08-19-2010, 10:31 PM | #1 |
Now the others dig........
68 C10 Q:How thick are the Radiator Support Mounts?
I really need to know How thick mm or Inches are the Radiator support bushings that go between the Radiator support and frame mounted Bracket for a 68 C10 1/2 ton.
ALSO....2 years ago I got in to a wreck....pretty bad...ripped the radiator support out of the 68s right frame bracket and tore the bracket apart. I replaced it with a 70's bracket (its all I could find!!!). it all seemed to line up well aside from the hole being larger..I dont remember. I am planning on replacing the other side with a 70s bracket as well...if the frame is straight will these brackets line up center and height wise as the 68 brackets? I know the 68 and 70 bushings are way different...was planning on getting or fabbing the simpler 68 bushings. Just seeing if I will run into any serious problems aside from the difference in hole diameter.
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
12-01-2017, 03:40 AM | #2 |
Re: 68 C10 Q:How thick are the Radiator Support Mounts?
I'd like to know this as well... anyone have a set in a box that they can measure? I really only need to know how thick the rubber is as I have the washers already.
Edit: found another post in which someone sais "The rubber insulator pads for the 60-68 core support are around 1/8 in thick" ... with the single 1/8" washer that's 1/4" total.
1968 LWB C20 / AC / Wood Bed Last edited by crakarjax; 12-01-2017 at 03:50 AM. |
12-01-2017, 10:08 AM | #3 |
The Older Generation
I have a new set out in the shop. I will be going out shortly and will check. LockDoc
12-01-2017, 04:29 PM | #4 |
I like the design of the 69+ mounts better; I'm thinking I'll open up the bracket holes and trim down the later bushing to the correct height, so that measurement verification would be greatly appreciated!
1968 LWB C20 / AC / Wood Bed |
12-04-2017, 07:39 PM | #5 |
×2. I have a 68 and bought a set of core support bushings advertized for 67-72 which i later found out were for 69-72 only. I had already widened the frame hole by 1/16 inch to accomodate the bushing, so now im wonderimg if i can simply cut the bushing down to acheve the correct height... would love to know for sure the correct height between the rad support and frame when installed.
12-04-2017, 07:45 PM | #6 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by LockDoc; 12-05-2017 at 06:02 PM. Reason: WTB by non Premium member |
12-05-2017, 02:31 PM | #7 | |
12-05-2017, 05:54 PM | #8 |
I finally remembered to do this and mine measure 1/4+, which means they are a smidge thicker than a quarter inch.... I made some out of a piece of truck mud flap once and they worked good. That was before you could buy them. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-05-2017 at 06:05 PM. |
12-05-2017, 11:38 PM | #9 |
Thanks for the confirmation!
