11-12-2018, 01:45 PM | #1 |
Whats everyone have for front inner fender tubs, while bagged?
Was hoping to get around from going with fire wall hinges.
11-13-2018, 10:54 AM | #2 |
Re: Whats everyone have for front inner fender tubs, while bagged?
What vehicle?
Modify stock tubs. Modified/built trailer fender tubs. Fabricated sheet metal tubs. Hills Rod & Customs (Pleasant Hill, CA). Slosh Tubz.
11-15-2018, 12:01 PM | #3 |
More info is needed what are your plans what do you have?
I am running 2.5 drop spindles, PB upper and lower arms, bagged with 17" wheels. Stock inners and hinges are working fine for me.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
11-15-2018, 12:16 PM | #4 |
Most likely you also have a fairly short tire up front as well (<28").
11-15-2018, 12:39 PM | #5 |
Yes it is a short tire 215/50r17 about 25.5 tall
11-17-2018, 09:03 AM | #6 |
I modified a set of wheel wells from the bed for mine. It was fairly easy but I do still need to make some small filler pieces to close in some gaps.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
11-17-2018, 04:34 PM | #7 |
This is what I mocked-up for my 67 years ago....
