Old 08-27-2019, 10:07 PM   #1
Old_iron
Is this supposed to happen with a transfer case?
I am trying to get the front drive shaft to rotate freely.
Here's what I did. I jacked up the front end so both wheels are off the ground, and locked both hubs. I put the trans AND the transfer case in neutral. When I rotate one of the wheels, or try to rotate the front drive shaft, it moves a little then stops. Like its engaged in the transfer case.
It has a np205 behind a sm465, truck 4 speed manual trans.
The truck is not yet running, and I am trying to test the transfer case. As far as I know it worked before.
Am I misunderstanding how it is supposed to work? What am I missing?
1968 GMC 3/4 Ton 4x4 K20 / 2500
1971 Chevrolet Chevelle Malibu
Old_iron is offline   Reply With Quote
Old 08-28-2019, 12:02 AM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: Is this supposed to happen with a transfer case?
In nuetral I believe the 205 is still locked in 4x4 correct me if I’m wrong.
*edit I was wrong!
I rebuilt my 205 last year and if I remember right All neutral does is unlock the input shaft from the rear output shaft but the front output shaft stays locked to the rear output shaft AKA 4x4 so with the rear tires still on the ground the fronts won’t turn. Put it into 2 high and your front shaft should unlock inside the case. Clear as mud???
It’s been a minute since I messed with mine sorry I got you pointed in the wrong direction.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 08-28-2019, 01:54 AM   #3
kwmech
It should spin freely even in 2wd, sure it's a 205?
Old 08-28-2019, 10:33 AM   #4
Old_iron
Pretty sure. Here is a picture.
Old 08-28-2019, 10:33 AM   #5
Old_iron
I'll give that a try after work today.
Old 08-28-2019, 10:40 AM   #6
kwmech
Yup, 205. front shaft is neutral until it goes into 4lo or 4hi. 2wd, front shaft is still neutral and should be able to spin front shaft with hubs unlocked.
Old 08-28-2019, 10:47 AM   #7
MJN
MJN's Avatar
So you locked both hubs and the t-case is in neutral, are you sure there isn't anything wrong inside the front differential? Does it have a locker/posi front diff? The driveshaft will be free to spin with the t-case in neutral or 2-hi as long as the hubs are unlocked. If you want to rule out the t-case then unlock your hubs and try to spin the driveshaft in neutral and 2-hi. If you haven't already- pop the differential cover off and check things out. If it all checks out, you're only out your time and a few bucks for fresh gear oil.
In your picture you have a NP205.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 08-28-2019, 02:03 PM   #8
LagunaGlide
I would put in 2hi and then remove the front drive shaft. With front wheels off the ground they should spin with hubs locked or unlocked; I Would try it both ways. The front shaft should be able to be spun as well.
LagunaGlide is offline   Reply With Quote
Old 08-28-2019, 07:20 PM   #9
Old_iron
I just went out and jacked the front up and tried all the combinations. Hubs locked, unlocked. Tcase in neutral, 2h, etc. The front diff is good, I checked it out thoroughly before installing it.
Any ideas?
Old 08-28-2019, 10:39 PM   #10
El Dorado Jim
sub'd
El Dorado Jim is offline   Reply With Quote
Old 08-28-2019, 10:40 PM   #11
El Dorado Jim
Any ideas?
I have no idea what could be wrong, it should spin free if you have the hubs unlocked and its in neutral
Old 08-28-2019, 11:56 PM   #12
57taskforce
All about them K’s
Make sure the front output shift rail is moving back and forth when you operate the shifter, there’s two rails that shifter handle controls, on is low/high and the other engages and disengages the front output shaft. If the rail isn’t moving it could be as simple as the fork or rail being gummed up or something could be broke too. The linkage bar that controls the rails could be worn too. Mine was, I had to weld the holes up and re-drill them.
This link should help you understand what’s going on in there.
http://67-72chevytrucks.com/vboard/s...d.php?t=469726
Tyler
Old 08-29-2019, 05:08 AM   #13
jkeady
jkeady's Avatar
So is this an open diff (as was asked already)? Because if the front diff is doing it’s job, you should be able to turn one front wheel and the opposite side will counter rotate with both tires off the ground. With only one wheel off the ground, turning that wheel will transfer motion back to the front drive shaft.
