Old 07-13-2017, 07:47 PM   #1
GMDad
GMDad's Avatar
Wiring harness grommet
Just a quick question. Need the grommet that snaps into the rad support and holds the plug for the headlight harness in place. Looked thru LMC catalog and on their site but missed it or will it need to be ordered else where?
GMDad is offline   Reply With Quote
Old 07-13-2017, 08:56 PM   #2
Clyde65
Clyde65's Avatar
Re: Wiring harness grommet
I believe they only come on the harness.
http://www.classicparts.com/mobile/1.../#.WWgWLoVOmaM
You can also contact a guy with hotrod wires, he may know where to find them new.
http://www.hotrodwires.com
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-13-2017, 10:31 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Wow, they have grommets: http://www.americanautowire.com/shop/nsearch/?q=Grommet
Old 07-13-2017, 11:35 PM   #4
GMDad
GMDad's Avatar
Trying to remember what it looked like. The # 500563 from American Autowire seems to look familiar.
Old 07-14-2017, 12:10 AM   #5
Captainfab
60-66 Nut
The rubber end on the headlight harness fits into the hole in the radiator support and the harness on the other side just plugs into it. No grommet needed.
Old 07-14-2017, 02:35 PM   #6
GMDad
GMDad's Avatar
Thank you. Boy do I feel stupid. I had the rad support on and the inner skirts just to wire things up enough to fire up the new motor and saw the headlight plug laying loose but too small for the hole in the rad support. All the wiring is left on my grille and lo and behold the grommet is there like you said and all I will need to do is plug in to it.
Thanks again
