Old 03-17-2014, 05:03 PM   #26
LONGHAIR
Re: Sharing my bump steer fix with this Great community of truck nuts!
I am in total agreement with the others about a lock nut of some kind. I wouldn't try to drill them for a cotter pin, a simple prevailing torque type nut is perfectly fine.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-20-2015, 06:36 AM   #27
The Rocknrod
Moderator
The Rocknrod's Avatar
Originally Posted by hugger6933 View Post
Do they make the rod ends with a insert[bushing] of some kind for street use. I seem to recall when i was messing with those wallet draining drag cars that when you put the 4 link stuff in the back you could opt for different rod ends with some sort of insert the name escapes me now but it was to help a small bit on noise and with the other slight issues that might arise with daily use of driving a car/truck with rod ends on it. Jim
http://www.speedwaymotors.com/Speedw...ead,25122.html
http://www.est1946.com/ssadjustablerodends.aspx
Old 05-15-2016, 02:16 PM   #28
crakarjax
crakarjax's Avatar
Originally Posted by poorboy View Post
Speedway also sells the cone spacers.
These
http://www.ebay.com/itm/370610280385
The high misalignment spacers wont work afaict because they reduce the bolt down to 1/2" on a 5/8" spacer. I suppose you could bush the steering knuckle to 1/2", but I don't know if a 1/2" bolt would offer enough margin of safety.
Also, with a longer bolt you can insert spacers between the cone and steering knuckle to fine tune the shaft angle.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 05-15-2016, 02:44 PM   #29
crakarjax
crakarjax's Avatar
Doing some digging, it looks like the tie rod adj. sleeve from a '90 Dodge D150 fits, at 10" and 11/16-18 thread.
http://www.rockauto.com/en/moreinfo....096&cc=1087051
And at $8 each not a bad deal -- I'd like to see an aluminum sleeve but couldn't find a set.
I did find an 8.5" aluminum set, but idk if this will fit. I'm not too close to mock-up yet so I can't really tell.
http://www.summitracing.com/parts/pof-105-10049/
Seems like it would be easier and cheaper to find stuff if we could use a 5/8" thread inner tie rod end. Anyone know of a suitable interchange? Even drilling the inner to a 5/8 heim would be cheaper overall. Check out this high misalign Heim for instance:
http://www.speedwaymotors.com/QA1-PC...ale,45403.html
Old 05-15-2016, 04:34 PM   #30
wbc409
What you did with the heim joint is the same thing Factory Five sells as a bump steer kit for their cobra replicas. Their kit comes with an aluminum sleeve with opposing threads so all you have to do is loosen the jam nuts to adjust.
wbc409 is offline   Reply With Quote
Old 05-16-2016, 01:19 AM   #31
crakarjax
crakarjax's Avatar
I think the ES323L inner tie rod end will work to convert to 5/8" -- it's got a slightly smaller small and large taper diameter but identical taper angle.
Useful site: http://webcache.googleusercontent.co...&ct=clnk&gl=us
Old 08-11-2016, 11:31 AM   #32
The Rocknrod
Moderator
Looks like some company came up with a solution on the tie rod thing:
http://www.gsimfab.com/tie-rod-adapt...4250_8716.html
Old 08-11-2016, 01:04 PM   #33
BMERDOC
BMERDOC's Avatar
The website says they are used to connect and rack to the spindles. Not the same thing.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 08-11-2016, 04:52 PM   #34
crakarjax
crakarjax's Avatar
They could be used for the same purpose but for $200 I'd rather just drill out the knuckle or get a tapered bushing to use a bolt. Tempting though, they look like nicely made pieces.
Old 08-11-2016, 05:08 PM   #35
Boog
laying low
Boog's Avatar
Gsimfab thinks its a good idea to use a cotter pin too. Just sayin.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-11-2016, 08:21 PM   #36
crakarjax
crakarjax's Avatar
Absolutely, not worth risking a crash over...
Old 08-11-2016, 11:15 PM   #37
crakarjax
crakarjax's Avatar
I was thinking that something like this could be used if you ever wanted to go back to a top-mount rod, or even inserted into the bottom if you wanted to use regular tapered rods.
http://www.ruffstuffspecialties.com/.../INSSTEER.html
Old 08-12-2016, 07:04 AM   #38
jjzepplin
jjzepplin's Avatar
I like both options. If those rack units are aluminum I might wonder. I think the spacer might be safer.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-12-2016, 10:08 AM   #39
88Stanger
88Stanger's Avatar
This is an awesome thread. Thanks you posting this and all the great added ideas!!
88Stanger is offline   Reply With Quote
Old 01-08-2018, 05:34 PM   #40
Ben_Yeaton
Has anyone used a bushing like this to flip the tie rod? I have found a few other options, just no specifics on pitch to know if they fit the C10 taper. The link above says for GM 1-ton rod ends, and I see others specifically for Jeep and Dana 30. Not much else. I feel like this could be a really good option for lowered guys facing this issue.
