01-30-2022, 10:33 PM | #1 |
Front engine crossmember for K20 suburban
Anyone know where I can find an engine crossmember for a 4 wheel drive suburban?
1972 GMC long bed 1967 GMC long bed 1970 Chevrolet CST shortbed 1967 Chevrolet K20 suburban 1957 Chevy 4x4 1/2 ton |
01-30-2022, 10:59 PM | #2 |
landarts
Re: Front engine crossmember for K20 suburban
For which motor are you going to install? Eight cylinder motor or 250 6 cylinder takes a specific crossmember and mounts. If going with 292 6 cylinder then it takes a different crossmember and mounts. If you are going to do a LS swap then that takes a different one available from after market suppliers.
Post what motor you are trying to install and someone will probably have one to sell or can point you in the right direction.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
01-31-2022, 01:26 AM | #3 | |
The Older Generation
You can check the "Blazer and Suburban Stuff" classifieds. You can't post a Want To Buy but if you see one for sale you can buy it. Probably the best thing to do would be to get a Premium membership. http://67-72chevytrucks.com/vboard/payments.php Then you could post a WTB on there. It may be pretty hard to find, not sure. Is yours bent? LockDoc
05-15-2022, 12:10 AM | #4 |
Are all V8 engine mounts the same on suburban? 2WD vs. 4WD? 307/350?
05-15-2022, 10:35 AM | #5 |
I am pretty sure the mounts that bolt to the engine are the same. The frame crossmember is quite different 2WD vs 4WD.
I've read that some change the crossmember out from a square body 4WD to get clamshell engine mounts and sway bar mounts.
