Old 02-08-2009, 04:56 PM   #1
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Exclamation 1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's:
Truck Spec/ID
Engine ID
Trans
Axle ID
All Spes and Id's are Blown up to very readable 2336 X 1696 photos!
Worthy of a Sticky !!!!!!!
Click on the Link Below:
http://cid-9169aad55cfc6d79.skydrive...%7C0%20ID%7C4s
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-08-2009, 06:23 PM   #2
Rogue
Airport Bum
Re: 1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
That is awesome, thanks.
I agree, need to sticky
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
Old 02-08-2009, 06:56 PM   #3
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Having a bit of trouble finding the GMC codes.
I don't have a SPID sheet just the VIN #
Where can I find the Serial # on my truck.
Apparantely the VIN is not the same I.D.
Edit:http://67-72chevytrucks.com/vboard/s...d.php?t=316902
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 02-08-2009, 09:31 PM   #4
1Bad62Pro/Street
Thumbs up Re: 1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
* Stamped on a metal plate attached to the top front of the driver's side door frame.
* Stamped on top of the left (driver's side) frame rail, near the steering gear.
However, this stamped number may only contain the sequential serial number.You can decode the VIN at one of the following web pages: http://www.americanclassic.com/paint.htm
http://www.americanclassic.com/paint_test.asp
Also check out www.classictruck.com, I used it on my 62'Chevy. Just click on "Vin Decoder". Type in your vin number, and thats it.
Old 02-08-2009, 09:41 PM   #5
joe231
joe231's Avatar
I can't see any of the pics...
maybe because it is a microsoft site???
I'm running the latest and greatest from mozilla
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-08-2009, 10:39 PM   #6
1Bad62Pro/Street
Last edited by 1Bad62Pro/Street; 03-10-2011 at 11:55 AM. Reason: http://qptwaq.bay.livefilestore.com/y1pizMyURTQJ4PyakKBiC0drBxOiN4dNNuFhV2Ma5kHwltiWZEsm_rnsN1H8nEy9BnyC4zx7GuivEwGHIODaijEJG
Old 09-20-2009, 05:10 PM   #7
1Bad62Pro/Street
Lightbulb Re: 1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
1960 - 1962 1/2-ton and 3/4-ton Chevrolet & GMC - torsion bar front end, coil springs in rear.
The 1-ton and bigger trucks, had torsion bar front end, leaf springs in rear.
1963 - 1966 Chevrolet - coil springs front and rear 1/2-ton and 3/4-ton.
The 1-ton trucks had leaf springs rear, coil springs in front.
1963 - 1966 GMC - leaf springs rear, coil springs in front, 1/2-ton, 3/4- and 1-ton
Canadian Trucks, both GMC and Chevy are the same as US built Chevy.
Historical/This I know/60-66 Model Changes
http://67-72chevytrucks.com/vboard/s...d.php?t=351107
http://67-72chevytrucks.com/vboard/s...d.php?t=327764
1960-66 Chevy/GMC Truck Frame Diagram
http://67-72chevytrucks.com/vboard/s...d.php?t=325736
The 6066 GMC Guy
http://www.6066gmcguy.org/
Old 09-21-2009, 11:56 AM   #8
cliffy
how can you tell what motor the truck originally came with?
my o/l says the truck has a vibration at 65 mph..I said its ok, it goes away at 90.
cliffy is offline   Reply With Quote
Old 09-21-2009, 04:58 PM   #9
1Bad62Pro/Street
Old 09-21-2009, 06:15 PM   #10
cliffy
but that just tells me what motor was avaiable for my truck, not what actually came in it.
I have a 283 in there now but the guy I bought it from says the guy HE bought it from installed it from whatever it had before. Has to be a 235 or 283 I guess...was just curious.
Old 09-22-2009, 06:30 AM   #11
1Bad62Pro/Street
Check the casting # on that 283 to see what year it is.
Also check the Large photos that I uploaded!
Vechicle Serial Number ID.
For Example my Truck is:
2C144N122375
Vin Decoding Results
VIN 2C144N122375
Model Year 1962
Chassis 2 Wheel Drive
Body Style Pickup
Series 1/2-Ton
Assembly Plant Norwood, OH
Sequential Number 122375
1/2-Ton Model Information
Model Description Wheelbase GVW
C1404 Stepside Pickup (6 1/2-ft) 115" 4,600
C1434 Fleetside Pickup (6 1/2-ft) 115" 4,600
C1504 Stepside Pickup (8-ft) 127" 4,600
C1534 Fleetside Pickup (8-ft) 127" 4,600
C1405 Panel (7 1/2-ft) 115" 4,600
C1402 Chassis-Cowl (6 1/2-ft) 115" 4,600
C1412 Chassis-Windshield (6 1/2-ft) 115" 4,600
K1404 4WD Stepside Pickup (6 1/2-ft) 115" 5,300
K1504 4WD Stepside Pickup (8-ft) 127" 5,300
K1434 4WD Fleetside Pickup (6 1/2-ft) 127" 5,300
K1534 4WD Fleetside Pickup (8-ft) 127" 5,300
K1405 4WD Panel (7 1/2-ft) 115" 5,300
K1406 4WD Carryall (Doors) 115" 5,300
K1416 4WD Carryall (Tailgate) 115" 5,300
K1403 4WD Chassis-Cab (6 1/2-ft) 115" 5,300
K1503 4WD Chassis-Cab (8-ft) 127" 5,600
1/2-Ton Engine Information
Code Cyl CID HP COMP Carb Trans
J 6 235 135 8.25:1 1-bbl Manual
JB 6 235 135 8.25:1 1-bbl Powerglide
JC 6 235 135 8.25:1 1-bbl Manual
M 8 283 160 8.5:1 2-bbl Manual
MA 8 283 160 8.5:1 2-bbl Powerglide
N/A 6 261 150 8.0:1 1-bbl N/A
Transmissions
Code Series Description Plant
C N/A Powerglide Cleveland
M N/A 3 Speed Muncie
W N/A 3 Speed HD Warner Gear
S N/A 3 Speed Commercial Saginaw
B N/A Powerglide (Corvair 95) Toledo
1/2-Ton Rear Axle Information
Code Ratio Plant
MA 3.90:1 Detroit Gear & Axle
MB 3.38:1 Detroit Gear & Axle
MC 3.90:1 (RPO) Detroit Gear & Axle
MD 3.90:1 Detroit Gear & Axle
ME 3.38:1 (RPO) Detroit Gear & Axle
MF 3.90:1 (RPO) Detroit Gear & Axle
MG 3.90:1 Detroit Gear & Axle
MT 4.11:1 (RPO) Detroit Gear & Axle
MU 4.11:1 (RPO) Detroit Gear & Axle
1962 Factory Color Codes
Code Description
500 Jet Black
502 Sea-Mist Jade
503 Glenwood Green
505 Woodland Green
507 Brigade Blue
508 Balboa Blue
510 Crystal Turquoise
514 Cardinal Red
516 Omaha Orange
519 Yuma Yellow
521 Pure White
522 Georgian Gray
526 Cameo White
528 Desert Beige
Where is my 60-66 Chevy or GMC vin number?
