07-06-2012, 12:36 AM | #1 |
What are the differences between c10, c20 and c30 frames?
...and also are there frame differences between C and K trucks?
Mostly I'm curious about frame size / frame thickness, pictures would be nice. I tried searching and couldn't find anything because there were way too many threads. Also can a 1/2 ton frame safely handle 3/4 ton loads? I have hauled 6200 lbs / 300 lbs tongue with another 300 lbs in the bed with my C10 over the mountains with no anti-sway bar, she was nearly bottomed out but I didn't have any trouble. |
07-06-2012, 01:30 AM | #2 |
Re: What are the differences between c10, c20 and c30 frames?
I have heard people say the 1/2 and 3/4 ton are the same frame but the 3/4 ton has extra bracing to the cross pieces and the 1ton is its own frame.If it was me i would look up what your truck can tow and don't go over it.They do sell a helper air bag that goes inside the rear coil springs that can level your load out for you.As long as you tow smart you should be ok just pray d.o.t. don't pull you over and get out there scales.
07-08-2012, 12:51 PM | #3 | |
Thanks, Chris
Favorite quote: "I'm sick and tired of being sick and tired B¡±@h!" - Drunk guy in one of my accounts Rides: 67 Chevy C10 LWB Stake Bed(in bad shape) 04 Miti Endeavor AWD(wife's ride) 76 Dodge D100 Club Cab(Hand-me down from my Grandfather) |
07-30-2012, 11:10 AM | #4 |
Why not just move the car back a little on the trailer and let the trailer support the weight?
07-31-2012, 02:02 AM | #5 |
Its not the weight balance its the total weight is the problem.If you try to haul more weight then your truck can handle the trailer will end up driving the truck which is never fun and can cause wrecks.
07-31-2012, 10:21 AM | #6 |
It actually is the weight balance that is the problem in the picture. And there is a huge difference in "rolling" and "static" weight. Equip the trailer with brakes and load it correctly and it will take care of itself. I have seen 1/2 ton trucks licensed at 18,000 lbs. I have also seen Surbabans licensed as cars and pulling 18,000 lbs. As long as you license your vehicle to pull the weight you desire DOT will not be a problem. At least not in Missouri.
08-02-2012, 12:17 PM | #7 |
67-72 parts collector,…
Way too much tongue weight on the truck in that picture.
Air bags in place of coils would do a great job of solving this issue,... but you still have to position the car on the trailer in the correct spot.
