10-15-2017, 11:17 AM | #26 |
Never Ending Projects
Re: Emergency Brake Delete on Rear Drums?
One thing that the E-brake system does outside of being a parking/e-brake is, the arm rotates the rear shoe adjuster. Without this system, as the shoes wear, they will not get adjusted and you will slowly lose the effectiveness of the rear brakes. You would have to manually adjust them as they wear.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
10-15-2017, 11:33 AM | #27 | |
10-15-2017, 02:37 PM | #28 |
The E-brake lever is on the inside of the brake shoe. It is activated by the cable and pushes the strut rod forward applying the shoes to the drum. The adjustment of the brake adjuster is from all the other hardware that is attached on the front side of the shoe. (Springs and adjuster arm). It activates the adjuster when driving in reverse and applying the brakes. The weight of the vehicle going back and the brakes trying to stop the weight of the vehicle cause the adjuster arm to push down adjusting the shoes. If you take the drum off and force the shoes back by pushing them front to rear you can see how it works. The minds that think this stuff up blow my mind. I guess im just too simple! Lol! In short they are two separate systems and will function one without the other.
10-15-2017, 04:15 PM | #29 | |
10-15-2017, 04:41 PM | #30 |
Sorry nsb29. My reply was more for Chevy Mike also.
10-15-2017, 11:06 PM | #31 |
Sorry guys, I was thinking more of how some of the more modern systems work. I had cars/trucks that specifically said the e-brake would adjust the shoes. Others that used the reverse and apply brakes method. Honestly I hate drums and tend to convert everything to discs anyways. LOL
10-16-2017, 10:17 PM | #32 |
Oh no, chevy mike back peddling? hahahaha
10-16-2017, 10:38 PM | #33 |
10-20-2017, 03:13 PM | #34 |
Hahaha.... I just convert everything to discs and it solves that problem.
12-18-2017, 11:11 AM | #35 |
Hey guys, not trying to bring a dead thread back alive. But im needing some help, I've started the brakes on my 1967 c20 fleet with the eaton ho52, I need to replace my e brake cable actuating lever and strut as well as the anti rattle spring. But I can't find them anywhere does anybody know where these items can be purchased? Thanks Taylor
12-18-2017, 12:25 PM | #36 |
Car truck shop in cali.
12-18-2017, 01:12 PM | #37 |
Car truck shop? Is that the name of the establishment? Do they ship parts as I'm in good old Utah.
12-18-2017, 01:20 PM | #38 |
Moderator
I just googled the words "car and truck shop" and got the first response - http://truckandcarshop.com/
Thats the one you want.
12-18-2017, 02:21 PM | #39 |
I just flipped though the online catalog and they didn't seem to have the part. I have all the hard ware I need the lever that the e brake fits into inside the drum. It has a slot to slip the cable in and then it pins onto the back plate.
12-18-2017, 04:16 PM | #40 | |
Moderator
I hate drums anyway.
12-18-2017, 06:28 PM | #41 |
TB - I am in the process of swapping to discs on my 64. I have all of the pieces you need is you can't find them closer. I'm in TN.
12-18-2017, 08:05 PM | #42 | |
Are the 64 components the same through 67? I'm just needing left and right e brake actuating levers, anti rattle bar and spring. Do you have pics? |
12-18-2017, 08:27 PM | #43 |
It looks looks up to 74 is the same.
12-18-2017, 08:28 PM | #44 |
12-18-2017, 08:32 PM | #45 |
t2 vigil looks like he may have the part.
12-18-2017, 11:57 PM | #46 |
60-66 Nut
The HO52 was not used beyond '72. You are likely looking at parts for a 12 bolt.
12-19-2017, 04:20 PM | #47 |
Tdbengry check you private messages.
