Closed Thread
Old 07-15-2016, 02:02 PM   #2426
Hugh in NC
Hugh in NC's Avatar
Re: What did you do to your truck today part III
Project Fix-a-Leak.
Radiator started leaking around the top seam. The radiator did not look to be in the best condition so I replaced it with an American Eagle 2 row with 1 inch tubes. PO had homemade fan guard/shroud, so I replaced it with a 3 inch chrome unit.
I also had a small oil leak from the back of the intake manifold. I removed the manifold and installed new gaskets. At the same time I installed cast aluminum valve covers and also a new distributor. Got it all finished up this morning for a Friday night and another Saturday afternoon cruise in. Test drive to town and back showed no oil leaks.
Hugh in NC is offline
Old 07-16-2016, 09:03 PM   #2427
T and S
T and S's Avatar
Working on cleaning up the paint, got the tail gate done. First time this has probably ever been done to this truck. Doesn't look to bad for 50 year old paint.
If you don't like this pound sand .....
T and S is offline
Old 07-16-2016, 09:44 PM   #2428
nhgonzo
nhgonzo's Avatar
Birthday present for son, new old stock 19.5 for the c10
1965 c10 cuztom dually build
nhgonzo is offline
Old 07-16-2016, 10:00 PM   #2429
maydaymike
maydaymike's Avatar
I replaced the trailing arm bushings on my '66 with polyurethane. It really tightened up the rear end.
maydaymike is offline
Old 07-17-2016, 01:07 AM   #2430
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Been sand blasting my 66'c cab. More rot repair than I wanted to see but oh well.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 07-18-2016, 12:41 AM   #2431
Kenfuzed
Kenfuzed's Avatar
Scraped out the flooring in my 66. Under the old rubber mats was what looked like tar paper that had baked into the floor. What a #@&% to remove.
Put down some Keep Cool insulation to quiet my tin can. Seems like a good product but after a few hours of using spray adhesive I can see why the other self adhesive products are more popular. At least it was only $60 for the 5x10 roll. I'll probably use dynamat or something similar for the inside of the doors.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline
Old 07-18-2016, 09:50 AM   #2432
robber grin
Drove it!
robber grin is offline
Old 07-18-2016, 11:06 AM   #2433
Figuarus
Figuarus's Avatar
I finally pulled the old rotted plywood out that got "temporarily" installed 20 years ago, and got new thicker and sealed plywood "for now"
the notch on the right side is where my leg went through...
Got the left side in...
finished for now. need to add a piece of strap so I can bolt down the end of the panels.
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline
Old 07-18-2016, 01:25 PM   #2434
Northwest Outlaw
Northwest Outlaw's Avatar
got the trans mount made, able to attach to the t-bar cross member for the th400 and was able to have the engine and trans sitting in and supported by the truck for the first time! also couldn't resist slapping a few on the finished parts on the engine just to get a picture (and vision)
3" lowering spring in the rear to compliment the 2.5" drop spindles in the front.
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline
Old 07-18-2016, 03:50 PM   #2435
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Originally Posted by robber grin View Post
Drove it!
So there isn't a pot of gold at the end of a rainbow... there's a C10. Just as well I suppose. Cool pic!
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline
Old 07-18-2016, 08:53 PM   #2436
rickoner
Worked on fitting up the front tub on the passenger side. I'm happy with the way this one is fitting so far. It's not perfect but it's not bad considering I'm no sheet metal guy. I did the driver's side a while ago, but am not happy with the outcome. So looks like I'm going to have to redo it. Hopefully the inner fender will be salvageable.
[IMG][/IMG]
[IMG][/IMG]
rickoner is offline
Old 07-23-2016, 12:06 AM   #2437
Backpayne
Replaced the rear pinion seal and extended exhaust to dump at rear axle.
Backpayne is offline
Old 07-24-2016, 04:19 PM   #2438
60chevyjim
60chevyjim's Avatar
I put on 4 new wheel cylinders and the three rubber brake hoses and gravity bled the brakes .
I put in a cross flow rad from a V8 Vega .
and I took the truck for the first ride on the street since I put it together .
60chevyjim is offline
Old 07-25-2016, 11:03 AM   #2439
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Installed an MSD ignition control box in my GMC.
Old 07-25-2016, 05:36 PM   #2440
vin63
It's Better With Nitro
vin63's Avatar
Machined the shifter arm and tap base to fit my North Coast Brewing Co. porcelain beer tap for my shifter handle...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline
Old 07-25-2016, 08:47 PM   #2441
65Gregg
65Gregg's Avatar
Started building my wiring harness...
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 07-25-2016, 11:15 PM   #2442
Kenfuzed
Kenfuzed's Avatar
Nice job! I had done the same on the jockey shifter of an old Harley. Most beer tap handles are too long inside the truck but that one fits nicely.
Enjoying the ride!
Kenfuzed is offline
Old 07-25-2016, 11:39 PM   #2443
vin63
vin63's Avatar
Thanks! Yeah, I machined a mini Budweiser tap handle, but even that was still too long...it got in the way of a few things. It was good practice for the porcelain one above.
vin63 is offline
Old 07-27-2016, 06:17 PM   #2444
oldies1938
Installed Vintage Air
oldies1938 is offline
Old 07-28-2016, 04:10 PM   #2445
DLW
Nice.
Any gotcha's on the install?
Did you end up using the kit's heater control valve? I have read that you should use a heater bypass control valve instead on the LS motor's just not sure how important it really is.
DLW is offline
Old 07-29-2016, 08:25 AM   #2446
chevy2tom
chevy2tom's Avatar
[IMG][/IMG]
[IMG][/IMG]
That looks good, what did you use & I'm digging the turbo 6 idea!
chevy2tom is offline
Old 07-29-2016, 05:11 PM   #2447
rickoner
Thanks. The tubs are just a couple regular trailer fenders from tractor supply.
rickoner is offline
Old 07-30-2016, 07:25 PM   #2448
The Rocknrod
Moderator
The Rocknrod's Avatar
Worked on assembling the chassis today and yesterday.
The Rocknrod is offline
Old 07-30-2016, 08:48 PM   #2449
geasson
I just bought a 1966 GMC 1-ton. It is low mileage, the owner says that the 9800 on the odometer is correct. It runs by pouring gas in the carb and today I pulled the tank. UCK, nasty and rusty. Ordered a new tank and sending unit today. I will start a build thread and post some pictures. It is an original stake bed with the original sides.
geasson is offline
Old 07-31-2016, 11:25 PM   #2450
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Unfortunately I did this:
Closed Thread
