Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-04-2013, 12:48 PM   #201
Super73
Super73's Avatar
Re: My build thread.. 63 LS powered C10
These LS pans are ummm let's just say pretty stout
Reason I figure 14" is that seems to be about the standard. Never run a vacuum pump before, so not too sure what to expect.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-04-2013, 12:50 PM   #202
Super73
Super73's Avatar
Old 01-06-2013, 06:36 PM   #203
hotrod1
56 - autocross
hotrod1's Avatar
Hey Super:
Nice build! How did you mount the seats? Did you go straight to the floor pan or build a floor hoop or connection to the roll cage? If you connected them tho the cage, can you show us pictures?
hotrod1 is offline   Reply With Quote
Old 01-06-2013, 08:55 PM   #204
Super73
Super73's Avatar
Not connected to the cage. I built mounts out of 1 1/2" x 2" square tube welded to the floor.
Last night I tore the motor completely down. While putting pins in the heads to align the intake for the porter, I did not relize the holes in the heads where the intake bolts come in are drilled/tapped all the way through. When I pulled the heads off, I found alum shavings in my lifter area and on the cam. some also fell in to the cyl's as the heads came off. Figured it would be a good idea to tear it completely down:
Tank the block
Pull the lifters apart and wash them out completely
Pull the rings off the pistons and clean the pistons
Clean off the cam
All the bearings look pretty good. So that makes me feel happy
Half tempted to sell my PRC 237 heads since I was going to have new valves/guides put in and buy some aftermarket casting LS7 heads. They flow about 15% more air across the full lift. Hmmm, head flow = power. But at what cost.
New intake
Need offset rockers (just bought 1.8 rollers for the current heads)
Might also require different fuel rails/adapters for my current injectors.
Ohhhh the addiction!!!
Old 01-12-2013, 04:33 PM   #205
Super73
Super73's Avatar
Tempted to put a different set of rings in it being there will be a vacuum pump moving forward. I'll call Weisco on Monday.
In the meantime:
EWP is back from Mezeire.
1.8 Yella Terra's are here.
Heads got shipped off to TEA yesterday. Debating on milling them vs running a thinner gasket. Guides were definately shot. I bought the heads used and should have checked them before installing them on the motor.
Started mocking up the vacuum pump yeasterday.
Old 01-24-2013, 01:17 AM   #206
Super73
Super73's Avatar
These are a bit old, but there was a photographer doing pics and half his proceeds were going to his friend who had cancer. I spent the $100.. Here are a few
Old 01-24-2013, 01:19 AM   #207
Super73
Super73's Avatar
Few more
Old 01-24-2013, 01:22 AM   #208
Super73
Super73's Avatar
Couple more
Old 01-26-2013, 10:46 PM   #209
noonzor
Lovin The Pics!!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 02-05-2013, 09:24 PM   #210
Bomp
Bomp's Avatar
those times have my attention!
Bomp is offline   Reply With Quote
Old 02-06-2013, 02:50 AM   #211
Super73
Super73's Avatar
Hopefully it goes 9.9x on motor this year..
Old 02-06-2013, 03:58 AM   #212
BigDan3131
BigDan3131's Avatar
That cam you have in it, is it the same one you started with in the beginning of your build thread? Do you have any pictures of the engine compartment the way it is now or has nothing really changed since the beginning.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 02-06-2013, 04:12 AM   #213
Super73
Super73's Avatar
I have had:
4 different cams
4 different sets of heads
2 different short blocks
2 intakes
2 different throttle bodies
3 different N20 kits
2 water pumps
1 less power steering pump
7 different front springs
2 different tran (but both out several times)
4 different converters
The list goes on and on...
If I took a pic of the engine bay for you now, it would be empty motor has been out a half a dozen times too.
Old 02-06-2013, 09:53 AM   #214
bigboybodry
bigboybodry's Avatar
I feel your pain mine is kicking my tail too. good luck! I'm sure you'll see some 9's on the motor or kill it trying that's what we do. haha!
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 03-07-2013, 02:31 AM   #215
Super73
Super73's Avatar
Heads are back. Intake valves weigh 87g. Time to drop the block, heads, and intake off so the valves can be unshrouded and the intake ported. Then back together it all goes!
But we just bought a house and a tractor. That could equal more time away from the truck.
Old 03-08-2013, 11:55 AM   #216
Marv D
Registered Truck Offender
Marv D's Avatar
Ultra light, extra high doller intake valves....... rockers made out of un-obtanium to keep them as light as science will allow,,, all to compensate for and attempt to control this big ol heavy overweight lifter.
