12-07-2013, 07:36 PM | #1 |
68 Steering wheel parts
Well took my wife for a ride in "Hanna" today and she decided that I should keep the 3 spoke 68 steering wheel instead of buying a 69-72 wheel. Now I need to fix the horn in the 68 wheel.
I've researched and I'm trying to figure out if the 68 horn guts are the same as the 69-72 guts. One set of posts says they are and another set says they aren't http://67-72chevytrucks.com/vboard/s...d.php?t=391037 http://67-72chevytrucks.com/vboard/s...d.php?t=561126 Which is it? Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
12-11-2013, 12:31 PM | #2 |
Re: 68 Steering wheel parts
Does anyone have any idea which set of posts is correct? Are 67-68 horn guts the same as 69-72?
Paul
12-11-2013, 12:47 PM | #3 |
What?
When I rebuilt the column in my 1970 k10, it had what appeared to be the same guts as my 1968 burb.
I too have been looking around for the guts in the horn and signal switch area. From what I have seen, the vendors carry the bearings. But there is a plastic piece that goes around the steering shaft, and then sort of sits on top of the bearing and works like a centering part? I can't find that piece, where as everything else I can.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
12-11-2013, 01:07 PM | #4 |
Chris I picked up a Dorman "Help" part at my local CarQuest the other day that looks like the correct plastic piece. It has a brass ring on the bottom and the long shaft for the horn contact stuff. It also acts as the turn signal canceling cam. The long shaft holds the spring and washer for the horn. Dorman part number 83232 but number 83233 looks the same. Advance Auto lists it for a 1984 to 1973 Chevy truck.
Haven't had a chance to see if it actually cancels the turn signal yet though. http://shop.advanceautoparts.com/web...urn+signal+cam Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) Last edited by pwdcougar; 12-11-2013 at 01:20 PM. |
12-11-2013, 09:38 PM | #5 |
ok next up.
Will the 65 ish horn button work on the 68? I'm looking at the plain round cap that has "Chevrolet Division" imprinted on it but the older ones with the red bow tie are much cooler. Are they the same size? Paul
12-11-2013, 10:51 PM | #6 | ||||
The Older Generation
That piece is called the cancel cam/ bearing retainer. Quote:
I don't think that one will work. The original one has a taper on the bottom to hold the upper column bearing in place. The one in the link you posted doesn't look like it has the taper on the bottom. Quote:
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-11-2013 at 10:58 PM. |
12-12-2013, 11:30 PM | #7 |
The CST cap makes the truck feel so much nicer inside. There well worth the $100
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
12-14-2013, 11:45 AM | #8 |
Moderator
The plastic ring and metal cup are different. The metal disc is the same.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-17-2013, 11:49 AM | #9 |
Thanks guys. I'll be looking for parts to use. I want to dig into this project but the weather isn't cooperating.
Paul
12-25-2013, 12:46 PM | #10 |
Had Hanna out the other day and noticed that with the Dorman ring the turn signal only cancels in one direction. Maybe there is a problem with the turn signal switch too. I read through a thread on stock vs aftermarket steering wheels and I'm liking the 68 wheel more and more.
In the spring there is a huge swap meet in Carlisle PA. I'll have to go and look for the horn guts I need there to complete the 68 set up. Paul
12-25-2013, 03:04 PM | #11 | |
I would think you would be able to find something there. LockDoc
