#2376 |
![]() Join Date: Aug 2005
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Brake/Fuel Lines going in:
#2377 |
maibe a bedliner like rinoliner works if you paint it on in several layers
all you basicly need to do is prevent the metal from ringing by adding a softer material or weight
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#2378 |
Yeh, the whole undercarriage is coated with raptorliner. Looking for additional measures.
#2379 |
WOW! This is an amazing build. Your attention to detail is truly incredible. I wish I had the patience you do. Thanks for sharing
51 motor buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=718113. 54 3600 Lincoln aviator chassis swap http://67-72chevytrucks.com/vboard/s...d.php?t=717927 |
#2380 | |
A little progress: I got all the suspension pieces stripped down and ready for powdercoat. Also picked up some stainless hardware for mounting the gas tank 💪 |
#2381 |
Fuel tank install:
#2382 |
It's nice seeing updates again! Everything is looking good!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#2383 | |
![]() Join Date: Dec 2012
There's one perfect fit And, sugar, this one is it We both are so excited 'cause we're reunited, hey, hey..." (only old guys caught that reference) Seriously, I can't speak for the noico liner or the DEI, but that gaffers tape is tougher than a $2 steak. I was moto riding and a turn signal fell off, hanging by the wires--one of the guys who's a theater nut taped it back on with gaffer's tape. It stayed like that for months, and when I got around to fixing it--that tape was like a weld. |
#2384 |
oh its pretty strong allright even though you have different qualities of gaffer tape for different aplications , most common is to seal up airductwork in offices and houses
did you know it was originally devellopped to be a watertight seal for ammoboxes ? that why they allso call it ducktape as water falls of it like from a ducks back (even though people tink its duct tape) its just that over time (talking years here) the gleu becomes hard and turns intoo powder and the backing basicly crumbles like burned paper
#2385 |
Actual Gaffer's tape is different than duct tape. It's used by the "gaffer" in stage, TV, and industrial production to attach or cover things the audience isn't supposed to see or tape down electrical cords on stage to prevent the actors from tripping. It's matte black so it doesn't reflect the lighting. I would never have come across it if I hadn't met a theater guy.
#2386 | ||
It's good to be back at it! Dropped off the remaining suspension parts for powdercoating this week
![]() Quote:
![]() Quote:
#2387 |
Templates for the DEI Thermal Barrier:
#2388 |
A little bit more, a little bit more...
Since the trans tunnel is painted and will not be covered inside the car I'm doing a layer of deadener in addition to the DEI thermal barrier. Got the sound deadener in place after a thorough cleaning with wax/grease remover: ![]() ![]() ![]() ![]() |
#2389 |
Looks great Frizzle! Do the Rattletrap guys have any feedback on using this on the exterior? Seems like the environment is a lot harsher in the trans tunnel that what you'd expect inside.
Also, can you tell more about the DEI thermal barrier? I checked out their website and while it looks like it functions well, I'm not sure I'd want it showing much in my engine bay. Are you planning to put any on the firewall? If not, are you concerned about heat in that area?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
#2390 | |
#2391 |
A few remaining parts back from powdercoating:
#2392 |
Still Learning
Wow! great looking powder coat!
#2393 |
VA72C10
![]() Join Date: Mar 2008
Everything is looking so fantastic!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#2394 |
#2395 |
#2396 |
The valve cover is out for paint. Any guesses as to color..?
#2397 |
This continues to be one of my favorite builds!!! The level of detail is inspiring....
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
#2398 |
#2399 |
think i would go for the blue bodycolour as whell
#2400 |
Camo?
"I feel the need for speed!"... as soon as I am done with my nap. |
