08-11-2015, 08:19 PM | #1 |
60-66 4x4 Frames
Does anyone know if there are any differences in the 4x4 frames of these years? As far as what bodies will fit what frames...etc?
08-11-2015, 08:39 PM | #2 |
But Found Her 25yrs Later!
Re: 60-66 4x4 Frames
60-62
63-66 67-72 73+
08-11-2015, 08:49 PM | #3 |
Is there a vin # or partial on the frame to determine what year the frame is...or is there something obvious about the frame to determine what year it is?
08-11-2015, 09:00 PM | #4 | |
simplify it there is something in the faq about frame dimensions inc thickness ron |
08-11-2015, 09:30 PM | #5 |
Well....I am buying a nice 63 big window cab and it has a 3/4 ton 4x4 frame that comes along. The cab is a 2wd cab. I do not know what year the frame is. Sorry if I was vague but wasn't trying to....I guess I can ramble sometimes
08-11-2015, 10:06 PM | #6 |
08-11-2015, 10:22 PM | #7 |
sorry....dont have a pic of the frame. Probably would be a couple of days till I would have some.
08-11-2015, 10:30 PM | #8 |
Not sure if this helps, 64 K10 has last part of vehicle identification number stamped in frame top rail drivers side, above drag link. The first part of the ID number is not stamped which would be more helpful to you.
Les |
08-11-2015, 10:58 PM | #9 |
1961 crewcab
if it is a 63-66 frame , then the 63 cab will just bolt on, if it is a 60-62 frame then you need to drill a couple holes for the front cab mounts to work.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
08-12-2015, 01:18 AM | #10 |
60-66 Nut
The frame will have the VIN stamped on the top flange of the frame between the steering box and the engine mount on the drivers side. Then you will need to decode it to find out what year it is.
08-12-2015, 01:25 AM | #11 |
The cabs are no different between 4x4 and 4x2. We can tell what year the frame is based on the crossmembers and body mount brackets.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
08-12-2015, 06:30 AM | #12 |
Check The Champ, Demonstrator
1960-62 K1000 frame GMC J-N Series
1960-63 K10 frame ( In 1964 the motor was no longer supported by the front crossmember.) Rear shocks were mounted parallel to the frame in 64 as compared to the V style of the earlier years. The drag link between the steering box and axle changed from a ball type setup inside a tube to a cast tie rod setup.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
08-12-2015, 12:37 PM | #13 |
beside the small differences my manual says 4x4 frames where the same as 1tons. latter type not x type frames like in 60-63
1961 chevy K10 my build is------------61K10 build |
08-12-2015, 01:47 PM | #14 |
1960-66 frame dimensions
Frame dimensions are as follows: 1963-66 ½ ton 2WD: 6-1/32 x 2-1/2 x 5/32 ¾ ton 2WD: 6-1/8 x 2-17/32 x 3/16 One ton 2WD: 8-1/8 x 2-13/16 x 3/16 ½ ton 4WD 115” WB: 8-1/32 x 2-25/32 x 9/64 ½ ton 4WD 127” WB: 8-1/8 x 2-13/16 x 3/16 ¾ ton 4WD: 8-1/8 x 2-13/16 x 3/16 As you can see, even the ½ ton 4WD long bed uses the same size frame member as the one ton 2WD. 1960-62 frame ,measurements ½ ton 2WD: 5-15/32 x 2-1/4 x 1/8 ¾ ton 2WD: 7-3/16 x 2-3/4 x 3/16 ½ and ¾ ton 4WD: 7-13/64 x 2-3/4 x 3/16 ron |
08-13-2015, 11:19 AM | #15 |
thanks for all the info...I will try to get a pic and some measurements.
08-13-2015, 02:48 PM | #16 |
The 60-62 K model frames had the single horseshoe motor mount, mount was in the front of the tubular cross-member for I6 trucks, the rear for V8 trucks. Mine was hacked so I had to fab one up. The GMC's had a plain cross-member and used the more conventional side mounts for their V6. Also at the rear of the frame they're mounts on the side of the frame to accommodate the wider rear bed sill on the 60-62. The rear shocks mount forward of the rear axle for 60-62 and 63-66 have one mounted forward and the other to the rear.
08-14-2015, 01:01 AM | #17 |
Correction on the rear shock mounts. 60-62 are mounted off the spring pad, or maybe its the block, and tilted to the centerline of the chassis, like in the pic above. 63-66 they are mounted to the axle tube and both tilt forward.
10-03-2018, 09:24 AM | #18 | |
60260 (the bracket that is most forward on the frame) where the heck would i find 2 of them |
10-03-2018, 09:35 AM | #19 |
I have 63-66 frame at home will be parting.
Headed to California back in 2 weeks.
10-03-2018, 12:17 PM | #20 |
good information in this thread ...
dont want to hear excuses, i want to hear solution(s) |
09-09-2021, 06:43 PM | #21 |
Thanks to everyone who commented here, this just answered all my questions on what 4x4 frame I have.