http://67-72chevytrucks.com/vboard/s...=316902&page=2
Last edited by 1Bad62Pro/Street; 03-10-2011 at 12:36 PM. Reason: http://www.americanclassic.com/paint_test.asp
Old 09-22-2009, 03:47 PM   #12
cliffy
[QUOTE=1Bad62Pro/Street;3531535][B]Check the casting # on that 283 to see what year it is.
ok will do.
Guess what Im thinkin is that someone restoring a vehicle could slide an engine in there from another same year truck and claim the truck is a numbers matching vehicle. But there is no way to tell if its the actual engine, just the same year and size.
Old 09-22-2009, 05:58 PM   #13
1Bad62Pro/Street
Yep! My truck had a 235 inline 6 cylinder in it, but was out of a 65 or 66.
This will help you!
Small Block Chevy Engine Block Identification
http://67-72chevytrucks.com/vboard/s....php?p=3469041
Small Block Chevy Cylinder Head Identification
http://67-72chevytrucks.com/vboard/s....php?p=3416964
Chevy Six Cylinder Casting Numbers
http://67-72chevytrucks.com/vboard/s...d.php?t=356268
Old 09-22-2009, 06:12 PM   #14
cliffy
yeah that will do it, thanks man.
Old 09-22-2009, 06:14 PM   #15
1Bad62Pro/Street
This will help you!
Just as an example here is my truck info:
Old 11-07-2009, 03:34 PM   #16
1Bad62Pro/Street
Transmission Identification
Old 01-20-2010, 12:06 PM   #17
Eagletucky
Where did THAT bolt go?
Eagletucky's Avatar
Can anyone shed any light on how I could identify what type of rear end I have in my 66 GMC Suburban? I'd like to figure out what gear ratio I have without pulling the cover.
Thanks,
The Swiss Car Club......A drinking club with a car problem....
Eagletucky is offline   Reply With Quote
Old 01-20-2010, 12:27 PM   #18
Martin64
Martin64's Avatar
Jack the rear wheels off the ground, mark the driveshaft with a piece of chalk. Turn the rear wheels and count how many times the drive shaft makes a full revolution for every 1 revolution of the rear wheel
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 01-20-2010, 01:27 PM   #19
1Bad62Pro/Street
There should be a tag on there showing the gear ratio. The rear ends have stamped ID's as well.
Raise and support the rear of the truck with jack stands.
Read the metal tag attached to one of the differential cover bolts.
This tag, which is always present (if not removed by a previous owner), will indicate the gear ratio that came with the vehicle originally.
This tag may not be valid if the previous owner has changed the ratio, and you will have to remove the cover to find the gear ratio.
Old 01-20-2010, 04:31 PM   #20
1Bad62Pro/Street
Example:
This is off a Nova.
Old 06-02-2010, 01:57 PM   #21
1Bad62Pro/Street
Arrow Re: 1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
1960-66 Chevy/GMC Truck Frame Diagrams
1960-66 Exploded Views
Thanks to aerotruk63
http://67-72chevytrucks.com/vboard/s...d.php?t=405550
1963 Chevrolet RPO's:
http://67-72chevytrucks.com/vboard/s...d.php?t=405734
1963 Service Bulletins:
http://67-72chevytrucks.com/vboard/s...d.php?t=405567
Old 08-10-2010, 01:26 AM   #22
old_1966_GMC
where can i decode my vin # for my 1966 gmc
old_1966_GMC is offline   Reply With Quote
Old 08-10-2010, 05:42 AM   #23
1Bad62Pro/Street
Vin Number query:
http://67-72chevytrucks.com/vboard/s...d.php?t=402078
Old 09-09-2010, 11:05 PM   #24
brawley
Easy Does It
brawley's Avatar
I have a question about the rear end codes. According to the tech sheet there are letter codes ex. WA or WC that tells the ratio, Where do you find that stamped code, I have looked all over mine and cannot seem to find it???
brawley is offline   Reply With Quote
Old 09-09-2010, 11:16 PM   #25
brawley
Easy Does It
brawley's Avatar
I have one more question about the rear axels when it says (exc. positraction) what does the exc. stand for?
