Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-04-2014, 01:18 AM   #2301
Captainfab
60-66 Nut
Re: PO has me PO'd
Congrats to both of you. You are obviously doing things right.
Old 05-05-2014, 03:12 PM   #2302
mtully79
mtully79's Avatar
Re: PO has me PO'd
Late congratulations, I hope there aren't too many diamonds...
mtully79 is offline   Reply With Quote
Old 05-07-2014, 12:48 PM   #2303
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks guys, great of you to check in.....sorry, but yeah, could of bought lots of rusty truck parts if i didnt buy those diamonds.
Working on injection harness, the part number for the FAST male terminal is #170260. Using the delphi tool in the pic will release them from the connecter...
20140507_115616 by james_jaros, on Flickr
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-11-2014, 10:25 AM   #2304
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
COP/CNP
20140511_101912 by james_jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 05-14-2014, 12:24 PM   #2305
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Worked on the injector harness, one side almost done. Much better in my opinion then the split plastic
XIM/with harness is on the way from FAST
OEM CNP brackets are just not working out, have to make something better
20140514_121524 by james_jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 05-14-2014, 09:33 PM   #2306
SONOSADSACK
SONOSADSACK's Avatar
Re: PO has me PO'd
Really looks good Jim. Big improvement over the plastic stuff. I wish I would have considered other options before I covered everything.
SONOSADSACK is offline   Reply With Quote
Old 05-15-2014, 12:18 AM   #2307
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks, yeah, it was a no brainer for me, couldnt stand the look of the plastic stuff. But, it is somewhat of a chore to pull the connectors apart to slip on the sheath. I keep telling myself "the end result is worth all the hassle"
Glad to see youre making some progress, that gas tank mod was incredible, wished you would have posted up sooner
SAFETY FIRST
AS usual, off topic
Jim
Old 05-20-2014, 02:00 PM   #2308
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Got the XIM and E dash in the mail today, now the fun begins, again.....
20140520_135439 by james_jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 06-07-2014, 02:37 PM   #2309
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Stuck in electrical prison....
Trying to repin my XIM 30 pin connector, but the sucker wont come out. Its a differant connector then what im used to working with.
20140607_141002 by james_jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 06-08-2014, 10:16 AM   #2310
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
After two fustrating days i finally got the pin out, now just waiting for new ones from FAST
20140608_100817 by james_jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 06-09-2014, 12:57 AM   #2311
Captainfab
60-66 Nut
Re: PO has me PO'd
Did you use a special tool or just what you had?
Old 06-09-2014, 09:51 AM   #2312
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Yeah, i used that super thin Delphi 12094429 tool, just kept pressing and pushing on the bottom of the connector. Ill try to take a pic of the tab, but its really small and i dont know if it will turn out.
If A3 is on the bottom of the connector, and you pry down, it should raise the tab on the pin, and allow you to pull the pin forward, or push on wire
SAFETY FIRST
AS usual, off topic
Jim
Old 06-09-2014, 10:19 AM   #2313
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Kinda hard to see, but the tang (T) is located in the dark shadowy area. I think the key is to pull on the wire, and then come in at a steep down angle with the tool to catch the (T) and pry up.....
The (T) im talking about has three horizontal white lines in it on the pic. I dont know if you have a tablet, but if blow up the pic, it becomes obvious where and what this 'T' looks like
20140609_100637 by james_jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 06-09-2014, 01:33 PM   #2314
skorpioskorpio
Re: PO has me PO'd
De-latching a pin from a shell usually involves insertion of a release tool (or a pick or a tiny screwdriver) from the opposite side from the wire while you gently pull on the wire. It's not always obvious where to depress the latching tang unless you have a pin out and in your hand already.
(far more difficult to do if there is no wire to pull on)
skorpioskorpio is offline   Reply With Quote
Old 06-09-2014, 06:17 PM   #2315
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Dang it, i mean vertical lines......
SAFETY FIRST
AS usual, off topic
Jim
Old 06-10-2014, 01:15 AM   #2316
Captainfab
60-66 Nut
Re: PO has me PO'd
So the wire and connector should pull out thru the wire side of the housing, correct?
