10-29-2009, 02:04 PM | #1 |
Heater Control Replacement or Repair
The heater control from my '72 either needs to be rebuilt or replaced. I'm curios as to other members experience with the quality of the after market units. Mine probably could be repaired with a little work. The rivets that hold the bracket for the cables have broken off and the defrost lever is broken. The catalogs I have vary in price from $80 to over $100. I really care more about the final look then the cost.
Blayne |
10-29-2009, 02:15 PM | #2 |
Grandpa in the rustmobile...
Re: Heater Control Replacement or Repair
mine did same, i drilled little holes in the potmetal and put nice lookin little bolts from home depot in
it helped alot, i also put graphite down in the cables im in school but will try to reember to post a pic wen i get home it looks good too!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-29-2009, 02:24 PM | #3 | |
I replaced the whole heater control unit with one from LMC and was quite happy with it. After I did that, I decided not to drill it out, but instead just left the middle cable disconnected. If you look where the butterfly valve is that it connects to, it's right under the heater box. I could flip it over by hand with no problem. You can leave this one flipped open and still shut off the heat when necessary with the bottom lever. I suppose a third option would be to figure out how to rerun the cable (maybe with a longer one?) so that the bend is not so extreme. |
10-29-2009, 03:25 PM | #4 |
Toss it all. The levers for "Heat > Def" and "Hot > cold" are with in reach. Right in the middle bottom of the dash.....And the Fan just run a toggle. Last for ever. Less parts the better.....
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
10-29-2009, 03:25 PM | #5 |
The Older Generation
I bought a heater control repair kit. It had the new levers and a decal sheet for the face of the unit. I drilled holes all the way through the face and countersunk the holes on the front panel. I then put small flat head bolts in to hold it all together and applied the new decal to the front. Use the smallest bolts you can and when you countersink the holes keep trying the flat head bolts and stop when the heads are flush with the surface. I had really good luck with this and you can't tell it was repaired. LockDoc
10-29-2009, 03:46 PM | #6 |
Watch out for your cornhole !
Here is what he's talking about. I did all four with countersunk screws. Then, you can use the aftermarket decal kit to cover this up for an original looking, permanent repair.
The aftermarket kit also comes with the new levers to replace your broken ones too. I just made new levers out of flat steel.
10-29-2009, 04:44 PM | #7 | |
10-29-2009, 06:27 PM | #8 |
When you're poor you have to improvise.
10-29-2009, 08:10 PM | #9 |
I am a Referee of life.
I rebuilt mine with the kit.10 years and it still looks and works good.The cables seem to cause more problems from lack of lube than the way they are run.Take them out and hang them up so the lube runs down thru the cable.Or toss them in a drain pan when you change oil.
I taped off and painted my face but then I am not a purist as far as originality goes.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-29-2009, 08:38 PM | #10 |
I rebuilt mine with the "unbreakable" ones from GMCPAULS (I think). I also lubed my cables with drip triflo. Cleaning out the needles, leafs, and mouse packed insulation behind all of the flapper dampers also keeps things moving better.
Everything works much better now.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
10-29-2009, 09:30 PM | #11 |
I bought a rebuild kit from LMC. I guess it is alright. I didn't use the decal. Didn't like the look of it. My rivets were broken too. Now I know why they broke. But the fix on my truck was not as pretty. Two screws on one side of the bracket. If I had to do it again I would have gotten the complete kit.
68 GMC 91 GMC ext cab 05 Dodge Ram SRT-10........gone but not forgotten |
10-30-2009, 10:56 AM | #12 |
Thanks for the responses.
Would it possible to weld the bracket to the face plate? With the rivets drilled out there should be enough surface area to get a decent weld. Since the sticker goes over the front you wouldn't see any burn through on the front.
Blayne |
10-30-2009, 11:57 AM | #13 | |
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-30-2009 at 11:58 AM. |
09-20-2017, 11:23 PM | #14 | |
Junior Member