Ben_Yeaton is offline   Reply With Quote
Old 01-08-2018, 09:58 PM   #41
Robznob11
Robznob11's Avatar
Talking Re: Sharing my bump steer fix with this Great community of truck nuts!
Here are my parts from rod end supply. There heim design cannot come appart and therefore needs no large washer on the bottom. As seen from pic. They are also self lubricated sealed units with special wear compound. They will make sleeves for you with any thread , any length, in aluminum, or steel (zink plated) i opted for aluminum 8 1/2 " long with a 5/8 LH anfd 3/4 RH. I have narrowed arms and was already running the cpp conversin sleeves from the disc swap years ago. So this will be a direct replacement bump steer kit with high end parts for about $115 shipped to my door. Oh I also got the stainless misalignment sleves like lolife posted. Only thing not pictured is 5/8 grade 8 bolts and lock nuts. I will get them locally.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 01-08-2018, 10:59 PM   #42
beadblaster
beadblaster's Avatar
mooreparts.com sell rubber dust boot covers for him joints
FK 1/2" TO 3/4" HEIM JOINT RUBBER BOOT SEAL RERS3
Brand:
FK Bearings
Price:
$7.00
(No reviews yet) Write a Review
SKU:
FK-RERS3
Availability:
Sold as Each
beadblaster is offline   Reply With Quote
Old 01-09-2018, 09:58 AM   #43
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Thank you for the heads up, all of you! ~Ghostrider~
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-14-2018, 04:59 PM   #44
Robznob11
Robznob11's Avatar
Update with pics above😁
LED TAILS
Old 01-14-2018, 11:02 PM   #45
Indyspecracer
Originally Posted by Robznob11 View Post
Here are my parys from rod end supply. There heim design cannot come appart and therefore needs no large washer on the bottom. As seen from pic. They are also self lubricated sealed units with special wear compound. They will make sleeves for you with any thread , any length, in aluminum, or steel (zink plated) i opted for aluminum 8 1/2 " long with a 5/8 lh anfd 11/16 rh. I have narrowed arms and was already running the cpp conversin sleeves from the disc swap years ago. So this will be a direct replacement bump steer kit with high end parts for about $115 shipped to my door. Oh I also got the stainless misalignment sleves like lolife posted. Only thing not pictured is 5/8 grade 8 bolts and lock nuts. I will get them locally.
Would you mind posting the part numbers for the inserts that go in the arms of the knuckles? Thanks, Dave
Indyspecracer is offline   Reply With Quote
Old 01-15-2018, 07:34 AM   #46
Robznob11
Robznob11's Avatar
The missalignment sleves are hms 10-12. If you are talking about abtapered insert for the spindle...there is not one....you drill the hole to a 5/8 straight bore and use a grade 8 bolt with lock nut. Aslo they have many styles of ends. Get the best chromemoly ones. I called and talked to Marda so she got me straight on the correct stuff.
LED TAILS
Old 02-19-2018, 06:34 AM   #47
The Rocknrod
Moderator
Here are my parts from rod end supply. There heim design cannot come appart and therefore needs no large washer on the bottom. As seen from pic. They are also self lubricated sealed units with special wear compound. They will make sleeves for you with any thread , any length, in aluminum, or steel (zink plated) i opted for aluminum 8 1/2 " long with a 5/8 lh anfd 11/16 rh. I have narrowed arms and was already running the cpp conversin sleeves from the disc swap years ago. So this will be a direct replacement bump steer kit with high end parts for about $115 shipped to my door. Oh I also got the stainless misalignment sleves like lolife posted. Only thing not pictured is 5/8 grade 8 bolts and lock nuts. I will get them locally.
When you get those installed can you post a pic for the rest of us?
Old 02-19-2018, 08:47 AM   #48
Robznob11
Robznob11's Avatar
Yes sir! Currently im wating on my narrowed 9" to be built by quick performance. So it will be a month or so....
LED TAILS
Old 02-28-2018, 10:09 PM   #49
mpalmer03
Just got my new girl home- 69 swb still with 6 lug/drums. Wasn’t even aware of bumpsteer phenomenon until I saw on here. Unfortunately, mine has 3” spring drop only as well. My tie rod end in stock position is pretty flat. The part that concerns me is the bump stop on bottom only has an inch to go before it bottoms out on flange. Any ideas would be greatly appreciated. Didn’t have new springs and drop spindles in budget right now.
mpalmer03 is offline   Reply With Quote
Old 04-20-2018, 02:26 PM   #50
Robznob11
Robznob11's Avatar
Well I got my kit on only to find out that my draglink had been swapped by a previous owner. Even though it looks cool the inner tierod are wrong fo my draglink.😡
If anyone has done the conversion disc swap where you use 68 outers as inners, hit me up if you want to switch to Heims on the spindle side. I had to have another set of adjusters made. So I guess these can become pretty shop art until the right person comes along....
LED TAILS