. Just just yanking your chain Shaun,,, we've had this long standing discussion over lifter weight and I just had to harrass him a bit. If you can't depend on your friends to give you crap......
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 03-08-2013, 04:59 PM   #217
Super73
Super73's Avatar
It's ok Marv.. Food for thought and our discussion.. Head work done at a reasonable cost of <$1,000 included
New LS3 sodium filled valves turned down from 2.165 to 2.10
Wore out bronze guides removed and new powdered metal guides installed. Requires cnc to cut the PM guides
Valve job and combustion chamber clean up from valve job
Shipping to my door.
Seems very reasonable to me. Heck a ti valve alone would cost me 2.5x what I just spent, and... They weigh a whopping 1g less
Btw, since you brought up the heavy Hyd lifter.. I thought I would share the following links with you. This heavy lifter is going all the way to 8,300rpm on the 1-2 shift and 7,600-7,800 on the 2-3 shift. Check out both links and the videos on YouTube (you will find links in the threads).
http://www.performancetrucks.net/for...-setup-511962/
http://www.performancetrucks.net/for...%40120-514911/
Old 03-08-2013, 06:30 PM   #218
Marv D
Marv D's Avatar
OK so apples to apples,, (and I know valve control and lifter control are only 'related' not the same thing but one compliments the other) BUT: Apples to apples what does a hydraulic roller weigh compares to a Morel solid.
You are so far from a daily driver now that 'maintenance' isn't a valid argument... Hell you tear it apart and change things more than you drive it,, Whats a little valve adjustment (really LMAO on that one buddy) . That must be a California thing. You and that silly a$$ Bob Wu-10 LOL,, can't just put it together and run it.. Nooooo gotta tear it apart and 'tinker' with it.
<grins>
Old 03-08-2013, 07:17 PM   #219
hotrod 80
mini truck racer
hotrod 80's Avatar
Sounds like it is about to go back together . I am also a hydraulic roller user . Keep us posted on how it is going .
If i build a new motor it will likely be solid roller .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 03-08-2013, 08:59 PM   #220
Super73
Super73's Avatar
Ok.. Just for you Marv
Weighed 4 hyd rollers, all still have some oil in them, how much, who knows. 127-129g
Crane SR that I have on the shelf, weighed 2 of them.. both weigh 127g
5/16 7.4" .080 push rod 52g
The push rod i might run (just got one in) 3/8 .080 with 5/16 tips is at 72g
The new Yella Terra rock is heavier over the nose than the stock rocker, but I don't have a good way to show the difference. Keep in mind, I am running a stiffer spring moving forward
Now, why HYD vs Solid? The cost!! Plus it will be more fun to show that a hyd pump gas motor can go in the 9's in my truck on motor Once I do that, well... God only knows.
Old 03-09-2013, 03:44 AM   #221
BigDan3131
BigDan3131's Avatar
"Now, why HYD vs Solid? The cost!! Plus it will be more fun to show that a hyd pump gas motor can go in the 9's in my truck on motor Once I do that, well... God only knows."
Then it will be time to get serious and ditch all that NOS stuff and go twin turbo.
Old 03-09-2013, 04:25 AM   #222
Super73
Super73's Avatar
That would require additional bars.. 8.5x on bottle will be plenty fast.. If I ever get there.
Old 03-09-2013, 10:37 AM   #223
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Nothing wrong with hyd lifters they can go much further than most think.. I do agree with light valve train.. then add you high flow heads LOL.. Its not my money I am spending so I say go for it.. Your other projects are sitting there I plan on getting out to the 1/8 track here.. the new 35 spline moser 9 inch is in and thus far is working flawless. Going to swap up to a 315 17 dot stickie and drop the hammer.
GMR-PERFORMANCE is offline   Reply With Quote
Old 03-09-2013, 11:33 AM   #224
Super73
Super73's Avatar
Haven't seen you much lately Steve.. I was beginning to wonder about you. Glad to see all is well!
Old 03-09-2013, 06:43 PM   #225
Marv D
Marv D's Avatar
Originally Posted by Super73 View Post
......? The cost!! ......
OK now just wait a minuite right there.. you are not SERIOUSLY going to tell me this motor is driven my budget!!!!
I know youbetter than that.. let's just take a look at the heads you upgraded FROM,,, LOL
I would love to see what happens if you got this combination all done, and replaced the hydraulics for a sit of solids on the SAME cam,, just for giggles.
Don't get me wrong,,, I'm not arguing this isn't going to be an animal! just can't get my old ways wrapped around the squishy ol hydraulic valve lifter upper.
