#2401 |
![]() Join Date: Aug 2009
Re: What did you do to your truck today part III
Bought more parts
#2402 |
![]() Join Date: Mar 2015
Blasted and painted the rear tow hooks for 3/4 ton 4x4. Now we just have to restore the truck.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
#2403 |
Today I installed a new manual fuel pump. Old one's diaphragm was shot. Tomorrow she gets a re-manufactured carb.
#2404 |
![]() Join Date: Nov 2015
Installed a front sway bar from a '78 1 ton using Energy poly bushings and CPP sway bar mounts. Unfortunately I haven't had a chance to drive it, yet. It was time for Big Brother!
#2405 |
Installed peep mirrors, driver and passenger (convex). Should have purchased convex for both sides.
1964 C10 LWB->SWB, 283->454, SM420->200-4R MECHANIC: "ME" |
#2406 |
https://www.youtube.com/watch?v=1u3UCa-qgSE
Replaced the Raptor mufflers that came on the truck with a set of Thrush welded mufflers. Sound was a reason, but the big thing was I wanted the outlets to be symmetrical and I couldn't get a new Raptor to match the old one. |
#2407 |
#2408 |
Been 2 years since i touched. Charged battery this week and backed outta garage and started on roof and hood again.
#2409 |
Finally drove it on the very curvey roads around here ansd the sway bar makes a huge difference. I don't have to hold on to the door to keep from sliding over anymore! Woo hoo!
#2410 |
Any pics of the seat bar install BP?
#2411 |
I ran out and took a couple of pictures. Disregard the excessive grease and the white lithium grease (stupid creaking spring).
#2412 |
5 speed
1990 Silverado Sport 2010 Silverado K1500 1996 K2500 |
#2413 | |
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
#2414 |
I need a 5 Speed real bad! Running 3200 rpms 70mls/hr 4;10 and 35s with the old 3speed granny no fun!
Its fun in the dirt or on the Rocks.... but its pavement to get there! |
#2415 |
It is a Tremec TKO 500 5 speed. Silver Sport Transmission moved the shifter location to the top of the transmission when I ordered it. It was a fairly simple job. The transmission fit the floor of the truck except the bolt in section. I raised the back of the bolt in section 2 inches. My being a '63 I used the e-brake crossmember for the transmission crossmember and left the bell housing mounts off. A longer speedometer cable and shorten the driveshaft. Your bell housing needs the correct size hole for the transmission.
#2416 |
I used my factory 3 on tree housing for both t5 and TKO 600. I went to the hydraulic bearing with new headers because fork didn't clear them. I was able to rotate the shifter into #2 position with the Porterbuilt stuff moving things forward and up. Also could put a Gear Vendor od and make a 6 speed over/under drive for about same $.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#2417 |
Is elevating the high hump necessary? Reason I ask is because my 66 was a 4 speed with a low hump which the PO butchered up cutting the hole for the shifter so I cut all that out and installed a high hump with the matching firewall section.
Am I going to have to raise the high hump as well? SBC with a TKO 5 speed. thanks.
#2418 | |
#2419 |
Active Member
![]() Join Date: Oct 2009
Spent the afternoon messing with the choke and timing, trying to get the Cadillac 500 to start better when hot.
#2420 |
Finally got the new motor in, vacuum timed and adjusted carb. Got the transmission out of gear. Teed the vaccuum line. Couldn't wait to drive it so I took it to the monthly cruise night with my daughter.
#2421 | |
#2422 |
It's Better With Nitro
#2423 |
Finished painting the front and left side of my engine, and put it back together with all new belts and hoses and gaskets. Still have the oil pan to do yet. Please excuse the overspray on the mounts. When I jack up the engine to do the oil pan, I intent to remove the towers, repaint and install with new mounts.
#2424 |
Four wheel disc brakes...
#2425 |
I went and looked at it at the painters. I should have it back by the end of next week.
