.
09-02-2013, 03:16 AM | #207 |
Sick build man! Very happy to see shiny paint! I like flat and satin paint, but shine is devine!
09-02-2013, 06:30 PM | #208 |
This truck is beautiful...I could hang that rear fender on my wall as art and look at it all day! Can't wait to see the final result.
57 suburban(sitting in the driveway), 2 69 C20 longbeds (sitting in the field ) and a 2003 8.1 Suburban Endeavor to persevere. "All of a sudden, I'm the old timer!" Some old timer on American Pickers. |
09-02-2013, 09:00 PM | #209 |
bubba, thanks! I wanna see yours done! Any more progress on yours? I love fat tires under old hot rods. Thats the way it should be!
vht, yeah, michael was pretty awesome. I called them at 8pm the one night just to leave a message but he was still there working. What are your plans for yours? Fluffy, thanks. I gotta get around to wet sanding and buffing it one of these days now. uggh. speesh, thanks!
09-02-2013, 09:34 PM | #210 |
I'm planning on pulling the 436 sb out of my chevelle for the truck. the chevelle will get a milder 383 sb and let my wife drive it. The 436 has a Motown block, dart heads, mech roller with a super victor and QF 850. I built the 350 turbo using Coan stuff and a freakshow conv. Runs pretty nice.
09-02-2013, 10:44 PM | #211 |
nice work on the console
block sanding and smoothing is a pain be careful, fiberglass can be addictive
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-02-2013, 10:59 PM | #212 |
VHT, that sounds like a beast! Any videos or a build up on it? If not, you should... Glad to hear of another successful freakshow user. Lol sounds like a drug.
Ogre, thanks a lot! You're pretty much the fiberglass interior god on this forum as far as I know. I will end up glassing the back of the cab, and a bunch of other interior parts, but probably after I'm able to drive it around. I'm fairly happy with how it turned out. Hopefully this week I can have the floor mounts made for the console to bolt it in, install all the gauges, cup holders, and the cage for a CD player. Posted via Mobile Device Posted via Mobile Device
09-03-2013, 10:51 AM | #213 |
Nebdrummer. Your consul looks great! That is one awesome truck you're building. Good luck going forward.
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
09-03-2013, 05:30 PM | #214 | |
still looks good from god's view
09-03-2013, 07:05 PM | #215 | |
Have a good one. Shawn
09-08-2013, 12:39 AM | #216 |
That console looks killer! Great job
1954 Chevy 3100 5 window, bagged on s10 frame, 6.0 ls swap/4l80e Past build thread http://67-72chevytrucks.com/vboard/s...=531261&page=3 1949 3100 s10 swap 5.3. Instagram -@thejcates |
09-10-2013, 06:56 AM | #217 |
nebdrummer, the console looks great. It will be a great looking truck and I am sure will be quick as well.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
09-10-2013, 11:52 AM | #218 |
Thanks guys. Progress is once again going to be slowed. My finances didn't work out as I had planned. So now, I'm going to finish the walls in the garage. I got one set of shelves hung, and 2 walls painted white. Now I need to lay down the floor border and move stuff around to finish the rest.
09-10-2013, 01:42 PM | #219 |
This thing is super nice! Keep up the fine work!
-Dustin "self built" Self Family Heirloom Project: http://67-72chevytrucks.com/vboard/showthread.php?t=579169 |
10-17-2013, 06:23 PM | #220 |
I've been busy as hell with things not related to my pickup. But, anywho, we had a big car club meeting planned, so I got the garage done minus the ceiling. So that's a plus. Doesn't look like it though. Lol
I'm fairly happy with how the console turned out. I need to make the floor mounts, cup holders, and get the cage for a CD player. wide band will go in the middle We have been remodeling my basement for the last month or so. Still need carpet, but that will be after the other half of the basement. Also dug in deep into the kitchen already. Yuck. On the bright side, I should be ordering the turbo next week. Then I will be sending the carb off to c&s to get it converted to e85 and other goodies.
10-17-2013, 06:32 PM | #221 |
I feel your pain, house projects kept me away from my truck for 6 years between tear down and start of reassembly.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
10-17-2013, 07:06 PM | #222 |
Ohh man! I don't want it to be that long! Lol.
10-17-2013, 10:33 PM | #223 |
trucks coming along nice. I feel ya on the home front, its got me a solid year behind on projects.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
10-21-2013, 07:07 PM | #224 |
Probably going to be even longer for motor parts now... Just ordered the new GE Artistry series. Fridge, stove, range microwave, and dish washer. I don't know if that's a good thing or a bad thing... Lol
10-22-2013, 10:44 AM | #225 |
hey man, gotta keep the wife and fam happy too (if you got those) if not, a nice home keeps a clear mind, a clear mind has more roof for mechanical thinking. I'm on a similar boat as you, getting set behind sux, but it will all pan out. Enjoy your nice new kitchen.
