Old 07-25-2020, 08:48 PM   #1
Greasey Harley
Greasey Harley's Avatar
"that motor ran great before I pulled it"
I was told, "You could probably re-seal it and run it, just the way it is"
Sure glad I didn't do that.
Not really a problem, it is still a good core, and that's what I bought it for.
You never know, 'til you tear 'em down.
Greasey Harley is offline   Reply With Quote
Old 07-25-2020, 09:21 PM   #2
PGSigns
PGSigns's Avatar
Re: "that motor ran great before I pulled it"
If I don't see it run or apart I assume its a core plus what ever may be bolted on the outside. It may have run good but what was the standard for good? I always like the ads that say corvette motor. Never new there was so many of em. That one has had a hard life.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-25-2020, 09:32 PM   #3
truckster
truckster's Avatar
Just like, "Ran when it was parked."
I was just going to put a used Vortec in my Blazer. My wife insisted I should rebuild it. I'm glad I listened to her.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 07-25-2020, 09:41 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Ya that "Ran when it was parked." Phrase to me usually means "run forrest".
Old 07-25-2020, 10:03 PM   #5
vince1
A spare top ring and you're good to go. Don't forget to unstick the oil ring.
A guy came by and picked up my old 250. He even gave me a hundred bucks for it and cleaned a lot of scrap out of my garage.
vince1 is offline   Reply With Quote
Old 07-27-2020, 03:10 AM   #6
wixthedog
wixthedog's Avatar
Jimmy
I agree, I was once bitten by the "it ran great when pulled" deal and never again. Unless I have intimate knowledge of the car/engine or was able to test it before pulled its a core to me.
Mike
1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop
Obligatory Build Thread HERE!
1979 C20 RCLB - 350 - TH350 Auto
wixthedog is offline   Reply With Quote
Old 07-27-2020, 09:39 AM   #7
Ziegelsteinfaust
My friend is on his 3rd ran when stopped motor he has bought in the last year or so.
Ziegelsteinfaust is offline   Reply With Quote
Old 07-27-2020, 11:57 AM   #8
kwmech
What does the cylinder wall look like?
Old 07-28-2020, 01:51 AM   #9
Greasey Harley
Both heads were cracked
Crank was toast
a few broken rings
...Cylinders all looked good
The block is at the machine shop, getting hot tanked and mag checked.
Old 07-28-2020, 12:38 PM   #10
gmc684x4
My 69 i blew the top on 2 pistons it still ran when parked just could not do highway speeds or climb a hill
gmc684x4 is offline   Reply With Quote
Old 07-28-2020, 10:08 PM   #11
Captainfab
60-66 Nut
If you are wanting a set of stock heads, I have a few sets here you can have before I haul them to the scrap yard.
Crank was toast
a few broken rings
Old 07-31-2020, 12:21 AM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have never bought a used engine that i didn't intend of fully rebuilding.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-31-2020, 08:53 AM   #13
TrybalRage
*nervously looks at the LM7/4L60E I just tossed in*
1985 C10 Silverado LWB LS Swapped! Other Stuff
2010 Suburban 2500 LT 4WD
TrybalRage is offline   Reply With Quote
Old 08-08-2020, 01:42 AM   #14
toolboxchev
[QUOTE=The Rocknrod;8781890]Ya that "Ran when it was parked." Phrase to me usually means "run forrest".
Yeah, life is like a box of chocolates!
toolboxchev is offline   Reply With Quote
