Old 10-01-2018, 09:43 PM   #201
Dads79GMC
Dads79GMC's Avatar
Re: Sparky's 1978 Silverado Build "Addiction"
I spent the whole day prepping the cab for epoxy. There are a couple areas that I need to go back and clean more thoroughly, but I wanted to get the whole thing in epoxy today. I was able to get two coats on this evening. This old body is a bit sore!!!
Oh yea, I was in the middle of scuffing the dash when I noticed that the radio area was cut-out for a modern radio.....damn, something to fix!! Now I'll have to find a patch panel....
Thanks Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 10-02-2018, 03:27 PM   #202
moregrip
moregrip's Avatar
Thanks Mike
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 10-02-2018, 08:56 PM   #203
Dads79GMC
Dads79GMC's Avatar
Today I put two coats of 2K primer surfacer over the epoxy. I also started working on two rust holes on the front right fender. Thanks Mike
Old 10-02-2018, 09:02 PM   #204
Dads79GMC
Dads79GMC's Avatar
Rear rust repair of right fender. Toward the end of finishing my patch panel welding, I blew out my air line and had a wild snake on my hands!!! Thanks Mike
Old 10-02-2018, 09:04 PM   #205
Dads79GMC
Dads79GMC's Avatar
Originally Posted by moregrip View Post
Thanks moregrip
Old 10-03-2018, 06:33 PM   #206
Jaysonb
Jaysonb's Avatar
Looks good Mike!
Jaysonb is offline   Reply With Quote
Old 10-03-2018, 09:04 PM   #207
Dads79GMC
Dads79GMC's Avatar
Originally Posted by Jaysonb View Post
Looks good Mike!
Thank you Master!!
Old 10-04-2018, 09:26 PM   #208
Dads79GMC
Dads79GMC's Avatar
Today I acquired some garage space inside the attached garage to the house. I was able to roll the chassis into the garage without the Mrs seeing it until it was too late. Now I should be able to easily move everything outside and do a good cleaning tomorrow then resume body work. I don't have time to get everything done before Dad's 79 GMC gets back from Jayson's in a couple weeks. So, I've decided to paint the firewall (side and front) and just put the cab on the frame. I really need to get this thing running under its own power so i can move it when i have to throughout winter. Mike
Old 10-05-2018, 09:47 AM   #209
moregrip
moregrip's Avatar
Under the gun now brother! Looks fantastic all the way around....these are "GOOD" problems to have!!!
Old 10-05-2018, 09:24 PM   #210
Dads79GMC
Dads79GMC's Avatar
Change update: I've decided to go with original steal bed floor. I plan on using the wood bed floor on a future build. Since I'll eventually sell this truck, I want to keep my 1 of 1 wood bed floor. Hahahah!
So, today I took the bed apart and changed out the bed floor. Also began the body work on the cab. Back to the bed. I also used one of my favorite tools to move the bedsides back into place, now they align with the bottom of the cab on both sides.
Pictures:
1. Right bedside was severely bent years ago. I had to cut into the front-edge to get enough alignment then fill the void with a bit of welding (not complete in the pic).
2. My favorite tool. Lol!
3-4. Just a little cab work.
Thanks Mike
Old 10-07-2018, 09:44 PM   #211
Dads79GMC
Dads79GMC's Avatar
Today I spent about six hours working on the 78....doesn't really seem like I accomplished much! I definitely can't focus on one thing at a time!!! Worked on the firewall some more, then spent a couple hours re-stripping the passenger bedside and filling holes on the upper rail, then worked on the corners and etc etc etc! Fun! Thanks Mike
Old 10-08-2018, 08:28 PM   #212
Dads79GMC
Dads79GMC's Avatar
Today I was able to get both fenders clean enough for an initial spray along with the hood. I will epoxy both fenders and under the hood tomorrow. Under the gun!!
Thanks Mike
Old 10-09-2018, 08:13 AM   #213
Low Elco
Coming right along. You're doing nice work!
Low Elco is offline   Reply With Quote
Old 10-09-2018, 08:48 AM   #214
Dads79GMC
Dads79GMC's Avatar
Thanks Low Elco. I think I can finally put the welder away???
Old 10-09-2018, 03:45 PM   #215
MrFinland
MrFinland's Avatar
Really great job, Mike! Have you decided yet what color you are going to paint this truck?
MrFinland is offline   Reply With Quote
Old 10-09-2018, 04:31 PM   #216
Dads79GMC
Dads79GMC's Avatar
Thanks Mr F!!
This is my inspiration!
Old 10-09-2018, 07:43 PM   #217
Jaysonb
Jaysonb's Avatar
The next one will have to be white! Red, white, and blue, very patriotic!
Old 10-09-2018, 10:26 PM   #218
Dads79GMC
Dads79GMC's Avatar
Learned tonight that you can adjust the door striker from inside the door. Didn't know that you could gain access through the latch (see pic). I aligned the door along the rear edge with the cab and reached in tightened the striker.....bam! Also got some epoxy on the hood and fenders. Thanks Mike
Old 10-16-2018, 09:21 AM   #219
Dads79GMC
Dads79GMC's Avatar
Lost my cab!!! Hope it shows back up at some point!!! I need to focus on the 79s interior for now, so I’m taking a little break on the 78. Thanks Mike
Old 10-25-2018, 02:23 PM   #220
MrFinland
MrFinland's Avatar
Thanks Mr F!!
You have nice inspiration picture! We had also inspiration picture before we started our truck restoration. This picture was our inspiration...
Old 10-25-2018, 03:06 PM   #221
Dads79GMC
Dads79GMC's Avatar
Nice!!!
Old 11-07-2018, 11:34 AM   #222
Dads79GMC
Dads79GMC's Avatar
Teaser!
Old 11-08-2018, 11:11 AM   #223
aggie91
I'm just glad to be here!
aggie91's Avatar
Nice!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 11-08-2018, 03:56 PM   #224
Woodyboat
Woodyboat's Avatar
ABSOLUTELY! I agree with you 100%. I'm in the middle of selling a home and moving. I'm really looking forward to getting into the new place where I can start tearing down my old truck for a complete restoration too. It's an exciting time for me and I'm really enjoying everyone's photos.
Dave
Woodyboat is offline   Reply With Quote
Old 11-09-2018, 04:32 PM   #225
Dads79GMC
Dads79GMC's Avatar
Best of luck Woodyboat with the new house!
