11-15-2018, 12:33 AM | #1 |
Modify a tailgate to make it removable?
Anyone ever make a tailgate removable like the modern tailgates? I guess it would involve modifying one trunnion and cutting a slot in the bottom of one side of the tailgate hole.
11-15-2018, 01:09 AM | #2 |
Re: Modify a tailgate to make it removable?
Probably doable (and I'd do it exactly how you describe, same as the new trucks), but keep in mind that for the newer, removable tailgates, they sell tailgate locks to make them harder to remove (by a thief). So, there's good/bad to both sides of the equation. As often as I might (not) need to remove my tailgate quickly, I'd rather not worry about it getting stolen the other 99.9% of the time.
11-15-2018, 01:12 AM | #3 |
If you didn't already know, the '58-'66 gates are removable: Remove bottom bolt from left and right trunnions, pivot gate to horizontal position, support tailgate and remove upper bolts, maintain horizontal position and lift one end of gate until trunnion clears socket and you're out. No guarantees made on a scratch-free result, but they do come out easily enough.
11-15-2018, 01:41 AM | #4 | |
11-15-2018, 07:24 AM | #5 |
Moderator
Mark-K makes tailgates with -latches and links - http://www.mar-k.com/Catalog/index.aspx?LID=16178
11-15-2018, 02:13 PM | #6 |
I did this on mine just like you described. Just like my 2k 1500,works ok. No way could i even slide mine between the rails, at least by myself. You have to maybe leave the bedside's loose at the bottom and spread them out a little. Still scratches? This was on a fleet-side.
1961 chevy K10 my build is------------61K10 build |
11-18-2018, 12:06 PM | #7 |
I’m currently prepping my truck for paint and plan to do this in the very near future, to help make reassembly a breeze. Removing 4 bolts while balancing a tailgate is not what i’d consider quick removal. I did see pics of this mod either online or InstaGram but can’t seem to find them. But the guy did exactly what you mention, cut the trunnion flat on each side, I was thinking 9/16” , set at about 20 degree angle, then cut a 5/8” slot in the bottom of the tailgate.
11-21-2018, 10:49 AM | #8 | |
11-21-2018, 11:18 AM | #9 |
Tailgate theft around the area would prevent me from making my tailgate easier to remove.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
