Old 04-21-2009, 10:41 PM   #1
GRIMSS
GRIMSS's Avatar
Goodies showed up today.
Big brown showed up with 4 boxes of parts from Scott’s. Complete Super Slam kit. Now I need the rear 4 link to show up so I can get started.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 04-21-2009, 10:54 PM   #2
sgtusmc
sgtusmc's Avatar
Re: Goodies showed up today.
Some guy's have all the luck. Screw the brown truck..It never drops any good stuff at my door! Looks like you've got a whole lot of nice stuff going on there.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 04-21-2009, 11:59 PM   #3
Kim57
Kim57's Avatar
Nice looking stuff. I love it when I see the big brown truck also.
Kim
Kim57 is offline   Reply With Quote
Old 04-22-2009, 10:25 PM   #4
pgf545
pgf545's Avatar
I Love getting new stuff....especially stuff for my toys...better than Christmas!!!
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 04-23-2009, 09:47 AM   #5
57ToyBox
57ToyBox's Avatar
SWEET !!! love those adjustable control arms.. NICE
What air ride system are you going with? or U just piecing your own system together?
57ToyBox is offline   Reply With Quote
Old 04-23-2009, 06:16 PM   #6
GRIMSS
GRIMSS's Avatar
Right now I'm working on getting a roller. Front will be the above IFS from Scott's Hotrods. It's their superslam kit. The rear is going to be a superlift triangulated 4link for suicidedoors. As for valves and the other stuff, no clue yet. For now just basic to get it rolling.
2001 GMC SIERRA
1968 Camaro
Jared
Old 04-23-2009, 10:49 PM   #7
57ToyBox
57ToyBox's Avatar
Nice choice on the air ride system. I p/u a system on Kijiji but later changed my mind on the system.
Decided to go all new and a complete system w/suspension.
my old air ride is on ebay right now.
Too bad I could have helped you with the Air manifold, regulators and air lines.
http://i87.photobucket.com/albums/k1...IMG_0725-1.jpg
Old 04-24-2009, 02:08 AM   #8
cajundragger
sweet, i know your excitement exactly.
hopefully you told them you want it setup for max travel, otherwise you don't get too much. I think I have right at 9", but I need more, supposedly its just switch out upper ball joints and I get more lift. we'll see.
if you need valves and air management stuff holler at me and I'll see what I can do.
cajundragger is offline   Reply With Quote
Old 04-24-2009, 07:26 AM   #9
GRIMSS
GRIMSS's Avatar
I told Justin what I was wanting. Around a 5" rocker ride height. So hope that was noted. He said that this setup they get 10-11" travel. This setup is a little different than the AD trucks. Mine goes to the inside of the frame. He said that I'll need to z it a little.
I'll PM you.
2001 GMC SIERRA
1968 Camaro
Jared
Old 04-24-2009, 11:35 AM   #10
Scottshotrods
On your ifs as I was saying we have a different ball joint that will give you
more travel.If you want I will send you 4 ball joints to you and you can
press them in and then you can see how they work.If you are happy with
them call me and then you can take care of it with us.
Justin
wwwscottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 04-24-2009, 11:45 AM   #11
Scottshotrods
I'll PM you.
Jared,
On your ifs as you are saying the crossmember does go to the inside of your
frame.This is done so we can get a longer a-arm and more travel and your
set-up is getting over 10 inches of travel.
On cajuns truck his crossmember goes to the outside of the frame.The
reason for this is to keep the lower pivots in line with the pivots on the
rack.On his truck his inside to inside is narrower than your inside to inside
of the frame.This is the reason why they are differnt and your ifs it has
the newer ball joint that does get more travel.At the time cajun made his order with us we did not have the newer balljoint.Hopefully both of you guys
understand this and this helps you guys out.
Justin
Old 04-24-2009, 05:15 PM   #12
GRIMSS
GRIMSS's Avatar
That's cool Justin. I was just stating that they were a little different setups and glad to know on the ball joints.
2001 GMC SIERRA
1968 Camaro
Jared
Old 04-24-2009, 05:28 PM   #13
GRIMSS
GRIMSS's Avatar
The rear parts came today also.
2001 GMC SIERRA
1968 Camaro
Jared
Old 04-26-2009, 10:28 PM   #14
CAL 58 GMC
CAL 58 GMC's Avatar
Cool stuff!!!
CAL 58 GMC is offline   Reply With Quote
