Old 09-11-2012, 10:45 AM   #201
zippeay
zippeay's Avatar
Re: How about some pics of bagged 60-66
I'm still have a ton to do but it's getting a lot closer.
zippeay is offline   Reply With Quote
Old 09-11-2012, 11:14 AM   #202
66clow
66clow's Avatar
Looking sweet as it sits! I'm afraid to grind one of my side panels down because it probably going to need more work than your panel.
66clow is offline   Reply With Quote
Old 09-11-2012, 11:18 AM   #203
zippeay
zippeay's Avatar
Im going to have to block the crap out of the bed because it used to be a long bed. I also put a whole new door skin on the drivers door and made the whole bottom 6-8 Inches of the passenger door "I don't recommend that btw, it was a huge pain in the butt". Ive almos done all the patching and metal work but there is a little still left to do. I just hope it turns out as well as I'm picturing in my head.
Old 09-14-2012, 01:46 AM   #204
DLOE65
DLOE65's Avatar
Here's Mine..
DLOE65 is offline   Reply With Quote
Old 09-14-2012, 11:48 AM   #205
piratexpress1369a
piratexpress1369a's Avatar
Originally Posted by DLOE65 View Post
Here's Mine..
thats cool
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 09-14-2012, 11:15 PM   #206
gixxer711
Originally Posted by coulter View Post
i just noticed i never really took any good pics of how my rear shocks are mounted but here is one pic
if you bought shorter shocks than factory and you plan on mounting them to the rear end i believe they are gonna limit ur upward movement.. i think my truck has like 13 or 14 inches of travel at the rear end... way more than the trucks with the bags mounted at the rear end
What did or are you going to do about your trailing arms hitting the frame ahead of your bags when laying out? I like the bags mounted where they are. Should allow for less air needed to get to ride height and make it ride better.
gixxer711 is offline   Reply With Quote
Old 09-14-2012, 11:18 PM   #207
gixxer711
[/QUOTE]
What tail lights are you going to run, camaro? I love how the hole follows the curve on the bed.
Old 09-14-2012, 11:32 PM   #208
coulter
coulter's Avatar
its hard to see in the pic but i made a pair of 3 3/4" lowering blocks.. when it is aired out and laying on the rear crossmember the trailing arms are bout an inch away from the frame..
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 09-15-2012, 01:40 AM   #209
Slow Build
Slow Build's Avatar
What size wheels are you going to be using? The trailing arms must be below the scrub line with 15" wheels.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 09-15-2012, 01:42 AM   #210
coulter
coulter's Avatar
they are 15" wheels.. and what do u mean scrub line?
btw zippeay i really dig your truck!!! you have done a sh1tload of awsome work on that thing!!! cant wait to see it done
Old 09-15-2012, 02:05 AM   #211
Slow Build
Slow Build's Avatar
Here are some quotes from other threads from smarter people than me.
Originally Posted by Tx Firefighter View Post
It puts the bottom of the u bolts below the wheel rim, which is illegal in a lot of states.
Originally Posted by jonzcustomshop View Post
thats called a scrub line, if you have a flat, you want to still be able to roll with out digging in.
Originally Posted by lakeroadster View Post
I wanted to mention that from a safety perspective 1-1/2" rear lowering blocks are the most you can go with if your are running 15" wheels, due to scrub line issues. Otherwise if you get a flat rear tire the trucks lower shock bracket will be diggin into the pavement..... not a good thing.
If you want to go more than 1-1/2" then you need to increase wheel diameter.
So if you have 18" dia. wheels you could use 3" blocks, as follows:
18" dia. - 15" dia. = 3" diameter difference,
3" dia. / 2 = 1-1/2" radius difference,
1-1/2" increase in wheel radius + 1-1/2" blocks = 3" blocks
Past GM Trucks:
Old 09-15-2012, 02:16 AM   #212
coulter
coulter's Avatar
ahh damn i never thought of that... luckly i really dont need the rear of my truck to go as low as it does right now (the front wont go as low as the back) so i will rethink the size of my lowering blocks... im glad you mentioned that
Old 09-15-2012, 07:15 AM   #213
zippeay
zippeay's Avatar
Thanks man! I can't wait to see it finish either! I just finished painting the front end and put most of it together but I realized that I didn't get 90 deg air fittings so hopefully I can get some in the morning and finish the front bags today.
Old 09-15-2012, 10:29 AM   #214
gixxer711
Ya, your blocks are huge. I was gonna mention the scrub line as well. I have 15" as well and my 2" blocks are just below the scrub line. I am running bias ply tires, so they should make up the difference if I go flat.
I was thinking of using porterbuilts tubular arms to clear the frame and mounting my bags similar to yours. I really don't like bags right on top of the axle.
Old 09-18-2012, 05:22 PM   #215
baggedbigblock
The interior
baggedbigblock is offline   Reply With Quote
Old 09-18-2012, 10:01 PM   #216
piratexpress1369a
Originally Posted by baggedbigblock View Post
The interior
that is cool grenade shifter
63
Old 09-18-2012, 10:22 PM   #217
zippeay
zippeay's Avatar
Is that a reefer door panel? Hehe...
Old 09-18-2012, 10:34 PM   #218
baggedbigblock
Yup. Both door cards and shift boot are made from old pot seed burlap bags.
Old 09-18-2012, 10:59 PM   #219
zippeay
zippeay's Avatar
Vintage sacks? Or Repops? Either way I think it's cool. People out here would freak out, lol
Old 09-18-2012, 11:27 PM   #220
dbomb53
dbomb53's Avatar
I think you should leave the door panels as is..looks killer
"I wanna be like Dino when I grow up"
dbomb53 is offline   Reply With Quote
Old 09-19-2012, 09:10 AM   #221
zippeay
zippeay's Avatar
Posted via Mobile Device[/QUOTE]
I just saw your post, they are 50 pontiac tail lights. Thank you!
Honestly, I can't take credit for the idea another guy on here had done it to his and I thought it looked awesome so I ordered some from Speedway and put them in. A lot of stuff from speedway is junk but these are actually pretty good quality, they have glass lenses and everything and they also sell the cups to french them in. It was actually pretty easy to install but I still need to figure out my access holes but I'm not worrying about that until I finish up the bags.
Old 09-19-2012, 09:22 AM   #222
zippeay
zippeay's Avatar
Here's Mine..
Dloe65, Do you have any better pictures of how you trimmed your fenders? I need to do that to mine soon and was wondering how did it. Are you keeping the inner fenders? I'm going to try and keep mine but I'm going to have to modify them a lot. Great looking truck btw! I'm painting mine a really dark metallic brown, not many people like brown but I think it looks nice.
Old 09-21-2012, 04:26 PM   #223
jdoisher
jdoisher's Avatar
Getting closer as well!
Name:  66 DELUXE 347.jpg
Name:  66 DELUXE 348.jpg
jdoisher is offline   Reply With Quote
Old 09-21-2012, 10:57 PM   #224
Justin36
Justin36's Avatar
Attachment 987904
Attachment 987905
Woooo! Looks great!!
Justin
Justin36 is offline   Reply With Quote
Old 09-22-2012, 02:01 AM   #225
thekid54
Hmm, I thought I had posted in this thread. Here's my '62...
After a new coat of primer...
And now...doing a V8 and frame swap.
thekid54 is offline   Reply With Quote
