10-08-2018, 10:10 PM | #1 |
67 p-30 with a 4 speed manual
What is the correct fluid or oil for the transmission???
10-08-2018, 10:25 PM | #2 |
Re: 67 p-30 with a 4 speed manual
Assuming it still has the SM420 in it here is the lube recommendation from Novak. If you find that it has had a new transmission swapped in then the link to Novak should be able to help with IDing what you have.
"When filling your 420 with gear oil, we recommend that you select a conventional mineral oil or a para-synthetic in lieu of a full synthetic oil. Properly assembled manual gearboxes do not have the thermal strains seen by combustion engines or hypoid gears. Synthetic fluid in these gearboxes, while not harmful, is probably an economic waste. Hypoid gear oil is sulphurized higher than transmission oil and can be mildly corrosive to the non-ferrous alloys used for synchros, bushings and thrust washers in these transmissions. An 80W-90, API-GL5 or MT-1 rated fluid is very good. Some claim faster shifts from using a 50W engine oil in their transmission and we do not consider this to be contraindicated unless you operate your vehicle in a very warm environment." http://www.novak-adapt.com/knowledge...s/manual/sm420 P.S. Welcome Aboard.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-08-2018, 10:26 PM | #3 |
The Older Generation
10-09-2018, 01:29 AM | #4 |
A couple of things. The SM420 is physically shorter that the SM465, so it may take less than the 8 pints [US Standard -- not Imperial] specified in the '68 manual. One US Gallon is 3.8 Liters, for our international viewers.
Also GL/4 is recommended for transmissions with bronze synchronizer gears. GL/5 is specified for limited slip [positraction] differentials.
