07-05-2003, 09:50 PM | #1 |
Rims And Tires
I am thinking about torq thrust II rims in 17x9.5 on the rearand 17x8 on the front (not sure what the backspacing should be on the front or the rear). What is the biggest tire I can run on the rear without scrubbing? Any help. Thanks
71 cheyenne 402 th400 swb 71 camper special (PARTS TRUCK) 70 Stepside swb 350 |
07-06-2003, 06:50 PM | #2 |
bump
07-06-2003, 07:10 PM | #3 |
Sizes & b.spacing req's will vary w/body style. Is it a step-side or fleet-side?
07-06-2003, 09:40 PM | #4 |
Fleet side
07-07-2003, 01:21 AM | #5 |
I've seen 295's on 15" rims, when you get up to 17-20's most i've heard of is 285's.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
07-07-2003, 01:48 PM | #6 |
I have 295/50/15s on my truck now on 15x10" wheels. I measured the width of the tire and it was about 13" at it's widest point. I then measured the tires I had on my car (315/35/17 Nitto DR) and it was like 12.5 on a 17x9 rim. I think you could run that size tire on our trucks.
I was going to run this size tire, but want something with a taller sidewall than a 35 profile tire, but no one make them, so I'll be running 275/50/17s in the near future. |
07-07-2003, 06:38 PM | #7 |
Is the truck lowered? If so, how much?
07-07-2003, 09:21 PM | #8 |
2.5 drop spindles front and lowered 4inches with springs on the rear. Thanks
07-08-2003, 09:18 AM | #9 |
295's
This has 295's 0n 15 x 10 and they will NOT tuck!
Roger
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd Last edited by raggedjim; 10-21-2009 at 03:07 PM. |
07-08-2003, 09:28 AM | #10 |
285/50/20 20X9.5 RIM I THINK ITS 4.5 ON THE BACKSPACING BUT WOULD HAVE TO DOUBLE CHECK..............AND THEY WILL TUCK!
70 SWB, 4/6" DROP,20X8 & 20X9.5. BOYD TIMELESS 5,93 BURB POWER SEATS, BILLET SPECIALTIES STEERING WHEELS. SOON TO BE VOTECH AND TBI POWERED. O YEA AND WAL-MART IS THE DEVIL!!! |
07-08-2003, 09:34 AM | #11 |
green70-72, What kind of wheels are those? They're nice...
Roger
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
07-08-2003, 09:40 AM | #12 |
BOYD TIMELESS 5'S THANKS
07-08-2003, 07:50 PM | #13 |
Thanks Green70-72 for the picture that is what I am looking for but with 17's but those 20's look good may have to reconsider. thanks again.
07-09-2003, 01:13 PM | #14 |
i am runnig 17X8 w/4.5" B.S. on all corners with 275-55-17, 11.5" at the widest point and plenty of room and they have a good amount of sidewall.
TIM '71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!! |
