Old 11-11-2019, 05:07 PM   #201
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: My 1st 68 panel
The heater box was in real nice shape but ended up breaking the damn thing trying to get it separated from the firewall. Not sure what they used to seal it but thought it would never come apart. Luckily I have a couple extra nice cases and can swap these guts over with all new gaskets at a later date. I imagine I will be quite some time before I need any of that. I need to get some bracing inside so I can take the doors off and get the outer floor area repaired. I think i will end up needing a second yellow note pad the way the list is going
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 11-13-2019, 09:46 AM   #202
richard2717
Re: My 1st 68 panel
what is the old saying......well while I am here I might as well...... I have to patch the old speaker holes anyway. Going to order a new cowl panel and leaning towards a blazer front floor.
Members I have met.
Old 11-13-2019, 09:59 AM   #203
richard2717
Re: My 1st 68 panel
One of the reasons for considering the blazer floor is that I would need to put 5 different patches in the existing one and the raised area for the front of the seats to bolt to is different on the panel floor area on the passenger side. It tapers off to nothing half way across. Since I am not using the factory utilities I would like it to be like the blazer/truck setup and go all the way across so i do not have to modify anything on the seats. I just wish I could find a vendor close enough to go pick it all up.
Members I have met.
Old 11-17-2019, 09:19 AM   #204
richard2717
Re: My 1st 68 panel
getting the cowl area stripped down and cleaned up
started pulling the dash apart and realized I was going to need to patch the radio hole that someone cut. To my surprise the did not cut completely out, so I can just pull it back around and weld it up. Most likely going with a delete plate anyway but want it back right
Members I have met.
Old 11-17-2019, 09:31 AM   #205
richard2717
Re: My 1st 68 panel
The new low hump blazer floors just came out and are in stock so this week I will be placing order for one of them as well as the outer cowl section. The orange suburban I have here cutting up for parts has good inner vent areas I am going to use to patch where they cut out for speakers as well as the small area on the upper drivers side that was toasted by wet debris sitting.
Also started gutting the rear interior and found a few minor problem areas that will need to be addressed at some point. I am thinking this was a plumbers truck at some point. There are holes in the roof from what appear to have been a roof rack and some dents that will need massaging as well. Nothing major but was all filled with bondo instead of weld. They insulated behind the paneling but I think it may have been owned by a carpenter at this point. A mixture of HVAC duct board & R-19 pink insulation on the walls and fiberglass insulated drop ceiling tiles in the roof
Members I have met.
Old 11-17-2019, 12:38 PM   #206
LockDoc
The Older Generation
LockDoc's Avatar
Re: My 1st 68 panel
Well, it should have been quiet inside....
LockDoc
Leon
Old 11-17-2019, 12:41 PM   #207
HO455
Post Whore
HO455's Avatar
Re: My 1st 68 panel
That cowl is Looking good. Does the rest of the wood floor look as good as the front part does?
My PO did the fiberglass insulation thing too. Man that was a bunch of work to get that mess cleaned up. When I first pulled the side panels off fiberglass dust went everywhere.
RIP Bob Parks.
Old 11-17-2019, 01:15 PM   #208
richard2717
Re: My 1st 68 panel
LockDoc
With my hearing loss it is always quite even when grinding inside
The pink does not bother me too much but man, them ceiling tiles have the old school fiber that just reaches down inside your body and holds on for dear life. My entire office ceiling had them that were 4" thick and when I had to change them out they ate me alive for days. Cold shower was no help at all. As soon as I saw these I went and got my tyvec suit on so we didn't go round 2. The mice had balled a lot of the pink up for housing but surprisingly there was no damage from them. They must have gotten cut on all the lower rust and bled out
The cowl cleaned up very nice as well as the windshield frame lip. I am always hesitant pulling the glass to see what awaits.
The rear floor in this thing is in great shape top & bottom side. Someone at some point sealed the top side but i will need to sand and reseal at some point. The underside of the truck had heavy oldschool undercoating on it that saved a lot of the underneath but all around the edges it had failed helping the rust out of the lower portion.
I have another set of rust free tubs here from a burb I parted that I am considering using to widen these tubs like on Leon's Panel. I really like the wide tire look
Members I have met.
Old 11-17-2019, 01:32 PM   #209
HO455
Post Whore
HO455's Avatar
Re: My 1st 68 panel
Wow! That does look good.
RIP Bob Parks.
Old 11-19-2019, 08:58 PM   #210
richard2717
Re: My 1st 68 panel
So now the fun begins to dissect these things so I can use the inner cowl area for patches. Should be as much fun as shooting pool with a rope
Members I have met.
