07-31-2016, 11:38 PM | #2452 |
Post Whore
Re: What did you do to your truck today part III
Blew a freeze plug. lol And ended up pulling the dang motor because it needed new front and real main seals and new gaskets anyhow. SO I have a new gasket set coming and will take the engine apart and clean all the sludge out and reseal and repaint. Oh, Here is a picture of the clutch and pressure plate. They look fine right?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
08-01-2016, 03:45 PM | #2453 |
Started varnishing my bed wood on Saturday. It started to bubble a little at the surface. Thinking it is because of heat. Will nock it down with some steel wool and give it another coat.
08-02-2016, 09:40 PM | #2454 |
Post Whore
Started painting the 305 v6. Got the oil pan, valley pan, and motor mounts painted up. Waiting on parts so I am gettin her perrtied up.
08-06-2016, 12:26 AM | #2455 |
Post Whore
Getting more done. Valve covers came out better than expected.
08-06-2016, 09:33 AM | #2456 |
Finished up steering - thanks again Captainfab for the adapter plate
08-06-2016, 09:49 AM | #2457 |
got my speedometer cable put in. napa #bk6151606
New wiper arms and blades from oreilys. ya gotta get the "classic" blades got the material cut for the new gas tank. looking forward to freeing up the space behind my seat
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
08-06-2016, 09:53 AM | #2458 |
I got the same radiator. works great so far. found out later that american eagle is another name for champion which has excellent reviews
08-08-2016, 10:57 AM | #2459 |
Post Whore
Yesterday evening:
08-08-2016, 08:06 PM | #2460 |
08-09-2016, 12:26 PM | #2461 |
Bought a power steering conversion bracket!
08-09-2016, 07:46 PM | #2462 |
I finally finished up the wood door to cover the air bag setup and topped it off with a bottle cap opener to use as a handle in opening the door.. it also doubles as the perfect tailgating accessory!
08-10-2016, 04:23 PM | #2463 |
got it back from paint
08-10-2016, 06:01 PM | #2464 |
Poked a 2"x2" hole to use the new shifter.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
08-11-2016, 08:14 AM | #2465 | |
Where bouts are you in NC?
08-11-2016, 04:41 PM | #2466 |
Finally got my tank built and installed. 30 gallon. I think my fuel gauge is bad? Stays pegged at full
08-11-2016, 05:10 PM | #2467 |
Is this just stained plywood? Looks great, whatever it is! I'd like to duplicate.
1964 C10 LWB->SWB, 283->454, SM420->200-4R MECHANIC: "ME" |
08-15-2016, 04:57 PM | #2468 | |
Thanks! |
08-15-2016, 05:59 PM | #2469 |
Moderator
Got the rear end mounted on the trailing arms and on jack stands - Shhhhhhh (don't tell the wife) I'm not supposed to be working on the truck yet (I'm in post op recovery).
08-31-2016, 12:29 PM | #2470 |
I was able to score a Lokar shifter for my th400 on Craiglist, with a set of shorty header (unused) for $75 total!! The shifter didn't have the mount hardware or linkage, so...
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 |
08-31-2016, 01:16 PM | #2471 |
Hi. Finally started back up a month ago and I'm making okay progress. I quit my job in order to work on this truck full time. Moving to Oregon soon!
http://67-72chevytrucks.com/vboard/s...d.php?t=675881 1972 C-10 SWB 1962 3/4 ton LWB 2011 GMC Sierra LML Z71 crewcab shortbed |
08-31-2016, 05:42 PM | #2472 |
Micro buck build looking like a truck again...
08-31-2016, 05:55 PM | #2473 |
RKS, what are those tanks? you have a build page on what you're doing there?
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
08-31-2016, 07:11 PM | #2474 | |
Tanks are from LMC http://67-72chevytrucks.com/vboard/s...d.php?t=675881
09-04-2016, 03:36 PM | #2475 |
Painted black behind the grill, white around the eyebrow, new chrome bumper, grill & bezels plus it's my new wallpaper on my phone
