Old 01-13-2018, 03:49 AM   #1
Swedchevy67
Transmission cooler line setup
I’m not a technical guy in any way ( at least
building cars). But I recently got this passion
for old American trucks, so I bought one from y
and got it delivered to Stockholm. The first thing
I noticed was that it was too tight between the
steering and the seat. I almost couldn’t fit.
What the heck did I buy!!!!! So I started doing
some research one how to make it “modern “.
The progress is doing well, and now I just finished
setting the hydraulic cooler hoses.
I need some positive feedbacks (negative also
respected)
Swedchevy67 is offline   Reply With Quote
Old 01-13-2018, 07:58 AM   #2
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: Transmission cooler line setup
It looks good to me, provided the inner line isn't too close to the exhaust. I just put headers on my old Buick and I'm debating between soft lines and bending up some copper-nickel.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 01-13-2018, 08:23 AM   #3
Swedchevy67
I see what you mean. I read that the hoses
need a distance of 6” from the exhaust.
Too be secure I mounted my headers to be
sure, and I’m satisfied with it. Thanks for the
input.
Old 01-13-2018, 08:24 AM   #4
Swedchevy67
input.
I wouldn’t use copper lines, I believe the
oil is too aggressive
Old 01-13-2018, 10:39 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Transmission cooler line setup
Personally I would run hard lines from the radiator to the transmission use the rubber hose for both ends to connect it. Run the lines up in the frame rail and hide them out of sight. The hard lines will be much smaller also which will give you more room.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-13-2018, 10:49 AM   #6
notsolo
notsolo's Avatar
Looks good I like the custom separation brackets, also you may need to protect the hoses once the inner fender is in place. What was your solution for interior modern updates? Custom seat, and steering wheel changes?
notsolo is offline   Reply With Quote
Old 01-13-2018, 06:50 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Will the inner fender still fit?
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 01-13-2018, 08:34 PM   #8
Swedchevy67
Yes, new power steering, fuel tank in the frame, hydraulic brake, automatic transmission, new seats (Volvo, I need some Swedish parts)
Old 01-13-2018, 10:28 PM   #9
JMC1965
JMC1965's Avatar
Definitely want to see the pics of Volvo seats in the truck.
JMC1965
1967 C20 LWB
  • 350 (ATK-HP32) / FiTech EFI
  • 4L60e / 4 wheel disc brakes
  • 20" American Racing VN327 & 245/50/20 Michelin
JMC1965 is offline   Reply With Quote
Old 01-14-2018, 08:26 AM   #10
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Gary
That's what I was wondering...? Other than that, I kinda like it. But I would never run without those inner fenders...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-14-2018, 11:37 AM   #11
aerotest
I would just put some DEI reflective sleeves on the lines where they are close to the exhaust. They make it with Velcro so you won’t have to disconnect the lines. I have used this stuff with success on turbo cars at much closer proximety.
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust)
aerotest is offline   Reply With Quote