Old 06-10-2014, 03:38 AM   #2317
skorpioskorpio
Re: PO has me PO'd
I'm saying "usually" as a generalisation, I would assume so, I've taken apart dozens of different type connectors, and most are either locked in place by a tang on the pin that springs against a step in the shell or if not they are usually held in place by a small wedge in the shell (plastic part) that a fat portion of the pin must be pushed past. For the most part connectors are usually made to be terminated and then inserted into the connector shell and not usually made to have to snake the wire through the shell and then terminate. I've disassembled connectors from Amp, Tyco, Molex, T&B as well as Japanese and European connectors in a wide variety of electronic, vehicle and industrial applications and almost all mass termination descrete wire pin in shell type connectors are one of the 2 types and I'm usually able to get them apart with either an eyeglass size screwdriver or a dental pick (and often those work better than specifically designed extraction tools).
Of these type of connectors, if the retension mechanism is a small wedge in the plastic part they are released from the wire side, if a tang on the pin they are released from the opposite side. These actually look like they are probably the wedge type so they would be released from the wire side.
Old 06-20-2014, 11:42 PM   #2318
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Ok, this is as much as i know on the subject.....
Looking at the pins, they have a release tang on the bottom and you can access it through the wire side, and push the pin forward. There is no way that i can see to take the pin back into the connector b/c there are to very little nubs at the top of the pin that keep it from going in the direction of the wire. The End
This is FAST's part number, but you should be able to cross referance it to a delphi part number
20140619_135952 by james_jaros, on Flickr
You can see the tang hanging down, in this pic. better, that has to be depressed to remove pin
20140619_131809 by james_jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 07-31-2014, 04:53 PM   #2319
mtully79
mtully79's Avatar
Re: PO has me PO'd
How's the progress Jim?
Old 08-01-2014, 01:09 PM   #2320
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Well, to answer your question....its slow. Im under the wifeys employ for the summer (honey do list) and she has decided the outside of my workshop was a bit ghetto. So, i had to hang siding and trowel stucco to give her the curb appeal she wanted, but it cost her a 1945 erie gas pump
But, i finally decided on the wheels and tires i wanted ( knurley, to coin a phrase i learned on the site) interco truxes m&s radials. Stock size on the front, 10 in. wide on the back with 1 1/2" wheel spacers. Corvette ralleye from wheels vintique, not sure if i will run the center caps and trim rings....might do a poll to see what you guys think
20140801_124059 by james_jaros, on Flickr
20140801_124133 by james_jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 08-01-2014, 02:54 PM   #2321
mtully79
mtully79's Avatar
Re: PO has me PO'd
Pump is a nice touch, it's the little victories that count after all.
Tires will look great on the truck, I'm curious to see how your poll turns out.
Any progress is good progress! Enjoy the rest of the summer.
Old 08-01-2014, 06:20 PM   #2322
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Yeah, shes a keeper....leaves me alone in the 3 or 4 winter months to play with my truck as much as i like, never even questions how much ive spent....shes the best, dont tell her i said that. haha
SAFETY FIRST
AS usual, off topic
Jim
Old 08-01-2014, 07:21 PM   #2323
msgross
msgross's Avatar
Re: PO has me PO'd
We use to have a similar pump on our Farm in Indiana... wish I would have grabbed it before everything was auctioned off.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-01-2014, 07:56 PM   #2324
warbucket
warbucket's Avatar
Re: PO has me PO'd
Nice job Jim, Ounce my blazer is ready for the highway I'll bring it up to your place. I also have to run it up to Jay's house too.
72 CST 4x4 Blazer, 1 ton
70 SS Chevelle, L78, 396
Everytime someone calls your Blazer a Bronco, God kills a kitten.
warbucket is offline   Reply With Quote
Old 08-01-2014, 08:34 PM   #2325
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Seems like we all have 20/20 hindsight nice job on your new mancave, a pump wouldve looked perfect out in front....
Whens the electric get done?
Thanks john...anytime your ready, still have some bugs to work out?
SAFETY FIRST
AS usual, off topic
Jim
