Old 10-06-2011, 01:10 AM   #2401
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: slik ricks 67 short wide CST
if ur like me you'll probabyl wish u didnt fill theholes
my vote is no
John
1999 Toyota Tacoma 4x4
Old 10-06-2011, 01:45 AM   #2402
jbclassix
Junk Yartist
jbclassix's Avatar
put your frooont end on jack stands and see if the wheels turn good both ways. this will also help bleed the steering. I agree with john, I wouldnt fill the holes, especially if it is a work-in-progress. You don't want to undo what you already did
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 10-06-2011, 06:51 PM   #2403
67chevy1series
67chevy1series's Avatar
so put it on jack stands and start the truck so i ahve power sterring and see if it starts working? do the wheels need to touch the ground or do they have to not touch the ground? the only hole i want to fill right now is the clutch hole, i dont want to ever make my truck a manual.
67chevy1series is offline   Reply With Quote
Old 10-06-2011, 06:54 PM   #2404
oldblue1968chevy
Can you plug it for time being, you never know you might get a wild hair and wanna build it a 3spd on the tree
John
Old 10-06-2011, 06:55 PM   #2405
67chevy1series
that would cost way to much. i want to get it running as an auto..... if i build a 3spd it will be with another truck...... i do have the plug and will plug it but i just dont like that they shreink with heat from the engine and fall out then you have a whole again, nothing is water proof like a flly welded in metal.
Old 10-06-2011, 10:05 PM   #2406
heeroyue2002
fat old dude
heeroyue2002's Avatar
make a thicker plug in shop
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 10-06-2011, 11:01 PM   #2407
67chevy1series
the plug is plastic............
i did some more wiring work. its coming along... if it doesnt work tommorrow then i am stumped. also the power steering trick didnt work so well... i could tell it was trying but it couldnt do it.. also after i turned it off it started leaking out of the top of the cap area it was as if the cap wasnt on all the way but it was.
Old 10-06-2011, 11:19 PM   #2408
oldblue1968chevy
bad pump or something? try the engine/drivetrain forum or the suspension forum where more people will see it
good luck ricky
John
Old 10-07-2011, 12:06 AM   #2409
67chevy1series
the pump worked perfect for member sleepertruck72 when he took it off to go to serpintine pattern.
Old 10-07-2011, 01:08 AM   #2410
heeroyue2002
fat old dude
oh. my 72 cab had a metal plug made and covered the clutch hole.
Old 10-07-2011, 01:42 AM   #2411
jbclassix
Junk Yartist
jbclassix's Avatar
Rick, was the steering arm ever off the gear box?
Can you pop the pitman arm off your center-link, make sure the arm can move side to side freely, and have someone turn the steering wheel full left to full right.
What may be happening is the pitman arm is 90 degrees off. SOME boxes this is possible to install the arm wrong. It's a lot of work, but it is a learning experience. Let me know buddy, any questions I am glad to help!
With the oil over flowing, you were working your steering pump hard and the fluid got hot. DEX III (which you should be using) expands quite a bit from heat. Have you ever noticed the full cold and full hot differences on the dipstick? Just make sure it is topped off. A good back yard trick to see if your pump is good, have some one watch your pressure line. Run the truck, turn the steering wheel either way to full turn and hold it there. If the pressure line "jumps" or "flexes" you have pressure.
I would eliminate your pump as a problem. If it turns good one way, then the pump is producing the flow to power your steering. The problem will be in the component that determines where the flow is needed. This will be your steering gear. I would recommend ensuring the arm is installed correctly, and there is nothing else binding the steering system. Once you have done this you have isolated your steering gear as the problem.
As for plugging the clutch hole, PLUG IT! on my burb (we're in a long distance relationship right now) I have a factory metal cover with a gasket. it has two screws that hold it on and it seals real good. if you want it, when we see each other again, you can have it!
-Jeremy
Rebuilding an NP205
Old 10-07-2011, 02:20 AM   #2412
heeroyue2002
fat old dude
yeah thats the plug mine has i believe
Old 10-07-2011, 06:18 PM   #2413
67chevy1series
yes 71 72 have these plates
jeremy i got the gear box witht the arm and it was on the frame when i took it off. i wanted to take it off but never got around to it.... the fluid might be a little over, so that could have caused the leaking, and yes i have noticed the cold and hot lines. i dont understand how my truck can steer perfect when its off but when it turns on it doesnt have power steering for the right.
Old 10-08-2011, 12:06 AM   #2414
jbclassix
Junk Yartist
jbclassix's Avatar
So it steers both left and right with the engine off?
And it steers to the left just fine with the engine running?
And it wont steer at all to the right with the engine running?
-Jeremy
Rebuilding an NP205
Old 10-08-2011, 12:21 AM   #2415
67chevy1series
this is how it is,
when ENGINE IS OFF i have manual left and manual right steering just fine.
when ENGINE IS ON i have power steering left and MANUAL steering right.
Old 10-08-2011, 05:04 AM   #2416
slick copper
slick copper's Avatar
Rick, sorry to take up space on your thread, but wanted to ask. On my 67 parts (for sale) truck i found a cig. lighter. I think it's original 67 only. How much are they worth if it's in good shape? I think I saw you had one. Post me a pic of it plz. Thanks buddy!
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 10-08-2011, 03:00 PM   #2417
67chevy1series
no problem raymond, here is a thread with good information on the 67 lighter and it has a pic of all the other knobs to LINKY
Old 10-08-2011, 10:31 PM   #2418
67chevy1series
well i sanded most of the front of the hood and primered it. also got some really really really really good original felt for the driver door.
Old 10-09-2011, 04:02 AM   #2419
1972hays
1972hays's Avatar
Cool Re: slik ricks 67 short wide CST
here are the picks of his hood i took
72 chevrolet 4wd 350/350 swb fleet green mean army machine
1972hays is offline   Reply With Quote
Old 10-09-2011, 04:03 AM   #2420
1972hays
1972hays's Avatar
thats all i had
Old 10-09-2011, 04:04 AM   #2421
67chevy1series
thats better then no pics at all
i sanded the hood again after these pics guys.
Old 10-09-2011, 04:20 AM   #2422
heeroyue2002
fat old dude
rick u can also use your grinder and a flab disc! cuts through all that stuff fast without hurting the metal
Old 10-09-2011, 04:22 AM   #2423
67chevy1series
i used one of these
Old 10-09-2011, 04:31 AM   #2424
67chevy1series
well what should i call the new build thread for the new cab and to finish the rest of this build with... heres some that i thought up:
1. "Ricks 67 project CST"
2. "67 project CST"
3. " Project CST"
4. "Slik Ricks 67 build part II"
5. "Slik ricks 67 part II
6. "Ricks new 67 build"
7. "1967 Chevy project"
8. "1967 Chevy build"
9. "finishing the 67"
10. "phase II of Ricks 67"
which one should it be guys?
Old 10-09-2011, 08:24 AM   #2425
Hubscrub
Cruzin
Hubscrub's Avatar
rick i thought of you yesterday at a cruise in there was an mid 60's black truck with whitewalls and caps on it reminded me of you (pics in my build thread)
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