Old 11-20-2019, 06:40 PM   #211
richard2717
Re: My 1st 68 panel
What a pain in the a$$ this is. and will still have to do some patching but can't afford the newly released inner & outer A pillar assemblies. I can do a lot of repairs for $1100 plus shipping. I have about 3 hours in getting this separated this far and still have a ways to go.
Members I have met.
Old 11-20-2019, 10:39 PM   #212
LockDoc
LockDoc's Avatar
Re: My 1st 68 panel
Sad part is there is no easy way to do it. Are you using spot weld cutters or regular drill bits? I find that the spot weld cutters cut faster and do a cleaner job.
LockDoc
Leon
Old 11-20-2019, 10:53 PM   #213
richard2717
Re: My 1st 68 panel
In the past I have normally used spot weld cutters but because I did not want to put holes in the part I am saving I actually just used a 3/8 bit and kinda rounded it as I went being careful not to put too much pressure on it. Just time consuming. It was a lot easier removing the one off of the panel because it was still attached to the full weight of the truck. I ended up putting some screws thru it into the table to help keep it in position.
Members I have met.
Old 11-21-2019, 11:03 AM   #214
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: My 1st 68 panel
Looks like a lot of fun.lol..You're definitely doing a nice job. Keep it up.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 11-21-2019, 11:49 AM   #215
richard2717
Re: My 1st 68 panel
Thanks Dale finally got the drivers side separated and have it in the blasting cabinet to clean up. I don't think I am going to end up needing this much for the passenger side.
Members I have met.
Old 11-21-2019, 05:13 PM   #216
richard2717
Re: My 1st 68 panel
Cleaned up pretty nice in the cabinet so I could see what I actually am working with. I think it will work out fine. I will still have to patch the very bottom of it. The passenger side is no where near as bad and I think i can get away with some flat metal inserts to fill the speaker hole area.
Members I have met.
Old 11-21-2019, 09:37 PM   #217
HO455
Post Whore
HO455's Avatar
Re: My 1st 68 panel
Great work!
RIP Bob Parks.
Old 11-21-2019, 11:02 PM   #218
Getter-Done
Getter-Done's Avatar
Re: My 1st 68 panel
Like it A lot.
Thumbs Up
84 Chevy K-20
Old 11-22-2019, 07:56 AM   #219
richard2717
Re: My 1st 68 panel
Great work!
Originally Posted by Getter-Done View Post
Like it A lot.
Thumbs Up
Thanks guys
Members I have met.
Old 11-23-2019, 11:14 PM   #220
KFF 1
KFF 1's Avatar
Re: My 1st 68 panel
Looking good !!!!
KFF 1 is offline   Reply With Quote
Old 11-24-2019, 10:14 AM   #221
jaros44sr
jaros44sr's Avatar
Re: My 1st 68 panel
OK, so I'm way late to the party, don't get over to the subs. side enough, but will follow from here on out. Looks like a great build!
Seriously, the whole rocker was filled with bondo, you could have used that to make a fibreglass mold of the rocker
good luck on the build
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-25-2019, 01:37 PM   #222
richard2717
Re: My 1st 68 panel
Originally Posted by KFF 1 View Post
Looking good !!!!
Thanks Guys, Glad to be back on it. Hope to get a lot of the metal work done over the winter but we all know how that goes. Did not get to work on it much this weekend but got the rest of it gutted and some more cleaning on the outer firewall. From the look of things, panel seems to be pretty rust free from the floor up. That , however, did not stop them from gobs more body filler. With the interior gutted I can see some dents in the main "billboard" area from the inside, but the outside is smooth. It also had some type of roof rack at some point that was removed and the mounting holes were just filled with filler.
Members I have met.
Old 11-25-2019, 11:57 PM   #223
Getter-Done
Re: My 1st 68 panel
Looking Good.
You have clean base to work with now.
My Question looking at the roof is.
Are the roof braces the same in a Panel Truck
As in a Suburban?
I would not think GM would use different braces.
84 Chevy K-20
Old 11-26-2019, 07:39 AM   #224
richard2717
Re: My 1st 68 panel
Looking Good.
As in a Suburban?
Dwayne
I am pretty certain they are both the same but have not held another up to compare. I got my final quote back on sheet metal yesterday so time to get everything ordered. Would be nice to get it all here to work on during the holidays
Richard
Members I have met.
Old 11-26-2019, 02:07 PM   #225
richard2717
Re: My 1st 68 panel
One more pc of the puzzle done and stored away. 80lb oil, NOS lens, NOS circuit card, new bezel and led bulbs
Members I have met.
