03-23-2021, 01:33 PM | #201 | |
Re: Doing LS Swap - I have no idea what I'm doing!
I appreciate the measurements. I'll check mine and see what I come up with.
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
03-24-2021, 11:05 AM | #202 |
Pulled some measurements last night. It's going to be a tight fit! My frame is showing about 33-1/2" inside-to-inside. I measured the crossmember, and it is 33-1/4" out-to-out of the brackets. Soooo, theoretically, it will fit. I may have to get a hammer and force it in there. I'm probably going to call CJ Pony Parts and see what their info is on the placement of the crossmember. Maybe I'm missing something... there weren't any install instructions that came with it - but, probably shouldn't "have" to be any, either - except for me.
03-29-2021, 12:21 PM | #203 |
Got my motor mounts in yesterday! Driver's side mount had a bunch of rubber down in the threads. Had to pull the motor mount off the motor, clean it out, and run the bolt through it to make sure it would work. Once I got that done, it mounted right up.
Now, to get time to tackle the crossmember.
03-29-2021, 01:35 PM | #204 |
HammerTime...good luck, I test fit speed headers...Look good and fit good, working on my own motor mounts, need clearance for stock compressor so far so good. Tight, but fits with some trimming of the plate.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
03-30-2021, 07:46 AM | #205 |
Check out the transmission crossmember I used in my No Daggum Money build. It was cheap and very well built and fits like it was custom made just for my truck. http://www.67-72chevytrucks.com/vboa...=550804&page=7 IFS is the builder.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
03-30-2021, 11:38 AM | #206 | |
Doing a quick search for it, though, I can't get their website to come up. Maybe work settings.
03-30-2021, 04:39 PM | #207 |
My partially restored truck came with an aftermarket crossmember from the po but I modified it to allow for better exhaust routing.
03-30-2021, 09:20 PM | #208 |
This one is very close to mine and may be a clone. https://www.ebay.com/itm/Transmissio...cAAOSw-Rle~Enr
03-31-2021, 11:07 AM | #209 | |
03-31-2021, 11:56 AM | #210 |
The one you have from CJ Pony will likely work. I kinda remember it took some twisting and turning to get mine in. Kinda like getting a couch through a doorway.
04-05-2021, 11:06 AM | #211 |
Got the crossmember in place. Not bolted in, but in place.
It looks like the holes will line up and work, I just have to "flex" the frame a little to get the bolts in place. Ordered a new transmission mount, as I forgot to do that.
04-06-2021, 12:22 AM | #212 |
Awesome! got a pic?
04-06-2021, 07:53 AM | #213 |
Also would like to see what you did with your motor mounts.
04-06-2021, 08:09 AM | #214 |
I'll try and get some tonight.
04-13-2021, 01:17 PM | #215 |
A few days late, but here we go...
04-13-2021, 05:30 PM | #216 |
Thanks for posting, good to see what others are doing. I'm going to use the OEM A/C compressor, so I need to shift mine back as far as possible...got my computer back from LT1....and almost done reworking harness.
04-13-2021, 06:23 PM | #217 |
Your a bit ahead of me with my swap. Branden has my computer as of today and will start on harness tomorrow. Ordered some parts for the LM7 planned refresh. I decided to go with Hooker Blackheart engine mounts so I don't have to mod anything to keep the low mount compressor.
04-14-2021, 10:56 AM | #218 | |
https://www.ictbillet.com/ls-truck-l...-7176-lq4.html Maybe that'll work? I have an a/c truck, but, I have no idea when it worked last. So, it's not a huge priority to get it going. Would it be nice? Sure. But, in the "older" vehicles I've had, a/c hasn't worked, so I'm used to it.
04-14-2021, 11:03 AM | #219 |
If you have the extra mounting holes in the plate, you might gain some room behind the compressor moving the mount back to the 2nd hole in the frame top.
04-14-2021, 11:08 AM | #220 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
04-14-2021, 11:21 AM | #221 |
Here's another bracket that I saw: https://www.ictbillet.com/ls-engine-...ls1-block.html
It may be another option, I don't know.
04-14-2021, 11:26 AM | #222 | |
04-14-2021, 02:30 PM | #223 |
Your solution is here:
https://www.holley.com/blog/post/hoo...y_c10_pickups/ F-body mount (Anchor 3064) bolts directly to LS block in factory location, so no interference with A/C compressor. The stands then move the engine reward to stock location. So, keep low mount compressor, no trimming required. But, may still need to figure out how to mount refrigerant lines...lot's of options to solve that problem which I plan to address when I get to it. I plan to use the Hooker Blackheart crossmember as well to ensure proper driveline angles. |
04-16-2021, 10:45 AM | #224 |
Got everything bolted up last night! Engine and transmission are now fully bolted in. Now to start figuring out the fuel situation. At my pace, I should have that wrapped up by, say, July?
04-16-2021, 05:28 PM | #225 |
Forward progress...Good...I'm right behind you, probably August - September.... Need to get my mounts complete...I have a Boyd tank and in the process of custom -redo-finagle a OEM 2001 fuel pump onto this tank.
