10-04-2017, 08:09 AM | #26 |
Re: 1972 SWB Build
What would the proper crimpers be? Weatherpak? I've done some audio stuff, but I'm no one's electrical genius.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
10-04-2017, 11:26 AM | #27 | |
Re: 1972 SWB Build
You can rent them from AAW or purhase a Delphi Packard crimper. They make really nice crimps. I borrowed the pair from a buddy. |
10-07-2017, 10:49 PM | #28 |
Re: 1972 SWB Build
Got to spend a little time on the truck today. I was able to finish up cleaning the truck arms and some brackets. The cross members wouldn't fit in the blast cabinet. I'll have to drop them off to be blasted. Coated the parts in Chassis Saver. Most likely going to put a top coat of roll bar paint to give it flat look.
10-13-2017, 03:44 PM | #29 |
Re: 1972 SWB Build
Parts are staring to arrive
10-18-2017, 12:31 PM | #30 |
Re: 1972 SWB Build
More parts arrived today. I am starting to get pumped for the winters project!
10-18-2017, 06:02 PM | #31 |
Re: 1972 SWB Build
What will be your ride height end up being with the Streegrip kit?
1970 C10 Short Stepper with 71/72 front clip. |
10-18-2017, 06:04 PM | #32 |
Re: 1972 SWB Build
10-18-2017, 07:27 PM | #33 |
Re: 1972 SWB Build
Nice work so far. You cant go wrong with red and white with a 6.0 swap.
10-18-2017, 08:44 PM | #34 |
Re: 1972 SWB Build
Looks fun, I'll be tagging along.
10-19-2017, 09:24 AM | #35 | |
Re: 1972 SWB Build
Thanks! It's a slow process. I have two kids that keep me busy, so it's about an hour at a time. |
10-19-2017, 10:27 AM | #36 |
Re: 1972 SWB Build
Cool truck, and I like the direction you're headed with it.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD) Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712 |
10-19-2017, 12:47 PM | #37 |
Re: 1972 SWB Build
Mmmmm, yummy parts. We'll need a report on those shocks.
10-20-2017, 10:07 AM | #38 |
Re: 1972 SWB Build
Thanks!
10-20-2017, 11:16 AM | #39 |
Re: 1972 SWB Build
Beater...what's the part number on the ridetech shocks?
10-20-2017, 11:35 AM | #40 |
Re: 1972 SWB Build
10-20-2017, 02:09 PM | #41 | |
Re: 1972 SWB Build
Thanks again...
10-31-2017, 10:13 AM | #42 |
Re: 1972 SWB Build
Between Soccer, fall ball and birthday parties, I have had zero time to work on the truck. I was able to blast, clean up and get a coat of chassis saver on the the cross members. I've scuffed them and they are ready for top coat whenever I can find a few minutes. I'm hoping to get some time this weekend to get the truck up on jackstands and start disassembly, hopefully...
11-21-2017, 11:45 AM | #43 |
Re: 1972 SWB Build
Progress has been extremely slow. I was able to "dig" out the bed bolts. 3 layers of spray in bed liner. That was fun. I also started on a bed cart for when I remove the bed.
All of the parts and cleaned and painted. All that is left is to start disassembly of the truck. I am hoping this weekend I can find some time to get the bed off and start tearing in to this. I've got an old YouTube channel that I am going to revive and document the entire process. There is not a lot of information out there about the conversion from leaf to coils. Should be a fun little project. Thanks! |
11-21-2017, 03:12 PM | #44 |
6>8 Plugless........
Re: 1972 SWB Build
At least you're making progress. I'm sure digging those bed bolts out is pure fun.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-22-2017, 11:00 AM | #45 | |
Re: 1972 SWB Build
The bed bolts took about 3 hours with a drywall blade. It was tedious. The PO took the bed off with the bolts in place. That had to have been a nightmare putting the bed back on. All but one of the bolts where bent, so I'd imagine it was a nightmare. I took my time to minimize the cutting so the new bolts don't look too bad. We shall see what it looks like upon reassembly. |
11-28-2017, 12:30 AM | #46 |
Re: 1972 SWB Build
Well, I was able to get the bed off and rear end out this weekend. It ended up being a little father son bonding time with my dad. I made a little video about it as well. This weekend I am going to remove all of the rivets, clean up the frame a bit and start laying out holes for the coil spring crossmember and track bar crossmember.
Thanks! Nick https://youtu.be/k1tx_uXx6bw |
12-04-2017, 12:29 PM | #47 |
Re: 1972 SWB Build
Made a little progress this weekend. I was able to remove the exhaust, shock mounts, and some funky brackets someone welded to the frame yesterday. I ran out of time, but it's ready to start putting back together. I'm going to bolt the trailing arms in as well as the axle to approximate locations for the cross members and start measuring and drilling!
I have not removed the leaf spring mounts yet. I'm going to remove them last. I left them on just in case I needed to move the truck for some reason. It's easy to bolt the leaf axle back in. They'll be gone this week. |
12-11-2017, 12:34 PM | #48 |
Re: 1972 SWB Build
Good morning all. I was able to spend some time on the truck yesterday. I bolted in the trailing arm brackets and tailing arms and attached the rear end to help verify the location of the shock crossmember and bolt in c-notch.
The shock crossmember is bolted in on the bottom side. I've got to figure out how to transcribe the top bolt holes to the top flange of the frame. The c-notch lines up perfectly. I was using a frame dimensional drawing that I found on the forum (forgive me, I can't for the life of me remember the user who posted this) to locate the crossmembers. I triple checked the shock crossmember center line and went to drilling. Much to my amazement, it lined up perfect! I ran out of time and had to call it quits, but it's slowly coming along. Next up is finishing the top holes on the shock crossmember, drilling the holes for the frame stiffener and drilling and cutting the notch in. After that, all that is left is locating/bolting in the panhard bar crossmember and installing all of the ridetech parts. Here is the video I made of what was done this weekend: https://youtu.be/BXHq3jkOqTA Thanks! |
12-11-2017, 03:58 PM | #49 |
Re: 1972 SWB Build
Upon further investigation, the frame is far from square from the factory. There is almost a 1/4" variance in the some of the measurements I am getting. I am going to slot the holes in the cross member to get it as close to square and I can with the axle. I had a hell of a time getting the crossmember to center up between the frame rails yesterday so it's about an 1/8" out of center, nothing a couple of slots won't fix.
12-11-2017, 08:05 PM | #50 |
Re: 1972 SWB Build
Nice progress. Removing the bed that way was pretty handy.
