04-25-2016, 10:10 AM | #2251 |
Re: What did you do to your truck today part III
Pics of my seat. well that didnt work.
1964 |
04-25-2016, 11:47 AM | #2252 |
The painter got the grill surround, grill and bed installed. Newest pics.
04-25-2016, 11:48 AM | #2253 |
My buddy helped me take the fuel door and filler tube off a 95 suburban and mount it on the back driver side were the previous owner bastardized it with a square hole, just big enough to get the cap on. We also pulled the back tailgate cross brace off and repaired where they had welded on a retainer to cover the wood. I'll get some better pics a bit later.
04-25-2016, 12:14 PM | #2254 |
Try this again.
1964 |
04-25-2016, 12:21 PM | #2255 |
Moderator
Nice seat. What type of seat?
04-25-2016, 01:51 PM | #2256 |
I got the cover from classic industries. I've been work on a guys 62 impala and had him buy it for me for payment for the work. Fit good. I didn't do to bad for my first time doing a cover. i didn't trim my filler close enough and that is the bulge on the drivers side top. But i'll get it better. I did find out the seat is not a 64 seat. had a tag on the frame on it that said May 19, 1961.
1964 |
04-25-2016, 03:27 PM | #2257 |
Thanks,
Amazing what some soap and water will do. |
04-25-2016, 06:29 PM | #2258 |
Got most of one of my doors stripped.
04-25-2016, 06:33 PM | #2259 |
That is not a small thing either! It's a lot of work.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
04-27-2016, 04:24 PM | #2260 |
For sure Lugnutz. I got the glass and vent window out of the passenger door. Getting ready to strip the drivers door now.
04-27-2016, 09:53 PM | #2261 |
Post Whore
Installed new KYB gas shocks on my 64. Man does it ride ALOT better. Also installed new grease seals and you gotta have chrome hub caps. lol!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-29-2016, 04:58 PM | #2262 |
04-30-2016, 08:46 AM | #2263 |
serviced rear diff., Eaton HO52, 4.57 gears...
05-01-2016, 03:54 AM | #2264 |
Installed a quick fuel 450 carb. 283 is much happier moving down from the tired Holley 600.
05-01-2016, 12:29 PM | #2265 |
How did you strip the pint? Did you sand or chemical strip? Funny I was standing my doors yesterday because I'm gonna get resdy to paint them Krylon Champaign Nuevuoe to imitate the light fawn, while I was standing, I was thinking, this is going to take way too long.
05-01-2016, 03:24 PM | #2266 | |
05-01-2016, 03:28 PM | #2267 |
Got my headers painted and installed and got the starter bolted on.
05-01-2016, 08:26 PM | #2268 | ||
I do NOT use chemical strippers for fear that any residue will prevent primer from bonding to the metal. Besides that, chemical strippers are expensive, caustic, and messy.
05-01-2016, 09:04 PM | #2269 |
rims and tires are on....20" MOB STEEL WHEELS
05-02-2016, 05:13 PM | #2270 |
Post Whore
New radiator came in today!
05-02-2016, 06:55 PM | #2271 |
Adjusted the valves after break in. Hope to take it out for its(to me) maden voyage lol
05-02-2016, 09:20 PM | #2272 |
Active Member
Worked on installing new bearings in the Cad 500. The thrust went out due to a high pressure transmission problem, which caused issues with the cam bearings.
Sorry about the sideways photo's, not sure why some do this and others don't, they're oriented correctly when I upload. |
05-04-2016, 10:30 PM | #2273 |
Post Whore
Got my new demon and slip yoke ordered from Summit this evening. Gonna measure the drive shaft and go have it shortened.
05-04-2016, 11:11 PM | #2274 |
It's Better With Nitro
05-08-2016, 11:06 AM | #2275 |
Post Whore
New demon and slip yoke!
