11-29-2017, 08:52 PM | #1 |
Fuel tank vent question
I recently installed an under bed fuel tank( top fill) I purchased from LMC. It has port that is supposed to be for a return line for Fuel Injection. Question is, does that need to be used as a vent for the tank, or does the tank vent thru the gas cap.
Thanks P.S. I'll post up some pictures of the tank and some other stuff tomorrow. |
11-29-2017, 09:45 PM | #2 |
Re: Fuel tank vent question
I would (and did) install a vent line with a loop in it for rollover protection. I put a small filter on it to keep bugs and mud dabblers from fouling it.
292 + TKO500 |
11-29-2017, 10:57 PM | #3 |
It's Better With Nitro
I would do a vent line at least the same size as your supply line. I had to install a couple of extra ports for high and low pressure returns and a vent with a filter so that it's EFI ready. I run a rollover ball vent fitting.
11-29-2017, 11:50 PM | #4 |
Moderator
It's easier if your just using a carburetor system then yes use a rollover valve and tube it away. I prefer out and up with a loop or 90 in it for rollover protection.
12-12-2017, 12:23 AM | #5 |
What style of Rollover Safety Valve did ya use? Was it necessary to do any metal fabrication to install the unit? Any photo's - Suppliers - Part numbers.....
Thanks in advance. |
12-12-2017, 07:51 AM | #6 |
Moderator
Mine came with the tank but I did some mods see post #157 - http://67-72chevytrucks.com/vboard/s...=666226&page=7
12-15-2017, 11:00 AM | #7 |
12-15-2017, 11:27 AM | #8 |
Moderator
12-16-2017, 10:55 PM | #9 |
http://www.tanksinc.com/index.cfm/pa...prod/prd98.htm I put this in there.
12-16-2017, 11:32 PM | #10 | |
12-17-2017, 12:48 AM | #11 |
Thanks for the info and location Idea.....