With hubs locked, both front wheels off the ground and free to spin (no seized brakes, bearings, etc), open differential, the state of the transfer case does not matter at all: you should be able to spin one front wheel if the differential is doing its job.
Josh
'70 Custom Camper / 20
jkeady is offline   Reply With Quote
Old 08-29-2019, 08:20 AM   #14
Old_iron
Yes it is an open diff, and yes performs as you describe.
I am trying to figure out why the transfer case is no ot allowing the front drive shaft to spin as expected. I'll look at the linkage later today.
Old 08-29-2019, 08:47 AM   #15
Bigdav160
Bigdav160's Avatar
Are you sure your hubs are unlocked? Just turning the knob doesn't ensure they are unlocked.
Wheels off the ground and spin the front tires? What happens? Front driveshaft should not be spinning.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-29-2019, 12:28 PM   #16
jeffahart
jeffahart's Avatar
This ^^^ You need to understand what mode you are in, and this is verified by unhooking the shift linkage and pulling the shift rails in and out to proper combinations for neutral, 2H 4H ect... Then you can see if it's the shift mount/linkage or an internal rail problem. Verify this first... else, you're just poking at it!
j
White K20
jeffahart is offline   Reply With Quote
Old 09-03-2019, 06:38 PM   #17
Old_iron
I discovered the problem. The front drive shaft is binding due to the 4" spring lift installed last year. Attached are some pictures showing the worst that the problem is with the axle in a certain position. Also showing the impact points at the joints.
As you can see it's not even close. Everyone said that the front axles are fine for a 4 inch lift. Maybe the 68 GMC K20s are different, possibly because it had a very heavy V6 in it stock which made it ride lower??
What do I do? Grind some relief into the yoke parts? Find a different driveline from a later model?
Old 09-03-2019, 07:36 PM   #18
jeffahart
jeffahart's Avatar
Looks like the last photo is the 205 output side. Should be a CV. Can you photo the whole shaft. It should be a slip shaft with a CV to 205 output. I don't think the lift is your problem, I think it's your shaft.
j
White K20
Old 09-03-2019, 10:05 PM   #19
Old_iron
Here is a picture of the whole thing.
Side note, when I bought the donor front diff, it had this front driveshaft yoke attached to the input. It though it was just a newer style than the shaft on the truck but not functionally different. I didnt have the rest of it anyway. I just bolted it up to the diff and compared the range of motion. It has more than enough.
So... I guess I need to find the rest of that style driveshaft? Anyone know years that will fit?
Old 09-04-2019, 09:24 AM   #20
MJN
MJN's Avatar
The lift isn't the issue. Your driveshaft is missing the CV portion that mates to the transfer case. The slip joint should be at the differential not the transfer case. It should look something like this photo.
'17 GMC Yukon XL
VCCA member #58596
Old 09-04-2019, 11:18 AM   #21
jeffahart
jeffahart's Avatar
It's not necessarily a year thing. Call around to junk yards and ask for a - 1310 2" CV slip shaft. 1310 is the ujoint. Measure carefully. if the shaft is too short and you jam on the breaks, you can run out of slip and jam transfer to the front diff. Or you can by new for about $350
j
White K20
Old 09-04-2019, 07:15 PM   #22
El Dorado Jim
try turning the shaft around, slip yoke towards differential, may help, or you may have to go with the cv joint style , that shaft looks bigger in diameter compared to most ive seen on the front
Old 09-04-2019, 08:33 PM   #23
Old_iron
Bingo. I flipped it around the right way. It turned freely until I just finished snuggling up the u joints. Then it just so slightly bound, at the transfer case yoke. I think if I grind just a little off here that will fix it. Any reason not to do that?
Old 09-04-2019, 08:53 PM   #24
MJN
MJN's Avatar
If you had the CV joint portion it wouldn't bind and you wouldn't have to grind the yoke either. Why not fix it correctly with the correct parts?
'17 GMC Yukon XL
VCCA member #58596
Old 09-07-2019, 10:48 AM   #25
57taskforce
All about them K’s
Did these trucks come with a cv from the factory? Mine definitely doesn’t have one. I know square bodies did.
Tyler
