09-23-2012, 04:48 PM | #201 |
made in america
Re: How about some pics of Static dropped 60-66
what size tires you runnin on that sucker?
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes. sounds good 1964 c10-283 powerpack, 3 on the tree 2004 corvette- lowered, borla, tuned. slow my old girl 1966 c10- 305v8, t-5 sold |
09-24-2012, 10:45 PM | #202 |
09-25-2012, 02:58 PM | #203 |
CPP modular spindels ( -2) and 2 inch drop springs up front 4 inch drop with adjust bar in the rear.. 245/45/17 front and 275/40/17 rear.
62 long box with a little SBC http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
09-25-2012, 10:58 PM | #204 | |
Chris
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
09-26-2012, 12:13 PM | #205 |
THXs.. I thought I was done ... HA HA just got my price on a new moser 9 inch with 35 spline axles.. and am already thinking of swapping out the TKO600 trans for a T 56 Magnum to have the great low gears and a double OD... Man it never ends LMAO
09-26-2012, 01:49 PM | #206 |
Never Ending Projects
Great looking truck and I'll be happy to take that TKO600 off your hands!!! I loved the one I put in my '69 Camaro!!!
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
09-26-2012, 06:19 PM | #207 |
Active Member
Jankin,
Can I ask where you got the 6 lug center caps with the Chevy bowtie? I'm looking for some like that and I think they were OEM on later trucks but what year? Is someone repop'n them? thanks
Fleet '66 ***************** '66 C-10 SWB 350 w/3 spd OD 4:11's - driver/project...future T-5 trans upgrade '64 C-10 LWB BBW near future project - "The Wife's Ride" '58 "Apache"Stepside BBW w/'75 K-10 4x4 conversion 331 w/350TH and NP 205 transfer 3:73's - occasional driver/ show |
09-26-2012, 11:09 PM | #208 | |
Posted via Mobile Device |
09-26-2012, 11:27 PM | #209 | |
Active Member
Nice ride by the way. I like the stance. Just right. Forgot to mention that in my last post. B...
09-27-2012, 04:46 PM | #210 |
1st Pic: 4/5 Lowering Springs... 2nd Pic, Cut 1 Coil, 3rd Pic Cut 1 more..
Drove like crap but to me the looks were more important. Sadly it was sold about 6 months ago. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
09-27-2012, 07:31 PM | #211 |
made in america
love the pic with the sunset. fine truck
10-03-2012, 01:23 AM | #212 |
'62 GMC Long Bed sitting on the rear end...
10-05-2012, 06:21 AM | #213 |
65 GMC 88+ up rear end, 20x10 Boss 338, 275/40/20
I moved the axle on top of the leaf springs using Moroso spring perches and removed the 2 of the 3 flat leafs. Tires barely rub the fenders. I'm just going to roll the fender lips flat. We are doing a 73-87 crossmember swap up front with 3" DJM drop spindles and some cut coils.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
10-08-2012, 05:43 PM | #214 |
eldogg, what is the back space on that wheel??
10-09-2012, 07:41 AM | #215 | |
67-72 parts collector,…
Looks like the use of the early 63-69 rearend with aftermarket 5-lug axles is the answer. (since they are 3/4" per side narrower) I'm going to try and remember this swap if I ever own a 60-66 truck. How close is your tire to the bedside?
10-09-2012, 12:11 PM | #216 |
Ha Miayota where did you get your push through caps?
10-09-2012, 05:19 PM | #217 |
The 20x10 wheels are only offered in a 6.230 back space.
10-09-2012, 05:21 PM | #218 |
Thanks! I have about 3/4 between the tire and the bed side.
10-10-2012, 05:56 PM | #219 |
Thanks for the info eldogg
10-16-2012, 10:33 PM | #220 | |
how low are you right now with those wheels? I'm trying to squeeze a 20x12 underneath my step fenders but I am lowering mine with the porterbuilt coilover dropmember. Not sure exactly how much it will lower it but they say the frame is only like 5.5" off the ground...I may have to do a 20x10 or 20x9.5... yuck |
10-29-2012, 03:41 PM | #221 |
Maybe a dumb question, but what I gather, to do a drop spindle you have to convert to disc brakes, right?
I have a 1964 and want to do a 5/7 drop. I checked with CPP and ECE, anyone else I can check out? |
10-29-2012, 03:54 PM | #222 | |
10-30-2012, 01:41 AM | #223 | |
10-31-2012, 04:35 PM | #224 |
I just got my truck. Its a 1964 C10. It is stock.
I saw an add on craigslist for a hotchkiss 4" and 6" drop springs. What else would I need to get in order to install it in my truck? I called Summit Racing tech and he said I need to buy a shocks for the front and the rear. Is that all I need? I plan on installing a power steering and disc brakes up front. I am still debating on converting to five lug. I have been looking at all the posts for a few days. I saw a post on redrilling the rear drums to 5x5.5" to match the front. I will post pictures once I figure it out. Thanks for the advice. |
10-31-2012, 09:56 PM | #225 | |
But Found Her 25yrs Later!
I would sure like to see more of this one. Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
